"Win $100" Become a Supporting Member Click here find out how! "Win $100"
SSImpala65 (2)
mlc48 (3)tri5ss (4)monty56 (7)
1960 Sedan Delivery (3)
Art Morrison.com
Edlebrock July SpecialsMax Chevy.com
Hellwig Products IncClassic ChevyAmerican Auto Wire Performance Rod & Custom
The Car Guy GarageNewGMParts
Ciadella InteriorsGreg's OnlineShowwheelsusa.com
Impala Bob'sBob's Chevy TrucksBob's Chevelle PartsBob's Classic Chevy
"CT and its community has helped me so much in just the past few days as a member its unbelievable."
Join the ChevyTalk Mailing List Annual CT West Coast Get Together
Check out the post in SW Forum
Cruisin For a Cure 2010 (9/25)
Username Post: 57 truck radiator        (Topic#229559)
Jalapeno
Jalapeno
Loc: The Republic of Texas
Reg: 04-30-00
11-12-09 12:51 PM - Post#1804577
Still working on the 57 Cameo. Most of the wiring is done, now on to the engine bay for some detailing, starting with the radiator.
The radiator currently in the truck is date coded D55 (April 1955) and stamped with the part number 3133343. Because of the date it's definitely not a 57 radiator, and well worn. So I'm on the hunt for a correct radiator. Which brings me to my question.
Does anyone know what a correct part number would be, and is there any difference between a 6 cylinder and V8 radiator? Thanks for any and all help.
Jalapeno
bobschevytrucks.com
bobschevytrucks.com
Jalapeno
Jalapeno
Reg: 04-30-00
11-13-09 06:46 PM - Post#1805348
    In response to Jalapeno
According to the reprinted 55-59 assembly manual, which is really a 55 manual, this radiator is correct for a 55. But I'm not sure if that number is also correct for 57, so I'm not even able to start a search for a correct radiator. The available aftermarket radiators I've seen are just replacements and do not look like the original radiators, so that's not an option.
Anybody out there with a stock 57, please take a few minutes to look at the numbers on your radiator. Even if you're not sure if it's OEM, please take a look.
I have searched every parts book and original literature I have to find published data on this number, but no luck.
Thanks for any and all help provided.
Jalapeno
Edited by Jalapeno on 11-13-09 06:47 PM. Reason for edit: No reason given.
Don57
Don57
Loc: Hooterville
Reg: 04-28-00
11-14-09 07:11 AM - Post#1805517
I'll check mine today. I think it's original but I guess the numbers will tell. Where are the numbers?
Happy Birthday to all the 1960 cars and trucks that are 50 years old this year. Get your car a present!
Jalapeno
Jalapeno
Reg: 04-30-00
11-14-09 07:34 AM - Post#1805523
    In response to Don57
Thanks Don.
When you open the hood, the part number will be on the top tank at the right, on the front face. They are big raised numbers about 3/8" tall, over an inch long, real easy to see. The date code is on the left.
Jalapeno
Don57
Don57
Loc: Hooterville
Reg: 04-28-00
11-14-09 01:58 PM - Post#1805669
Here's what I found:
Driver side facing front says Harrison and below that is 3133343. Passenger side says R-11 and below that is G 55.
Those same markings are on the other side of the tank, facing the engine, BUT (note BIG BUT), there's a thin metal tag spotwelded over the Harrison 3133343. That tag reads 55G and below that is 3135953.
I'm pretty sure this is the original radiator. I'm the 3rd owner of the truck so I can't be positive.
BTW, this truck was originally a 6 cylinder and standard transmission.
Jalapeno
Jalapeno
Reg: 04-30-00
11-14-09 02:25 PM - Post#1805686
Thanks Don.
The date code is similar to my radiator, yours is dated July 1955, so I presume that's not the original radiator. I have no idea what the thin tag welded onto the back side signifies.
Thanks again.
