Username Post: Diffrence between a 1964 impala ss and 1964 four door impala        (Topic#235934)
avilae99
Reg: 01-06-10
02-17-10 08:27 PM - Post#1864934
Hello, I was wanting to know if the frame from a 1964 four door Impala would fit on a 1964 2 door Impala SS. Also would any other body parts fit as well . I would appreciate the help. Thanks for the feed back to all those who have replied.
Edited by avilae99 on 02-17-10 08:33 PM. Reason for edit: No reason given.
Dave64SS
Dave64SS
Loc: Cypress, TX
Reg: 02-28-09
02-18-10 07:54 AM - Post#1865101
    In response to avilae99
most definitely the frame will work. convertable frames are different, but non verts are all the same. I'm not sure how far back, but 61,62,63 frames would work as well....maybe older. other experts I'm sure will chime in. regarding the 4-dr parts....the entire front clip is a swap...of course molding hole will likely be different. trunk is same (should be same tail light setup)...doors wont swap....far rear quarter panels would...past rear door. i suspect glass is interchangable. probably other stuff...but thats what i know of.
Bigcarman
Bigcarman
Loc: Tucson, Arizona
Reg: 01-20-00
02-18-10 08:47 AM - Post#1865131
    In response to Dave64SS
No glass, except maybe the vent window....
Robert
63 Impala original AZ car in transition
63 Bel Air 2dr sedan 454 hotrod
97 Monte Carlo daily driver;
80 F-100 84,000 original miles (Dad's old truck)
Dave64SS
Dave64SS
Loc: Cypress, TX
Reg: 02-28-09
02-18-10 09:11 AM - Post#1865139
    In response to Bigcarman
interesting..i would have thought front and rear glass would have worked. i guess the design "lines" are different. thanks for correcting me...just in case i ever need glass for my impala....
Trailbum
Trailbum
Loc: Harpers Ferry, WV
Reg: 11-06-00
02-18-10 10:44 AM - Post#1865177
Hey Dave, Different roof lines between the 2 door and 4 door. Back window is WAY different. You would THINK the windshields interchange, but they are slightly different!!!
"They say men should get in touch with their feminine side.... Well, if I HAD a feminine side.. believe me, I'd be TOUCHING IT!!!"
Bobaloo
Bobaloo
Loc: Alabama
Reg: 07-02-07
02-18-10 01:03 PM - Post#1865242
    In response to Trailbum
Just for informational purposes, 2 door post cars will swap glass with 4 door cars in this time frame. 62-64 at least.
Bobaloo
See my progress at http://63belair.9f.com/
1963 Bel Air 2dr
avilae99
Reg: 01-06-10
02-18-10 07:05 PM - Post#1865433
    In response to Bobaloo
I appreciate all the feedback Thank You fellas.
Trailbum
Trailbum
Reg: 11-06-00
02-18-10 07:38 PM - Post#1865456
Sorry...... I wasn't thinking of the 2-door post models. I was only thinking 2-door hardtops... You are correct!!!
MajesticsCanada
MajesticsCanada
Loc: Surrey, B.C., Canada
Reg: 08-27-06
02-19-10 01:25 AM - Post#1865550
will the frame from a 58 impala work in a 62? I know the rearend mounts are different, but will everything else work?
VintageCarryall
Loc: Arizona
Reg: 10-08-06
02-21-10 04:48 PM - Post#1866846
    In response to MajesticsCanada
Out of luck there: the 1958 has a standalone frame due to a 117.5" WB.
avilae99
Reg: 01-06-10
03-09-10 06:50 PM - Post#1877190
Hello, I am restoring a 1964 Impala SS 2 door and I am wanting to purshase a 1964 Impala 4 door for parts can someone help me and let me know what parts I can use and what I can't use. I appriciate all the feed back. Thanks
Edited by avilae99 on 03-09-10 07:01 PM. Reason for edit: No reason given.
avilae99
Reg: 01-06-10
03-09-10 06:51 PM - Post#1877193
Can the doors on a 1964 Impala 4 door fit on a 1964 Impala 2 door. Thanks
avilae99
Reg: 01-06-10
03-09-10 06:58 PM - Post#1877201
This feed back is giving me HOPE to be able to get this Impala restored sooner thanks fellas. I was wanting to know if the floor pans would fit as well from the 1964 Impala 4 door on the 1964 Impala 2 door?
Edited by avilae99 on 03-09-10 06:59 PM. Reason for edit: No reason given.
4spd409
4spd409
Loc: West Fargo ND
Reg: 10-10-02
03-09-10 07:20 PM - Post#1877217
In short no. The 2 door doors are longer and there are other differences also.
61 Impala Bubbletop
4spd409
4spd409
Loc: West Fargo ND
Reg: 10-10-02
03-09-10 07:27 PM - Post#1877219
You can use most of the mechanical parts. The front clip is the same with the exception of the trim holes on the front fenders. The trunk lid will interchange with the same trim hole problems. Rear bumper is the same as are the floor pans and trunk floor. The dash area is the same with a little trim difference. None of the glass interchanges. It is always helpful to have a parts car around even if it is a different body style.
61 Impala Bubbletop
slo
Loc: Houston Tx and Sydney Aus...
Reg: 03-16-08
03-11-10 03:33 PM - Post#1878306
    In response to 4spd409
flor pans will work... doors no roofline or glass no, front end yes, trunk and trunk sections of floor yes.. all suspension yes. .
1964 Impala SS
1964 Impala station wagon
1953 chevy 210
2005 Silverado
Execution time: 0.269 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:48 PM
