 Page 4 of 25 « First<4567>» Last
Username Post: What did you do to your truck today?        (Topic#235250)
hilandr451
hilandr451
Loc: Anna Texas
Reg: 01-02-02
06-14-10 06:52 AM - Post#1929951
    In response to old_gto
I got the new carb plumbed in and bolted on. I installed a relay for the fuel pump, re-routed the fuel line down the C-channel and cleaned up some wiring. I had just enough timne last night to test all the electrical connections and fire it up. She's pumping fuel just fine and she started right up!
I still need to re-tune the carb for the motor, set idle mix, adjust the idle speed, cold start idle, TV cable that sort of thing, then she'll be ready for a test drive!
Mikey, Jeff - yes, I took about a bajillion pictures, no I haven't processed them yet. I plan to have them up tonight.
-The Hilander.
Silver 2017 Silverado 1500 double cab 2WD 5.3L
"Rattle can primer red" 1966 C20 Custom Camper 5.7L, 700 R4 trans 410 diff. front disc, p/s
Project Pics
HURSTSSAMX69
HURSTSSAMX69
Loc: Madison, WI
Reg: 01-23-10
06-14-10 07:12 PM - Post#1930331
    In response to hilandr451
it's tonight . . . where is them photos ?
1953 Studebaker M275.
1962 GMC 4500.
1969 AMC AMX.
1976 Arctic Cat Jag2000.
1977 Ford F-350.
1988 AMC/Jeep MJ.
1992 GTA Trans AM.
1995 GMC K2500.
2007 Honda Rubicon TRX500.
Looking for M52A1 Mack 5T 6x6/M123A1C 10T Mack 6x6.
hilandr451
hilandr451
Loc: Anna Texas
Reg: 01-02-02
06-15-10 06:20 AM - Post#1930512
    In response to HURSTSSAMX69
Busted! sorry - I ended up staring at the inside of my eyelids when I got home after work. My wife said I was competing with the neighbor's sander all the way up until dinner time. After that I went to bed. I must be gettin old.
I promise to have them up tonight!!!
-The Hilander.
Project Pics
old_gto
Needs to Get Out More Member
old_gto
Loc: Orlando, FLA
Reg: 07-13-00
06-15-10 11:50 AM - Post#1930637
Huh...what?
Did somebody call me?
The only thing I`m sure of, is that I`m not sure of anything.
71 Corvette, 97 burb, 66 GTO, 69 Grand Prix, 65 Mustang, 65 C-10 Fleetside, 74 Camaro
Too many toys, not enough play time!
hilandr451
hilandr451
Loc: Anna Texas
Reg: 01-02-02
06-15-10 05:08 PM - Post#1930818
Here's the old Thermoquad on the bench for good.
Here's the cavity I have to work in. Not so good for a man of girth such as m'self.
Solution: I used Mikey's engine as a model to fab up & fit the plumbing & linkage brackets. Here's the new fuel inlet (the T.Q. came in the back of the carb). I needed to run behind the alternator and drop out into the C-channel on the forward RH frame.
Here I routed the vacuum line for the brake booster under the linkage. The T.Q. had no outlet for this and I used a "T" fitting out of the manifold. The hose used to droop over the throttle linkage (not good).
Attachment: New_Carb_6-12-10_001.1.jpg (64.04 KB) 2078 View(s)
Attachment: New_Carb_6-12-10_002.jpg (111.67 KB) 2564 View(s)
Attachment: New_Carb_6-12-10_003.jpg (57.82 KB) 1991 View(s)
Attachment: New_Carb_6-12-10_001.2.jpg (79.17 KB) 1997 View(s)
-The Hilander.
Project Pics
hilandr451
hilandr451
Loc: Anna Texas
Reg: 01-02-02
06-15-10 05:18 PM - Post#1930825
Here's where it paid off - the new fuel inlet line just dropped right in place and dumps out right where I wanted it to.
Here's the vac line in the back - looks like it's suposed to be there.
There all in and hooked up. Now all I have to do is tune it. - Oh yeah and clean up about 25 lbs of sloppy half azzed wiring.
Attachment: New_Carb_6-12-10_004.jpg (51.07 KB) 2015 View(s)
Attachment: New_Carb_6-12-10_005.jpg (84.15 KB) 1624 View(s)
Attachment: New_Carb_6-12-10_006.jpg (80.26 KB) 1620 View(s)
-The Hilander.
Project Pics
HURSTSSAMX69
HURSTSSAMX69
Loc: Madison, WI
Reg: 01-23-10
06-15-10 05:48 PM - Post#1930837
Looking good !
Your routing seems to be about spot with factory style of that era . . .