Jalapeno
Don57
Don57
Loc: Hooterville
Reg: 04-28-00
11-14-09 02:34 PM - Post#1805691
Is it possble that they built several years worth of radiators in '55 and just used them in the following years until the stock was depleted?
Jalapeno
Jalapeno
Reg: 04-30-00
11-14-09 08:42 PM - Post#1805911
Short answer: No. Harrison radiator could not possibly make that many radiators all at once. Many many parts and components were date coded. The date coding was one way to keep track of production problems when/if they cropped up.
Jalapeno
Jalapeno
Jalapeno
Reg: 04-30-00
11-14-09 08:45 PM - Post#1805915
I just received some info on a radiator dated E57 (May 1957) with a part number 3135894. I will cross reference this number tomorrow.
Jalapeno
Red58Cameo
Loc: Oklahoma
Reg: 02-22-09
11-16-09 08:39 AM - Post#1806712
What about M 57 ?
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
11-16-09 08:43 PM - Post#1807192
    In response to Red58Cameo
The 1959 parts book shows 3139816 for 1955-57 (1/2-1 ton)(2 " core)
Shows 3135894 was replaced by the above number 11-1-58
I would bet that the 3133343 was replaced by the 3135894 in about 1956-57.
Will get at my 1957 book tomorrow and look farther.
The number on the top tanp is not always the part number of the complete radiator. Its more or less the number of the tank and some small modifyication could have been made to the radiator assembly and the stamped tag was the actual part number for production.
Jalapeno
Jalapeno
Reg: 04-30-00
11-17-09 08:34 AM - Post#1807379
    In response to Gene_Schneider
Thanks Gene.
In my 57 Parts and Accessories book (dated March 1 1957) under 1.219, Core - Tank Assembly., Radiator:
55-57 COMM., (2nd Ser.) (exc D-D, hvy. duty)
(stamped 3135642 - 2" core)
3135642
So this does not corroborate the number I posted above.
Jalapeno
Jalapeno
Jalapeno
Reg: 04-30-00
11-17-09 08:37 AM - Post#1807380
  • Red58Cameo Said:
What about M 57 ?
Red, that would be a Dec 57 date code, making it a 1958 model radiator. Hope this helps.
Jalapeno
Red58Cameo
Loc: Oklahoma
Reg: 02-22-09
11-17-09 10:01 AM - Post#1807437
I was prepared to give it to you if it was what you were looking for.It has just been sitting in my shed collecting dust.
Edited by Red58Cameo on 11-17-09 10:03 AM. Reason for edit: No reason given.
Jalapeno
Jalapeno
Reg: 04-30-00
11-17-09 01:41 PM - Post#1807540
Thanks for the offer, Red58Cameo. I too wish the date would work, I am interested in finding one for the 57 Cameo that is dated within that model year.
While we're on the subject, what is the part number stamped on the right? Maybe you can add a little more data to our discussion.
Again, thanks for the help, and for the PT, I really appreciate it.
Jalapeno
Red58Cameo
Loc: Oklahoma
Reg: 02-22-09
11-17-09 02:19 PM - Post#1807557
The number on the radiator is 335642 with M57. On the subject of the horns, do they have specific numbers to identify them? I may have them.
Gene_Schneider
Loc: Wisconsin..USA
Reg: 09-27-02
11-17-09 03:37 PM - Post#1807613
From 1957 parts book-
part #31333343 replaced by 3135642 7-1-56 ......so the 3135642 would have been the rad used in 1957, .....from 1957 parts bok. Says number stamped on tank.
Jalapeno
Jalapeno
Reg: 04-30-00
11-17-09 04:16 PM - Post#1807636
Red58Cameo, the radiator number jibes with the numbers posted her. The LH horn might have 327 stamped on the underside of the collar, the RH might have 328.
Gene, so I guess we agree with the 3135642 is correct.
Thanks again to all who helped.
Jalapeno
bobschevytrucks.com
bobschevytrucks.com
Execution time: 0.051 seconds.   Total Queries: 10   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:34 AM
