 Page 4 of 4 « First<1234
Username Post: General EFI discussion        (Topic#217970)
64duece
64duece
Loc: New Jersey
Reg: 10-31-01
03-12-10 08:56 AM - Post#1878694
    In response to 79ZED
  • 79ZED Said:
If you buy the unterminated harnesses for ignition, injectors, or main wiring do you get the proper connectors for terminating them? Is the main harness already pre-terminated at the ECU end? Do you need a Weather Pack crimper or a Metri-pack?
Thanks!
John,
Yes, the 550-605 HP ECU & Unterminated harness includes the connectors and is terminated on the ECU end. The leads are 15ft. The connectors are Metripac 150.
Regards,
Dennis
Moore Racecraft
Dennis
55 Chevy 210
e85 Injected
572 Twin Turbo
4L80E
79ZED
Loc: Nanaimo, B.C., Canada
Reg: 01-09-02
03-13-10 06:53 PM - Post#1879579
    In response to 64duece
Thanks Dennis, Guess I need to invest in a good metripac tool, after all these years using weatherpac.
John 79Z28
Steve P
Reg: 07-13-08
03-14-10 03:54 AM - Post#1879746
I am sure I am missing something but what is a METRIPAC tool. On this side of the pond we dont have such a device.
Steve P
D.Mac
Loc: Ontario Canada
Reg: 03-22-03
03-14-10 06:34 AM - Post#1879785
    In response to Steve P
The proper terminal crimp and pin extractor tools make a world of difference when your trying to do a nice clean install or repair.
http://www.whiteproducts.com/metripack-tools.shtml
Dave MacDonald
Ontario, Canada
'66 Impala LT1/C950-,EFI,700R4,(sold 07/2011)
'12 Sonic LTZ, Turbo, M6
'07 Pontiac Solstice GXP
'06 Caddy CTS-V
ShelbyDogg
ShelbyDogg
Reg: 07-05-09
05-26-10 09:24 AM - Post#1920915
    In response to Doug_F
Doug,
Quick question;
After all of the self learning is finished, with the 3 new Holley EFI systems, is there an option to turn off that function and run with locked cells? Or maybe limit it to lets say, 5% ?
I would hate to lose a spark plug wire then have the computer lean out the remaining 7 cylinders because of a false rich condition.
Rob
Rob
V3 Megasquirt, Edelbrock Pro-Flo-1, Holley C950, F.A.S.T. EZ-EFI
My restoration thread:
http://www.cuda-challenger.com/cc/index.php?topic=...
Danny Cabral
Danny Cabral
Loc: Connecticut
Reg: 11-03-04
05-26-10 10:15 AM - Post#1920938
    In response to ShelbyDogg
  • ShelbyDogg Said:
After all of the self learning is finished, with the 3 new Holley EFI systems, is there an option to turn off that function and run with locked cells? Or maybe limit it to lets say, 5%?
Yes, you can disable the Learning function (self-tuning) or select the percentage of Learning compensation (kPa x RPM, + & -).
May God's Grace Bless You
'78 BRONCO: 508" stroker, TFS heads, Dominator MPFI & DIS, A/C, Lentech Strip Terminator AOD, 3:1 Atlas II, modified Dana 44/60-lockers-4.10s, hydroboost/4-disc brakes, ram-assist/heim joint steering, 4" lift, 35" tires
ShelbyDogg
ShelbyDogg
Reg: 07-05-09
05-26-10 11:05 AM - Post#1920958
    In response to Danny Cabral
Thanks Dan!
Rob
ShelbyDogg
ShelbyDogg
Reg: 07-05-09
05-26-10 11:54 AM - Post#1920973
Dennis,
Do you sell an ECU and harness for the Avenger unit? If so, how much is it?
FAST came out with their EZ-EFI ecu and harness last month. It is about $950 retail. I'm trying to figure out the cheapest way to convert my 3 cars to self tuning, 2 already have throttle bodies and 1 has multi-port.
Rob
Doug_F
Holley Subject Matter Expert
Doug_F
Loc: Bowling Green, KY
Reg: 08-20-01
05-26-10 07:42 PM - Post#1921208
The HP has the same self tuning fuel table the Avenger has. The Avenger just allows "simpler" global changes vs the HP which has similar tuning tables like the C950 (AE, etc).
