BBC-454
Loc: Edmonton, Alberta
Reg: 05-11-03
10-31-09 05:01 PM - Post#1797448
I finally got working on my big block project, and found the blocks casting number to be 361959, and it has hi per pass cast into the back. From what I found on a search it is a 78-87 block, and can be either two bolt or four bolt.
I didn't have long enough bolts so I couldn't get it on the stand today, hopefully tomorrow.
What does the hi perf pass mean for the block? 4 bolt?
It has the peanut port heads (346236) so those wont be going back on!
Josh R.L.
GMC/Cadillac dealer technician
1961 Apache 10 panel/2002 Chevy LS Stepside 4x4
fritz1990
Loc: Kansas
Reg: 02-16-03
10-31-09 05:54 PM - Post#1797476
In response to BBC-454
Most all if not all BBC have "High Perf" cast into them. My 454 block that I used for my 496 had it too and is a 2 bolt main. I have tore apart many different 396, 402, 454 blocks and I don't remember seeing one that didn't.
Regards, Jeff
1998 K1500 6.5 Coal burner
1965 C10 with 498 BBC AFR Heads
1964 C10 Ran 348W for 6 years, now SBC.
Corvettes owned: '74 L48 '77 L82 '78 L82 Silver Anniversary
Don't have a nervous come together!
http://picasaweb.google.com/fritz199090
Edited by fritz1990 on 10-31-09 05:55 PM. Reason for edit: No reason given.
BBC-454
Reg: 05-11-03
10-31-09 06:18 PM - Post#1797485
In response to fritz1990
Yeah that's what I have found out also. But there is still a chance it is 4 bolt! Have to pull the pan tomorrow and find out.
How common are OE steel cranks in 454's?
Josh R.L.
fritz1990
Loc: Kansas
Reg: 02-16-03
10-31-09 06:49 PM - Post#1797503
My '73 454 block had a steel crank. Only one I have ever seen other than the high horsepower blocks. It was in a '73 1/2 ton pu.
Look at the side of the block where the oil filter pad is, if there are two 1/2" NPT plugs above it, it is a 4 bolt block.
One of my other 454 blocks is a 959 too, cast crank and 2 bolt. Came out of a 78 1 ton pu.
I have some more 454 blocks all 2 bolts and cast cranks.
Regards, Jeff
Edited by fritz1990 on 10-31-09 06:51 PM. Reason for edit: No reason given.
BBC-454
Reg: 05-11-03
10-31-09 08:35 PM - Post#1797554
Thanks Jeff
Josh R.L.
BBC-454
Reg: 05-11-03
11-01-09 11:18 PM - Post#1798163
Well no luck, it is a 2 bolt, cast crank. Oh well. Should I be ok to run a stroker crank and dart IE 308's if I use main cap studs?
Josh R.L.
fritz1990
Loc: Kansas
Reg: 02-16-03
11-02-09 04:57 PM - Post#1798518
Don't know how much RPM's or power you are looking to build but I run a 2 bolt studded block. Spin 'er to 6500 everytime I'm in it. Unless you already have the Dart Iron eagles the 781's or 049's would do the same with bigger valves and some bowl blending. My
Regards, Jeff
fritz1990
Loc: Kansas
Reg: 02-16-03
11-02-09 07:02 PM - Post#1798628
If you plan on using studs you should also plan on a line hone too. Same if you use ARP bolts instead.
Regards, Jeff
BBC-454
Reg: 05-11-03
11-02-09 07:08 PM - Post#1798631
No I don't have the heads yet, and I know where there a pair of 781's for 400 bucks.
If I do a line hone, will that affect how the bearings install?
Josh R.L.
fritz1990
Loc: Kansas
Reg: 02-16-03
11-02-09 08:03 PM - Post#1798685
Do the 781's already have the larger 2.19-1.88 valves in them? If not that is pretty steep for a set compared to where I live. Might do some research on the Dart Iron Eagles, I don't know what they cost or what you are doing with your combo but there are probably better heads in that price range.
If you use studs it will generate more clamping force and make the main bearing bores out of round. Once you line hone it with the studs installed the bearing bores will become round again, to put it simply.
If you don't have it lined honed with the studs more than likely the crank will bind up and not turn or turn hard.
Regards, Jeff
Edited by fritz1990 on 11-02-09 08:04 PM. Reason for edit: No reason given.
