"I was bad and let my membership expire. The check is in the mail! This board is the best resource on the net for Chevy lovers. Thanks to all the users for the "expert" advice!"
Join the ChevyTalk Mailing List Annual CT West Coast Get Together
Check out the post in SW Forum
Cruisin For a Cure 2010 (9/25)
Username Post: do air bag levellers if too high affect pinion angles        (Topic#229208)
denny4
denny4
Loc: MB.,Can.
Reg: 05-27-06
11-07-09 03:29 PM - Post#1801320
Just wondering if running around with the air too high will affect pinion angles? Could this be harmful.
"cause my friends truck seem higher than normal and has had the rear end rebuilt twice now and haul or tow anything heavy.Only 40,000km since last repair,its a'97 Z71 K1500.
'95 K1500 5.7 GMC Siera SLE xt cab,Flowtech headers new y-pipe,cat,2 1/2 exhaust w/magnaflow muffler,homeade dual snorkle airbreather w/dual heat tubes.
61-Flat Top
Site Sponsor (RideTech.com)
Reg: 10-02-03
11-09-09 06:35 AM - Post#1802202
    In response to denny4
That is going to be dependent on what type of rear suspension he is running. In short, if the pinion angle is out it can destroy the rear end however with most modern accecptable rear suspensions... you can have a couple inches of travel adjustment without a notable change in pinion angle.
denny4
denny4
Loc: MB.,Can.
Reg: 05-27-06
11-10-09 06:07 AM - Post#1802882
    In response to 61-Flat Top
Thats what I thought myself and another tech I talked to said the same thing. So its safe to assume we can rule out the airbag causing anything.
Thanks for the reply.
D.
61-Flat Top
Reg: 10-02-03
11-12-09 03:54 PM - Post#1804670
you got it and your welcome!
Execution time: 0.044 seconds.   Total Queries: 8   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:01 AM
