Username Post: Need a flywheel and clutch        (Topic#234492)
fiftysixbowtie
Loc: Plano, Texas
Reg: 04-10-03
01-28-10 05:15 PM - Post#1851606
My 52 216 is in the shop for a main seal replacement. My mechanic called with bad news that the flywheel is missing some teeth and the clutch is worn almost down to the rivets. So now I'm on the hunt. I found a flywheel "ring gear" with 139 teeth for standard transmission for $69.50 at The Filling Station. Part # WX-100. Are there any flywheel experts that can tell me if this is the right part?
For the clutch, they also have a 9 1/8 clutch disk. Same question. Is this the correct part? (part # FS-30)
John R
In dog years, I'm dead
56 Chevy 210 2-door,383 stroker,5-speed,9-in Ford,4 discs
51 Chevy 3100 PU
99 Tahoe 2-door
Photo albums...
Video... http://www.youtube.com/user/magnumrush
fiftysixbowtie
Loc: Plano, Texas
Reg: 04-10-03
01-28-10 05:41 PM - Post#1851633
    In response to fiftysixbowtie
Or do I need 162 teeth?
John R
51 Chevy 3100 PU
99 Tahoe 2-door
Photo albums...
49er
49er
Loc: Missouri (St. Louis area)
Reg: 12-15-06
01-28-10 06:23 PM - Post#1851659
Hi John, You need the 139 tooth flywheel and the 9 1/8 clutch will work. Good luck, John
Link to see my project-
http://www.cardomain.com/ride/3304881
2blu52
2blu52
Reg: 03-12-02
01-28-10 06:29 PM - Post#1851665
around here NAPA has the clutch.
THOMAS JEFFERSON
01-28-10 06:31 PM - Post#1851667
    In response to 2blu52
I got both clutch and pressure plate from NAPA. After I got them home I found--Made in China in tiny letters.
Loc: Hendersonville, N.C.
01-28-10 06:37 PM - Post#1851672
    In response to 49er
Before you buy a 139 tooth deal, are you using 6 or 12 volt starter?
1951 Styleline Deluxe 2 dr sedan. 1955 235" 3 speed std.
1969 Corvair 500 Coupe 28,000 miles.
70fierro
70fierro
Loc: National City, Ca
Reg: 09-20-05
01-28-10 06:49 PM - Post#1851682
    In response to bobg1951chevy
The local(to me) clutch shop carries the ring gears or can flip the old one over if the teeth look good from the back.
You should try and find somebody local to look at it to avoid any mistakes.
Or just count the teeth on your old one to be sure if you must mail order it. Cesar
fiftysixbowtie
Loc: Plano, Texas
Reg: 04-10-03
01-28-10 07:34 PM - Post#1851721
12 volt starter
John R
51 Chevy 3100 PU
99 Tahoe 2-door
Photo albums...
01-29-10 12:00 AM - Post#1851859
  • fiftysixbowtie Said:
12 volt starter
139 tooth is for 6 volt starter.
I believe the 12 volt starter needs 153 teeth, but not 100% certain on the 12 volt teeth number.
fiftysixbowtie
Loc: Plano, Texas
Reg: 04-10-03
01-29-10 03:21 PM - Post#1852297
I counted 139 teeth on the flywheel. The clutch just needs the disc. I ordered the parts from a place called Old Car Parts. They asked the price I've found elsewhere and he beat all of them by about $5. The guy also knew what he was talking about. I will have to keep his number. (800) 886-7277. Have any of you dealt with them?
John R
51 Chevy 3100 PU
99 Tahoe 2-door
Photo albums...
arnieg141
arnieg141
Loc: nj
Reg: 10-06-08
01-29-10 03:33 PM - Post#1852308
ya john i bought my complete clutch/pressure plate/truw bearing set up from them
49er
49er
Reg: 12-15-06
01-29-10 03:40 PM - Post#1852310
    In response to arnieg141
John, Arnie, Do they have a web site? Thanks, John
arnieg141
arnieg141
Loc: nj
Reg: 10-06-08
01-29-10 04:44 PM - Post#1852367
    In response to 49er
i made a mistake i got mine here the 163 dollar kit http://www.partstrain.com/store/?PN=9191&N= 0&a...
fiftysixbowtie
Loc: Plano, Texas
Reg: 04-10-03
01-29-10 06:21 PM - Post#1852438
I didn't ask them if they had a website. I found them through another supplier who didn't have what I wanted. so they gave me the number. It was interesting when he asked what prices I have found then he beat it.
John R
51 Chevy 3100 PU
99 Tahoe 2-door
Photo albums...
Execution time: 0.269 seconds.   Total Queries: 14   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:57 AM
