Username Post: I need to wire up the electric choke, where???        (Topic#226098)
Black57
Loc: Milwaukee, Wi.
Reg: 02-08-04
09-17-09 09:12 PM - Post#1773894
I have a Demon carb with electric choke... Since I put the carb on, I have had the electric choke wired directly to the battery and I manually connect/disconnect it.
Far from ideal, but if someone tries to steel the car they won't get far because the choke isn't openning but then again I have had a dead battery because I forgot to disconnect the thing.
Where is a ideal place to wire the choke too??
burbdude
Reg: 04-08-06
09-17-09 11:29 PM - Post#1773933
    In response to Black57
tap off the + coil wire as its switched by the key.
http://community.webshots.com/user/55dude
09-18-09 04:19 AM - Post#1773961
    In response to burbdude
Any 12 volt source that is on when the key is on and off when the key is off.
57TOMMY
57TOMMY
Loc: Bay Area , Calif
Reg: 08-19-03
09-18-09 06:01 AM - Post#1774007
    In response to wagonman100
Run the wire to your fuse box & test it to make sure you get 12 volts when the key is on or it will not work correctly. If you run it to your coil you may not be getting 12 volts.
Tommy
Stand up for what is right ,even if you stand alone.
57 Drop Top
57 Drop Top
Loc: Pearl,MS
Reg: 09-22-04
09-18-09 08:40 AM - Post#1774085
Directions that come with all electric chokes say to use any "switched" 12 volt source except the coil.
The fuse panel is by far the best choice. Just make sure it only has 12 volts in the ignition on position.
Paul 57 Convertible 502/700r4,68 Camaro 396/375 4-speed
HAL_396
HAL_396
Loc: Austin, TX
Reg: 11-16-06
09-18-09 09:32 AM - Post#1774100
    In response to 57 Drop Top
I just put a new carb on my 66 and the instructions say if it is not a switched 12V source you will burn up the choke coil due to no air flow around it. Also says not to use coil +.
1955 Chevy Custom
1966 Biscayne
1966 Caprice Drag Car Inwork
1966 Caprice parts car
56driver
Loc: Charlotte, NC
Reg: 02-26-06
09-18-09 10:18 AM - Post#1774125
    In response to HAL_396
I used the "upstream" connection of the ballast resistor.
Jonathan Hines
Charlotte, NC
56 BA 4DR sedan undergoing rebuild
cnbell
cnbell
Reg: 04-14-04
09-18-09 11:25 AM - Post#1774149
    In response to 56driver
A fused source from the fuse panel is the best location.
52chevybob
Reg: 05-27-08
09-18-09 02:04 PM - Post#1774203
    In response to cnbell
Use the power side of the ign. resisor or the power terminal of the HEI. Short wire and they are both switched 12V lines that aren't on in the ACC position.
Old_Longboarder
Deceased Member RIP Art
Old_Longboarder
09-18-09 03:55 PM - Post#1774234
    In response to 52chevybob
I agree with the feed side of the ballast resistor, if you're still using points and condensor. If not, points..., + side of the ignition coil.
Home.., is where dog hair sticks to everything but the dog.
elvis
Loc: Ontario
Reg: 11-10-05
09-19-09 01:15 AM - Post#1774448
Do you have an American Autowire kit installed?
If so, there is an accessory harness that you can run a wire directly into and connect to an ignition source.
Pouring money between the wheels.
Black57
Loc: Milwaukee, Wi.
Reg: 02-08-04
09-19-09 05:34 PM - Post#1774805
    In response to elvis
Stock wiring...
tjn.
Loc: louisville, kentucky usa
Reg: 02-16-05
09-19-09 05:45 PM - Post#1774811
Connect it to a source that is hot with the key on, ONLY. TJN
09-19-09 07:22 PM - Post#1774868
You may have a couple of empty fuse holders that are switched power next to the radio fuse. There ment for accessories like emergency brake warning light, spot light and power antena.
Link to fuse block.
72novaproject
72novaproject
Loc: D/FW Texas
Reg: 02-18-03
09-20-09 07:37 AM - Post#1775061
Ideally you don’t want the choke to get power until the moment the engine starts. Otherwise, if you turn on the key without starting the engine the choke will begin to heat and may open too far for a reliable start. The switched 12V can be run through an oil pressure switch to accomplish this. I know that’s kind of splitting hairs but I thought I would throw it in anyway.
Steve
To each problem exists a solution...now think.
The ZD Nova Page
Brain55
Brain55
Loc: Brentwood, CA
Reg: 07-23-02
09-20-09 08:59 AM - Post#1775101
    In response to 72novaproject
I used a relay for my electric choke and triggered it off of the alternator. It accomplished the same thing as triggering off the oil pressure switch.
Brian
'55 210 2-door sedan
355 SBC, vortec heads (364HP, 377ft/lbs @ wheels), M-20, 3.70 gears
Crew chief of the Pyromaniac jet dragster
www.allmobilerepair.com
rod
Loc: kingman,az
Reg: 04-29-00
09-20-09 04:41 PM - Post#1775312
    In response to Brain55
i have a question about the electric choke.
does the choke continue to use power once it is fully open?
most of the year i do not need a choke [it was 105 here friday-don't need a choke then!!!!] so i would not need power then. however there are winter days in the 20's, when a choke would be nice.
thanks rod
Black57
Loc: Milwaukee, Wi.
Reg: 02-08-04
09-20-09 05:51 PM - Post#1775345
Brian
What does the wiring schematic look like for that??
aawtech
Loc: Bellmawr, NJ
Reg: 09-11-06
09-21-09 06:26 AM - Post#1775561
One thing that everyone has missed here is that it MUST be a fused circuit. Especially with stock wiring! Tapping off of the hot or high tension side of the ballast resistor is fine, however, you must install an inline fuse as the ignition is completely unfused. Electric chokes are somewhat subject to heating up and shorting out. If you do that on an unfused circuit, you dead short EVERYTHING on that circuit and seeing that you are using stock wiring (which has a PVC coating as opposed to GXL), you will have a serious case of "instant napalm" followed by a fire.
Donny
Brain55
Brain55
Loc: Brentwood, CA
Reg: 07-23-02
09-21-09 06:49 AM - Post#1775570
  • Black57 Said:
Brian
You run a fused 12V power constant power wire to #30 terminal on the relay. Run the choke wire to the ouput of the relay. Then a trigger ground on the relay to ground. And then tee into the wire off of the alternator that goes to the alt light on the dash to the trigger terminal on the relay.
Brian
ALS57
ALS57
Loc: LONDON-UK
Reg: 08-29-04
09-28-09 09:29 AM - Post#1779627
    In response to aawtech
Donny
Donny
I'll be fitting an AAW kit in my 57 so where do you recommend wiring the choke on your kit? (if as elvis says above, does it need to be fused as well?)
Al
57 Bel Air 2 Door Hardtop (being restored)
07 Dodge Magnum R/T
Execution time: 1.393 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:11 PM