379-V6:
1962 GMC 4500.
1969 AMC AMX.
1977 Ford F-350.
1988 AMC/Jeep MJ.
1992 GTA Trans AM.
1995 GMC K2500.
1965C-10
1965C-10
Loc: San Tan Valley AZ "Phoeni...
Reg: 11-18-01
06-16-10 11:47 AM - Post#1931180
Where do you have the electric choke wire going, I read that it should be on the starter "run" terminal?
58delray
58delray
Loc: Rutledge, Georgia
Reg: 03-09-01
06-16-10 05:37 PM - Post#1931455
    In response to Chevy_Stepside
Still trying to get it started
Attachment: IMG_3004.JPG (144.33 KB) 1493 View(s)
Attachment: IMG_3005.JPG (198.41 KB) 1521 View(s)
1958 Delray
HURSTSSAMX69
HURSTSSAMX69
Loc: Madison, WI
Reg: 01-23-10
06-16-10 07:12 PM - Post#1931541
    In response to 58delray
It'll all come together in due time all in due time . . .
1962 GMC 4500.
1969 AMC AMX.
1977 Ford F-350.
1988 AMC/Jeep MJ.
1992 GTA Trans AM.
1995 GMC K2500.
Chevy_Stepside
Chevy_Stepside
Loc: San Francisco, Ca, USA
Reg: 07-08-02
06-16-10 07:19 PM - Post#1931546
Well I was on my way to work on the 66 when the Ranger started to make that noise again. There is a noise it has been making when taking a left turn on the freeway but not all the time. Well this time it really started. It sounded like a wheel bearing. It managed to stop binding and I drove it home about 15 miles.
It seems the last dork that did the brake job forgot to put the seal on the left side. I drove this truck 35,000 miles like this. After I got the wheel off I noticed I needed new brakes.
I should have known something was amiss. When I first got the truck it was making a banging sound when ever I went over a bump. I noticed it stopped when I applied the brakes. Well after looking around the same dork that forgot the seal didn't tighten the caliper mount bolts very well. They were making their way out.
Lucky for me I was able to get the remainder of the bearing off.
So I had to work on that truck instead today. I put new rotors, brakes and wheel bearings only on the left side but I did repack all of the bearings. I spent about $150 in parts.
I think I am going up Sunday to work on the 66. I want to get it started this weekend.
"A man and his truck, It's a beautiful thing"
The tour is on again. May 1st 2011. $5 I ride 100 miles. http://main.diabetes.org/site/TR?pg=personal&a mp;f...
hilandr451
hilandr451
Loc: Anna Texas
Reg: 01-02-02
06-18-10 10:44 AM - Post#1932259
    In response to 1965C-10
I ran the e-choke from switched power off of the ign sw.
I don't know if it would be the best idea to have the choke heater on the same circuit as the coil. I'll need to look into that.
I did however, install a fuel pump relay so I could take that load off of the ign. sw. Fuel pump now gets it's power directly from the battery via the positive terminal block at the horn relay.
I'm thinking I'm going to install a bussed terminal strip there so I can have more connections. Right now, with 3 or 4 wires landed at aech of the two screws, the horn relay looks like some kind of Christmas tree ornament.
-The Hilander.
Project Pics
old_gto
old_gto
Loc: Orlando, FLA
Reg: 07-13-00
06-20-10 08:01 AM - Post#1933179
We got the cab off the frame, set up on blocks. We got the center section of the frame done with POR 15, next we`ll put some glossy black "Rustoleum" over the frame, (it will retain the shine a little better than the POR) then we can start working on cleaning & painting the front suspension parts!
String
Loc: Sault Ste Marie Michigan
Reg: 05-08-10
06-20-10 11:28 AM - Post#1933259
Pulled out the steering column support, the clutch and brake pedal support bracket and parking brake. Wire brushed, sanded primed and painted.
Beer is proof that God loves us and wants us to be happy. Benjamin Franklin
Chevy_Stepside
Chevy_Stepside
Reg: 07-08-02
06-20-10 07:13 PM - Post#1933466
    In response to String
I got the 66 fired up today. Was nice to hear is rumble through the open headers. Now I just have to get the tranny all buttoned up. I did take a short video of it but have to upload it. Now I just have to figure out how..
Edited by Chevy_Stepside on 06-20-10 07:14 PM. Reason for edit: No reason given.
1965C-10
1965C-10
Reg: 11-18-01
06-20-10 09:09 PM - Post#1933505
Open headers, Mikey style
hilandr451
hilandr451
Loc: Anna Texas
Reg: 01-02-02
06-21-10 01:04 PM - Post#1933722
Final adjustments and test drive on Sat. Scarry power!!! gonna have to buy some tires if I keep this up!
I drove it in to work today - 80mph down the freeway. Nice solid ride, responsive and quick. It doesn't feel like a 3/4 ton truck anymore.
