LMC Truck
Username Post: 2003 Suburban oil pressure sending unit location        (Topic#225273)
plow509
Reg: 02-29-08
09-05-09 01:10 PM - Post#1766939
Can anyone tell me where the oil pressure sending unit for a 2003 Suburban is located? 5.3 L engine.
LMC Trucks
black95jimmy
black95jimmy
Loc: Venice, FL
Reg: 01-05-02
09-05-09 04:58 PM - Post#1767018
    In response to plow509
Back of the Intake Manifold, see brass adapter in photo.
82 Monte Carlo SC, 355 w/Vortec heads, roller rockers, 670 Street Avenger, TRUE DUALS.
2000 Sub.5.3L 40 Gallons of gas @ $2.24/gal. bla bla bla.
plow509
Reg: 02-29-08
09-06-09 06:53 AM - Post#1767165
    In response to black95jimmy
I need to check the oil pressure with a manual gauge. Just hook it up and thats it? I am assuming it will be setting of a warning chime at least. Am I correct? Thanks for the pics also.
black95jimmy
black95jimmy
Loc: Venice, FL
Reg: 01-05-02
09-06-09 08:34 AM - Post#1767195
Better picture.
With all the junk in the way.
mvillani
Reg: 05-01-12
05-01-12 08:55 AM - Post#2221120
Hello all. I just replaced the oil pressure sensor on my wife's 2006 Yukon (5.3 engine). I was able to replace with only removing the plastic intake cover and the air intake (from air cleaner to throttle body). This required loosening three 5/16 screws (one on intake cover and two clamps on air intake) and four screws (air cleaner cover). These were removed to ensure they weren't cracked as I laid across engine to reach back of engine on the drivers side (right side) to remove the sensor. Location is directly under firewall before back of engine meets the transmission. I used a 3/4" drive, two 6" 3/4" extensions, ¾” swivel, and a Autozone Oil pressure sensor socket #25254 to remove the sensor. I will try and add pictures for location and to show what I removed. Took 15min max. Hopefully this will help!
Pictures as promised:
Plastic intake cover removed (one 5/16 bolt):
Air intake (from air cleaner to throttle body - two 5/16 clamp screws and 4 air cleaner screws:
Oil sensor socket from Autozone:
Driver, extensions, swivel, and socket:
Location of sensor when laying on top of engine towards windshield:
Another view:
LMC Trucks
Execution time: 0.345 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:47 PM
