Username Post: 305 Vortec vs. 305 HO heads        (Topic#226217)
Reg: 06-20-01
09-19-09 07:15 PM - Post#1774863
Quick question, how do the 305 Vortec heads compare with the 305 HO '416 castings? The shortblock would be a 9.0 to 1 305 with the 350 Ramjet Hyd. Roller cam in a light vehicle with a 200-4R and 3.42 gears.
Loc: Bedford, Texas, USA
Reg: 11-13-02
09-19-09 09:13 PM - Post#1774916
    In response to Glenn_McAtee
The 059 Vortec castings will BLOW the 416s out of the water in every possible manner. I would target a little more compression with that setup as 9.5 was factory for the L69. Make sure the pistons are no more tha .025" in the hole and if they are, use the .016" compressed rubber embossed steel shim headgasket.
Edited by 1983G20Van on 09-19-09 09:14 PM. Reason for edit: No reason given.
Reg: 06-20-01
09-20-09 06:11 AM - Post#1775018
    In response to 1983G20Van
Execution time: 0.418 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:28 PM
