"Win $100" Become a Supporting Member Click here find out how! "Win $100"
SSImpala65 (2)Woogeroo (6)gmgary (6)
mlc48 (3)tri5ss (4)monty56 (7)
1960 Sedan Delivery (3)
Nailheadv8 (5)
Art Morrison.com
Edlebrock July SpecialsMax Chevy.com
Hellwig Products IncClassic ChevyAmerican Auto Wire Performance Rod & Custom
The Car Guy GarageNewGMParts
Ciadella InteriorsGreg's OnlineShowwheelsusa.com
Impala Bob'sBob's Chevy TrucksBob's Chevelle PartsBob's Classic Chevy
"I have been able to complete a rebuild on an American car here in Australia thanks to this site."
Join the ChevyTalk Mailing List Annual CT West Coast Get Together
Check out the post in SW Forum
Cruisin For a Cure 2010 (9/25)
 Page 4 of 4 « First<1234
Username Post: 210 Wagon Progress pictures (a quarter will do)        (Topic#228819)
MPandC
MPandC
Loc: Leonardtown, MD
Reg: 03-09-06
07-05-10 01:01 PM - Post#1940731
    In response to jeffs55
Acutally Jeff, that was Chris goofing around on the dry erase board. Good help is hard to find...
Thanks for the comments guys. Been finishing up the front fenders so I can fold that last flange on the door skin. I guess when you move fenders to get them out of the way you forget what is left to do on them. Sometimes it's better to trip over things I guess.
In addition to fixing the rust on top
I had this to complete....
Once done with that I saw a nice glancing dent that someone had left. I'm surprised (and relieved) that the wheel opening was not invovled in this.
Time for some off-dolly work using the slapper. It will spread out the blows a bit to leave less marks than the body hammer would.
Some 80 grit does a nice job of showing the highs/lows.... Worked it back and forth until most of the damage had been removed.
Some high build should take care of the rest... The bolt hole for the turn signal had grown due to rust, but we'll tackle that next time and then move on to the other fender...
Robert http://photobucket.com/albums/y167/rmccartney/
jeffs55
jeffs55
Loc: Millington, Tennessee
Reg: 01-05-06
07-05-10 01:28 PM - Post#1940741
    In response to MPandC
Great work Robert.
Did you take anytime off for the 4th?
At least a hamburger or hot dog?
Jeff
55 Handyman
66 F100 project
32 3 Window Coupe project
Nuthin' to it but to do it.
My Pics
MPandC
MPandC
Reg: 03-09-06
07-18-10 05:37 PM - Post#1947340
Just a little bit, Jeff. Maybe it was on the 5th, though....
Just to finish up the passenger fender, needed to fix the upper hole for the turn signal. Looks like another spot that is a dirt/moisture/rust collector.
Need to fit the light to get a more accurate location for the new hole.
Cut a replacement out of 18 ga, and put some arc in it using the Lancaster shrinker and stretcher.
Welded, dressed, hole drilled.......
sedandelivery55
sedandelivery55
Loc: Moore, OK
Reg: 02-20-02
07-18-10 08:50 PM - Post#1947446
Excellent job as usual, Robert.
Lee
http://www.picturetrail.com
55 Chevy Sedan Delivery
400/TH400
jeffs55
jeffs55
Reg: 01-05-06
07-19-10 04:32 AM - Post#1947513
    In response to sedandelivery55
Perfect!
What's that circle on the headlight opening?
Well, a circle indicates an issue, obviously.
So, how are you going to address that?
Is it small enough to just tack it with the wire?
Or am I jumping the gun on the next installment?
Jeff
55 Handyman
66 F100 project
My Pics
MPandC
MPandC
Reg: 03-09-06
07-25-10 05:47 PM - Post#1950661
Dang Jeff, I can't sneak anything by...
The circled area above was a low spot, and I decided to fill it with weld and grind it flush..
.....and just when you think you're done, you find a thin spot in the metal from all the welding and grinding. So another replacement patch was installed.....
Now to show what the other fender has in store for repairs:
We'll start with the inner grill opening rust issue by drilling out the spot welds...
Original, pattern, and new....
Now this fancy hammer I used is sometimes hard to find in the store, but they are on ebay on occasion. 2" dia steel used as an anvil to form the sweep
trimmed and test fit......
