Username Post: 4L60E SHIFTS HARD FROM 1ST TO 2ND?        (Topic#220829)
jkarastury
Reg: 06-29-09
07-05-09 05:57 PM - Post#1729698
can anyone tell how to fix my 4L60E from shifting hard from 1st to 2nd?
transman618
transman618
Loc: Cumming,GA
Reg: 06-06-04
07-06-09 12:00 AM - Post#1729836
    In response to jkarastury
What year 4L60E?????
transman
GM MASTER TECHNICIAN
SR. TRANSMISSION BUILDER
rodram
Loc: Saskatoon, CANADA
Reg: 04-14-09
07-06-09 11:54 AM - Post#1730054
    In response to transman618
my 97 C2500 5.7LVortec with 4L60E did that one day about a dozen times after a highway drive on a hot day... when everything cooled down there was no problem..... except that a week later I lost the transmission on the highway while pulling my travel trailer.....
.. the 1-2 shift issue is likely caused by a sticky shift sensor
.. on the other had it could be an early sign of impending major trouble
jkarastury
Reg: 06-29-09
07-06-09 03:07 PM - Post#1730160
    In response to rodram
YEAR 1993
transman618
transman618
Loc: Cumming,GA
Reg: 06-06-04
07-06-09 11:36 PM - Post#1730459
  • jkarastury Said:
YEAR 1993
Several things would cause harsh shifting in the 4L60E.
I would, scan the computer first to see if there are any transmission issues.
Another common problem is a worn out accumulator piston. What happens here is the aluminum accumulator piston wears in the pin bore causing leakage. The purpose of the accumulator is to cushion the shift. If the accumulator is leaking the cushion effect is reduced causing the harsh shift.
transman
transman618
transman618
Loc: Cumming,GA
Reg: 06-06-04
07-06-09 11:43 PM - Post#1730460
In your case, a quick scan probably would have shown a P-1870 trouble code. If it did, the valve body would have had to be removed and the converter clutch regulator and isolator valves sleeved. This was probably one of the causes of your transmissions demise.
transman
rodram
Reg: 04-14-09
07-07-09 08:13 AM - Post#1730576
transman....
well, I now have a total rebuild of the 4L60E transmission and torque convertor... it seems to be working OK, and I am getting used to the different shift response compared to the old sluggish operation.
transman618
transman618
Loc: Cumming,GA
Reg: 06-06-04
07-07-09 02:49 PM - Post#1730744
Its amazing what a couple of small upgrades will do to the performance.
transman
Execution time: 0.402 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:18 PM