.....Now let's make her puurrdy!
-The Hilander.
Project Pics
1965C-10
1965C-10
Reg: 11-18-01
06-21-10 07:03 PM - Post#1933931
Glad to hear it's quick now.
I remember riding with you in your truck I think Jan 2002, when we went to Frisbee's place somewhere past Sacramento, and it would only go 55!
hilandr451
hilandr451
Loc: Anna Texas
Reg: 01-02-02
06-22-10 06:40 AM - Post#1934068
Unfortunately on the way home it started acting up again. Like it's running out of fuel. It ran fine on the way to work. It was hot yesterday afternoon (well 88ยบ anyway), maybe that had something to do with it.
It ran strong for almost 10 miles then on the last 5 mile stretch I limped all the way home.
It would cut out like the fuel was being switched off and then lurch forward as if the fuel was being turned on again - then it would die all together. I'd pull over and let it sit for a minute then I'd put it in park, restart the engine and it would rev up just fine. I would put it in gear, it would run good for a minute while shifting through the gears then it would start cutting out again before we could reach 40 mph.
I don't get it! It was running beautifully from Saturday morning until yesterday afternoon.
-The Hilander.
Project Pics
Vaughn
Vaughn
Loc: Colorado Springs, CO
Reg: 08-08-04
06-22-10 12:06 PM - Post#1934210
As you probably already know:
Vapor lock or water contamination in the fuel, usually.
Insulate the fuel line next to the block and up to the carb. Change filters to be safe.
If ti still does it, a vane fuel pump with a return style regulator will eliminate vapor lock, keeping the fuel in the line cool because of the return. It will also eliminate dry carb start ups, if that is an issue.
You can pull the sending unit and look for evidence of water in the tank. It may be necessary to drain the tank and clean it out.
dewitte
dewitte
Loc: Virginia
Reg: 06-16-10
06-22-10 05:20 PM - Post#1934379
Today I fixed the signal light switch and bought replacement wiper blades. Hoorah!
Chevy_Stepside
Chevy_Stepside
Reg: 07-08-02
06-23-10 03:14 PM - Post#1934820
    In response to dewitte
Here is the video. http://www.youtube.com/watch?v=v7ZDk8fKDmc
dewitte
dewitte
Loc: Virginia
Reg: 06-16-10
06-23-10 05:07 PM - Post#1934882
Today I installed the wiper arms and new blades and replaced the bad headlight dimmer switch. Should be road worthy real soon.
58delray
58delray
Reg: 03-09-01
06-23-10 05:16 PM - Post#1934889
nothin
1958 Delray
1965C-10
1965C-10
Reg: 11-18-01
06-24-10 10:32 AM - Post#1935257
Is that "ooga' horn like Chevyboy has on his truck?
HURSTSSAMX69
HURSTSSAMX69
Loc: Madison, WI
Reg: 01-23-10
06-24-10 06:33 PM - Post#1935521
I found 2 set of 2 tires, Tho 1 guy seems to be unfairly priced as he doesn't really wanna sell want's to trade 4 8R19.5's for 2 8-19.5s thats like paying $250x4 = $1000/2= $500 a tire for used baisply Mudders . . .
the other seems to be spaced out . . . only hear from him about once a week so far ask a few questions get 1 answered a week . . . so who knows . . .
1962 GMC 4500.
1969 AMC AMX.
1977 Ford F-350.
1988 AMC/Jeep MJ.
1992 GTA Trans AM.
1995 GMC K2500.
LT1BURB
Loc: Roseburg Oregon
Reg: 01-06-05
06-24-10 08:48 PM - Post#1935599
I opened my garage door to go for a cruise and noticed a puddle of coolant under my truck. Cheap radiator just springs leaks for no reason, so I just ordered a nice aluminum one, I am done messing with it.
Chevy_Stepside
Chevy_Stepside
Reg: 07-08-02
07-01-10 08:12 AM - Post#1938899
    In response to LT1BURB
Thinking about heading up on Saturday to button up the tranny and some other little stuff. Need to set timing and other little adj.
dewitte
dewitte
Loc: Virginia
Reg: 06-16-10
07-01-10 11:00 AM - Post#1938977
Started replacing the left side trailing arm. What a workout! I think I'll need a lightsaber to get the old one loose.
Woogeroo
Woogeroo
Loc: what does this part do?
Reg: 05-26-02
07-02-10 02:16 PM - Post#1939552
I taped up, prepped and spray painted the outside frame around the vent window glass on the driver side... and painted the exterior side of the vent window assembly as well.
Tomorrow, the fun part... putting it back together.
aggh.
-W
Execution time: 2.213 seconds.   Total Queries: 16   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:34 AM