Now for the front piece.....
....and the official template....
The start of the replacement....
Now in this next picture I used a mower blade that I'd thrown under the welding table about three years ago as an anvil, so you never know what will come in handy. (....but don't use me as an excuse for your hoarding issues, I'll deny everything... ...)
And for a test fit...and a comparison.....
And that will be all for tonight. I'll break out the grille stainless parts to check the contour for any needed tweaking next time.....
jeffs55
jeffs55
Reg: 01-05-06
07-26-10 09:00 AM - Post#1950917
Sorry Robert, I find myself getting ahead of the teacher sometimes.
I like that custom hammer. I like the holes you put in it to reduce wind drag while hammering.
Jeff
55 Handyman
66 F100 project
My Pics
MPandC
MPandC
Reg: 03-09-06
07-28-10 07:20 PM - Post#1952299
I hope the guys from Harbor Frieght don't see it, they'll just flood the market with 2 x 4 scraps as cheap imitation hammers. Then what will I do with mine?
Had some time this evening so I worked on the fender a bit more. Cut out the rust to make room for trimming the patch....
Folded the inner flange, which required quite a bit of stretching to maintain the curve.....
....and we'll get this tacked in another night....
ljfen
ljfen
Loc: Michigan
Reg: 11-04-04
07-29-10 10:22 AM - Post#1952619
Robert, the fenders I'm dealing with have heavy grind marks, dents and someones attempt at pounding out the deep dents so the metal is stretched. Do you ever have a job that is so bad that you get it close then use building primer or a skimmer of mud to straighten it out fully? I spent hours last nite sanding, filing and dollying the dents in a 2 ft area. They don't look even close to your works of art but its better than before.
Larry
It is when a people forget God that tyrants forge their chains. A vitiated state of morals, a corrupted public conscience, is incompatible with freedom.
Patrick Henry
MPandC
MPandC
Reg: 03-09-06
07-29-10 05:28 PM - Post#1952793
    In response to ljfen
Larry, the stuff you're looking at here is far from perfect, I think the camera is kind to me. I wouldn't see any problem attacking the fenders as you suggest, they should be better than they were so you at least improved what you had..
jeffs55
jeffs55
Reg: 01-05-06
07-29-10 06:32 PM - Post#1952835
Isn't the camera a fickle thing.
Some things look great that maybe are not so much.
(like my car... )
Or it will make your finely polished aluminum panel, that looks perfect by eye, look like it was rubbed with a pot scrubber.
Jeff
55 Handyman
66 F100 project
My Pics
MPandC
MPandC
Reg: 03-09-06
07-31-10 10:32 AM - Post#1953442
Got some welding done this morning. With all the metal being forced into the "valley" when forming the patch, the outer flange had a tendency to bulge outwards. Used the shrinking tip on the dent puller to help take care of that, as well as better form the radius.
...comparing to opposite fender.....
Inner grille opening......
Welding outside seam
Welds dressed.....
That gets it real close, and fresh metal to last a few more years. Now only 3 more spots to go on this fender.....
07-31-10 11:11 AM - Post#1953457
Looking good Robert...as always.
MPandC
MPandC
Reg: 03-09-06
07-31-10 06:44 PM - Post#1953642
    In response to wagonman100
Thanks Jay. Worked on it most of the day trying to get a grunch of the fender work knocked out. One last bit done for today, trying to get the new eyebrow ready to go on. Time to open it up......
The treasure map taken from the original....
....and after much fitting, trimming, and repeating.....
...And that will be all for a couple days....time to tend to mowing duties tomorrow...
Pistol
Pistol
Loc: Terryville, Ct.
Reg: 11-11-02
08-01-10 06:47 AM - Post#1953796
Nice work Robert, really nice
I put on door skins on my car and I had to refold and straighted the bottom line, I unfolded the whole bottom line and used 2 heavy pieces of angle iron clamped to each side of the skin and made the new line, worked out well, a little time consuming but well worth it.
A lot of the work looks very familiar to me
keep up the good work, love all the pics
Pete
Awl speeling misteaks r myn
57 BelAir 2DRHT My-Pics
jeffs55
jeffs55
Reg: 01-05-06
08-01-10 11:33 AM - Post#1953906
    In response to Pistol
Great jobs, both of you guys.