Doug
1972 Nova
6.0L LSx, 80mm BorgWarner, 4L80E
9.34@147
64duece
64duece
Loc: New Jersey
Reg: 10-31-01
05-27-10 10:37 PM - Post#1921738
  • ShelbyDogg Said:
Dennis,
The HP is the cheapest ECU & Harness kit available from Holley. Cost range between $1399 and $1449. It includes ECU, Main and Injector Harness (TBI or Multiport) and all new sensors including WBO2. There are several major differences but wanted to note: Holley has igntion control, FAST EZ EFI does not.
Dennis
55 Chevy 210
e85 Injected
572 Twin Turbo
4L80E
Danny Cabral
Danny Cabral
Loc: Connecticut
Reg: 11-03-04
05-28-10 12:27 AM - Post#1921752
  • 64duece Said:
[There are several major differences but wanted to note: Holley has ignition control, FAST EZ EFI does not.
The Fast EZ isn't in the same class as the Holley HP EFI.
It lacks most of the tuning parameters the HP has.
ShelbyDogg
ShelbyDogg
Reg: 07-05-09
05-28-10 04:19 AM - Post#1921775
The HP-Holley is still $500 more than the FAST. That is why I was trying to see if the Avenger was cheaper in price, without sensors, WB, and throttle body. The benefits of ignition control have been discussed here in great detail already. One of my systems is still running the weight and vacuum advanced distributor and runs very well. If I lose ignition, I'm able to fix it with a few parts in my tool box or parts store without having to carry a spare EFI-ECU.
When it comes down to it, "cheapest" and "self tuning" were my key words.
Rob
oregonjoe
Loc: Sothern Oregon Coast
Reg: 07-16-12
07-17-12 11:12 AM - Post#2249107
We recently installed a Holey HP ECM in replacement of a C950 to take advantage of the extra/new features. Especially important were the CAN bus interface and single wire Gauge Output.
This is a Marine application with a GM Vortec MPFI engine so we wanted to be able to get the Holley HP data on the vessel CAN Bus up to the Helm station 50 feet away.
After finding no mention in the manuals on interface to CAN bus and Gauge Out – calls to Holley Tech Support reviled these are not to be touched by “human” hands – only Holley can use these ports.
This is a significant downgrade of a much advertised feature set. Modern ECMs all use CAN Bus styled PID s to query and get ECM status data. Besides the standard sensor data like RPM, Temps, pressures, and such we are also after the calculated values like load, fuel economy, power and more. All of which we thought we could access over CAN bus just like other ECMs.
Another goal was to integrate the Holley HP data with our wireless CAN Bus gateways to get the info wirelessly up to an iPad or similar device like we now do with other EMCs and vessel data. Many custom car builders are now looking at using iPads in the dash for instrumentation and this could have been a good fit.
So, the question to the Holley folks is why is the CAN bus interface forbidden and is there any hope for developers to utilize this data in more interesting and useful ways. At least a simple spec on how to enable the sensor output like on other CAN ECMs.
Custom Digital Instrument Panels at www.chetcodigital.com
oregonjoe
Reg: 07-16-12
07-17-12 12:25 PM - Post#2249134
For anyone who is interested – here are the connectors and pins for the Holley ECMs available from www.mouser.com at about $25/set
I have used them to make up two custom harness and they are great for spares.
571-3-1447221-3
3-1447221-3
S-SEAL SKT 18-16
571-4-1437290-0
4-1437290-0
HSG PLG 034C KEY:1
571-3-1437290-7
3-1437290-7
26P PLUG 4 ROW
oregonjoe
Reg: 07-16-12
07-17-12 12:31 PM - Post#2249138
    In response to BrianM
For anyone who is interested – here are the connectors and pins for the new Holley ECMs available from www.mouser.com at about $25/set
I have used them to make two custom harness for C950 to HP ECM.
571-3-1447221-3
3-1447221-3
S-SEAL SKT 18-16
571-4-1437290-0
4-1437290-0
HSG PLG 034C KEY:1
571-3-1437290-7
3-1437290-7
26P PLUG 4 ROW
Execution time: 0.598 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:25 AM
