Username Post: 1999 Silverado - "security" light stays on        (Topic#238461)
Gotechslack
Reg: 02-01-10
03-23-10 12:59 PM - Post#1885412
Hello. I have the stated truck. The "Security" message came on while driving the other day. When I turned off the truck and started it, the message went off. This happens periodically, but not all the time. It can go days without coming on. Any ideas? Thanks.
rodram
Loc: Saskatoon, CANADA
Reg: 04-14-09
03-23-10 01:12 PM - Post#1885424
    In response to Gotechslack
it is possible that the security light is coming on because the security system is detecting something unexpected in your ignition key cylinder ....
that may sound wild to you, but I had this issue with my '02 Impala ... and someone convinced me that the issue would be worse if my key ring was big and heavy with a ton of other keys swinging away as you drive... this causes the issue in the key cylinder
if you normally use a big heavy key ring, then try driving with a light key ring ... only 1 or 2 keys on it... and see if that makes any difference ... it did for me..
Gotechslack
Reg: 02-01-10
03-24-10 07:48 AM - Post#1885930
    In response to rodram
I do have a big key ring. I'll try it. Thanks!!!
rodram
Reg: 04-14-09
03-24-10 12:34 PM - Post#1886060
if the damage in the key cylinder is already done ... the lighter key ring may help, but maybe not totally eliminate the security light issue
Good Luck
Bad Bowtie
Bad Bowtie
Loc: TX
Reg: 07-04-03
03-24-10 12:49 PM - Post#1886075
Try blowing out the lock cylinder with some of that computer (bottled air) cleaner too...
Gotechslack
Reg: 02-01-10
03-25-10 12:58 PM - Post#1886671
Good Luck
Just bought the truck last month. I lightened my key ring. Hasn't come on yet. Got my fingers crossed. Thanks for your help.
Gotechslack
Reg: 02-01-10
03-25-10 12:59 PM - Post#1886672
    In response to Bad Bowtie
Will do. Thanks.
Execution time: 0.319 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:11 PM
