Username Post: How much does a torque convertor hold        (Topic#230732)
305c1500ext
Loc: Auckland,NEW ZEALAND
Reg: 10-23-06
11-30-09 03:13 PM - Post#1815257
Hi all.I am planning to change the oil and filter on my 4l60e and need to know how much does the torque convertor hold please? I know the trans pan holds 5 quarts. Many thanks Philip
1996 c1500 305 vortec.1st truck so far!350 crate motor is in....had to rebuild the engine first!!
1986 mazda 323 turbo road race car 400hp.SOLD
598 bbc in 56 chev drag car 8.62 second 1/4 mile
1965 Chev Impala sedan 283-now 327 + turbo 350
bobby9621
Loc: Midwest
Reg: 06-30-08
11-30-09 03:49 PM - Post#1815281
    In response to 305c1500ext
The whole system holds ten - eleven quarts, but regardless you want to check the level several times as you are adding, to not over fill, or under fill.
1996 Chevy Ext. Cab Z71 5.7 Liter
"You've already spent your two cents and I don't accept credit..."
305c1500ext
Reg: 10-23-06
11-30-09 03:52 PM - Post#1815286
    In response to bobby9621
Great thanks for that!
ltlvt
Loc: Wichita Falls Texas USA
Reg: 09-17-00
11-30-09 03:53 PM - Post#1815287
My question is how do you get the fluid out of the converter?
Runs like a Scalded Dog!!
305c1500ext
Reg: 10-23-06
11-30-09 04:18 PM - Post#1815298
    In response to ltlvt
Have seen on the amsoil site how to replace your fluid by disconnecting one line out from your trans while having the engine going.It pumps the old fluid out and stop when you see the new fluid come thru.
bobby9621
Loc: Midwest
Reg: 06-30-08
11-30-09 04:27 PM - Post#1815305
You can also roll your torque converter allowing the fluid to escape. If you run it out of fluid watch your temp and becareful as the heat will build quickly.
305c1500ext
Reg: 10-23-06
11-30-09 04:55 PM - Post#1815339
Thats handy to know!
transman618
transman618
Loc: Cumming,GA
Reg: 06-06-04
12-02-09 11:36 AM - Post#1816505
Drop the pan, clean it real good, change the filter, reinstall the pan and torque the pan bolts to 95" (INCH) pounds. You will refill using between 5-6 quarts. Dont worry about trying to empty the converter. Service your trans every 25-30k miles.
transman
GM MASTER TECHNICIAN
SR. TRANSMISSION BUILDER
305c1500ext
Reg: 10-23-06
12-02-09 02:01 PM - Post#1816584
    In response to transman618
I only want to empty the convertor as i am going to put Royal Purple trans fluid.Others i know have had very good results with it in auto`s.
Philip
12-02-09 02:50 PM - Post#1816614
IMO it's almost impossible to get all of the fluid out of the converter unless you're a converter reman operation and you're splitting them open. The only way you can get most of it out is to remove it from the trans, and that won't get all of it.
305c1500ext
Reg: 10-23-06
12-02-09 03:40 PM - Post#1816632
    In response to someotherguy
Will just try replace what we can! It`s got to be better than whats in there now!
Philip
elcamino
elcamino
Reg: 03-30-00
12-03-09 07:56 AM - Post#1816976
The only way to empty the converter short of drilling a hole in it is to pump the fluid out the cooler line using the engine (running in park) while adding new fluid till you have replaced all the fluid. Be prepared to waste some fluid.
2017 GMC Sierra Denali Ultimate 6.2L(420hp)/8-sp
2016 Polaris RZR 900 EPS
Crusty1
Reg: 01-07-04
12-04-09 09:29 AM - Post#1817658
    In response to elcamino
I bought a replacement cooler line at the local Napa for $8. I cut the length in half. Then I bought some clear PVC tubing and slipped it on the end of the cut alum tubing. I screw the treaded end at the top of the radiator after disconnecting the tranny cooler in line. With the clear PVC tubing I can flush the whole system in less than 20 minutes with a minimum of ATF waste. Best $8 bucks ever spent!
Execution time: 0.685 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:03 AM