Jeff
55 Handyman
66 F100 project
My Pics
Pack_Rat
Pack_Rat
Loc: Vancouver, BC, Canada
Reg: 05-22-06
08-01-10 11:37 AM - Post#1953910
Hey Pete, how about doing your own thread with a bunch more photos and detail on the door repair. I have a re-skin coming up and I'd love to see your whole process.
Robert, I love your posts. At one point I was feeling sorry for you, not having better fenders to work with. I'm begining to think you could build one from scratch if you had to.
Ernie
MPandC
MPandC
Reg: 03-09-06
08-02-10 04:39 AM - Post#1954257
    In response to Pack_Rat
Thanks for the comments guys..
Pete, nice work there......and thanks for the pictorial reminder....I need to put drain holes in the bottoms of the doors still.
MPandC
MPandC
Reg: 03-09-06
08-20-10 10:16 AM - Post#1963962
Well I've been wanting to build something for the shop, and happened to stop by a local machine shop yesterday. He gave me a drop cut that had been sitting outside, which was all the prompting I needed. A stop at another machine shop who had a similar piece and that should be enough to complete the puzzle.
4 x 6 x 1/4 wall, and if my highly technical chalk calculations are correct, it should have about a 29" throat with 2" of steel left over.
The wheel and anvil kit should be here in a couple weeks, so this is all for now. Plus, I'd like to make some "official" AutoCAD drawings up to better test the measurements on paper...Cheaper cuts that way
MikeB
MikeB
Loc: Plano, TX
Reg: 08-28-03
08-20-10 11:52 AM - Post#1964004
  • MP&C Said:
Aligned as we went, dot welded, planished, ground down the weld, repeat.
Robert -- Please explain the planishing procedure.
Thanks.
Real Hot Rods have a Clutch!
1955 210 sedan, solid lifter 327, Brodix IK180 heads, Muncie M20, Wilwood front brakes
1969 C-10 LWB pickup
My car pictures
jeffs55
jeffs55
Reg: 01-05-06
08-20-10 01:19 PM - Post#1964038
    In response to MikeB
I know you asked Robert to explain, but let me give it a try.
Planishing
Tapping on a panel surface, backed up with a dolly using a hammer or "slapper" to smooth out irregularities in the surface especially around welds. Generally, it's a bit of a sliding or glancing blow. Not really straight down pounding.
That would stretch the metal too much.
It can also be used to add shape to a pannel.
Check this video out.
At about 3:43 they demonstrate planishing.
metal working
Actually there's several shots of planishing through out this video.
Hope this helps.
Jeff
55 Handyman
66 F100 project
My Pics
08-20-10 02:20 PM - Post#1964074
That's a great video Jeff. Thanks for posting that.
MPandC
MPandC
Reg: 03-09-06
08-20-10 05:14 PM - Post#1964160
Jeff, I have David Gardiner's DVD and I can say it is well worth the money. He does an excellent job of showing how to do something without fancy tools, so well worth the purchase price for anyone doing sheetmetal repairs. And thanks for taking up the slack for me...
Mike, I have a thread I had posted in the P&B forum a couple weeks ago that I think will help...
http://www.chevytalk.org/fusionbb/showtopic.php?tid/245105/
MPandC
MPandC
Reg: 03-09-06
08-22-10 04:54 PM - Post#1965144
Finishing up the Driver's fender....
And my nephew Chris came over today and started to re-assemble the front end for test fitment as I finished up the welds on the drivers fender.
Not too shabby. We do have some planishing to do on the patches of the drivers fender to fix some gap inconsistencies...... Until next time..
jeffs55
jeffs55
Reg: 01-05-06
08-22-10 05:57 PM - Post#1965186
Looking whole and complete again.
Good work!
Jeff
55 Handyman
66 F100 project
My Pics
Pistol
Pistol
Reg: 11-11-02
08-23-10 06:59 AM - Post#1965460
Pete
cnbell
cnbell
Reg: 04-14-04
08-23-10 04:23 PM - Post#1965711
Very nice, the gaps look great on the passenger side...
Execution time: 0.069 seconds.   Total Queries: 8   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:52 PM
