Username Post: looking to change rearend of my truck        (Topic#213062)
reborn 1968 chevy truck
Loc: Bakersfield,ca
Reg: 03-14-09
03-27-09 10:07 AM - Post#1662403
hey guys im looking to change the rear end gear in my 68 chevy truck, it a 3/4 camper special. 8 lug, 1 ton rear end, im putting a super charged v8 in her and i want to be able to go to the strip and have fun with it. it has a tall gear in it now like a 4-55 or taller not sure, does any one have any ideas on what gear i can use, the rear end is a 12-bolt . well let me know what i need to do to achieve this goal. thanks.
bobschevytrucks.com
Loc: San Francisco, CA, USA
03-27-09 12:31 PM - Post#1662522
    In response to reborn 1968 chevy truck
Some of what you are saying just doesn't make much sense. First, a 12 bolt rear would belong to a 1/2 ton truck. A stock 3/4 or 1 ton rear will have a removable center section and a removable cover plate, both perfectly round and held with 10 bolts. If the rear you have in there now doesn't look like this, please post a pic of it.
http://chevy.oldcarmanualproject.com/booklets/47st...
Second, 4.55 is hardly a tall gear. If you are running quarter mile drags it's probably about the shortest gear you would want to run unless you have huge tires.
Your present gear ratio doesn't have to remain a mystery because it is easy enough to count.
Put matching marks on the pinion yoke and differential housing. Jack one rear wheel off the ground, put the transmission in neutral, and the parking brake off. Turn the wheel exactly TWO revolutions and count how many times the driveshaft turns, estimating any fractional turn as closely as possible. That number is your axle ratio. If the wheel is difficult or impossible to turn, you may have posi. In that case, jack both rear wheels off the ground and turn either of them only ONE revolution. Count the driveshaft turns the same way as for an open rear.
Once you determine what kind of rear you actually have in there and find out what the ratio is, then you can decide where you want to go with the gearing.
Lastly, you are on the 67-70 car board here. Scroll down the forum list and you will find the trucks.
Live more responsibly. Eat lower on the food chain. Eat vegetarians.
Loc: Bakersfield,ca
Reg: 03-14-09
03-31-09 07:56 PM - Post#1665904
well thanks for the advice, but i know that the rear end is a 12 bolt, because the rear end number says its a 12bolt 1 ton.. also i know that its not a posi track because i tried doing a power brake and only one wheel took all the power. and pic in the link is not the same as what is under the truck. the front half does come off but there are 12 bolts. the rear pumpkin has 12 bolts also. well if you have any other tips just let me know on here thanks.
03-31-09 10:36 PM - Post#1666012
Ok, I believe you have what you say, but I have no clue what it is. The rear pictured in the link I posted was used in all 3/4 and 1 ton Chevy trucks up to 72. Maybe if you post a pic of the rear in your truck, or a link to it, someone who is more knowledgeable than I am might be able to identify it. You can still count the ratio using the method I described in my earlier post.
Loc: Bakersfield,ca
Reg: 03-14-09
04-01-09 11:02 AM - Post#1666291
ok i have a pic of the back of it for the insurance company, i dont know if it will help at all.
Bad Bowtie
Bad Bowtie
Loc: TX
Reg: 07-04-03
04-01-09 11:18 AM - Post#1666306
I'm lost as well!!
That would be a great rear axle ratio for the drag strip. The only thing missing would be the limit slip carrier...
Loc: Bakersfield,ca
Reg: 03-14-09
04-03-09 09:44 AM - Post#1667927
    In response to Bad Bowtie
ok here is a link for the pic for the rear end,
http://i137.photobucket.com/albums/q225/donaldduc k...
04-03-09 11:22 AM - Post#1667990
Please shoot another pic centered on the rear end so the entire cover is visible. Also, what is the series or model ID shown on your front fenders?
JimKshortstep4x4
Chevytalk Moderator & "9th Year" Silver Supporting Member
JimKshortstep4x4
Loc: Muskegon, MI, USA
04-04-09 01:51 AM - Post#1668448
Here is a link to an axle guide. Maybe you can compare yours to the pictures.
http://www.coloradok5.com/axleguide.shtml
Member 65-66 Full Size Chevrolet Club
66 Impala SS, 396, TH 400
69 El Camino, 350, TH 350
71 Short bed stepside 4x4, 350/350
Current project, 72 GMC Shortbed, stepside, 427
Loc: Bakersfield,ca
Reg: 03-14-09
04-05-09 11:57 AM - Post#1669356
ok guys its the dana 60 rear end. not sure what the model id is on the fenders, where would i look for that on the fender. well thanks for all the help. now i just need to find out the gear ratio in the rear end.
04-05-09 12:17 PM - Post#1669376
Ok, that makes it a lot easier. You won't need the truck model now. That's actually a GMC rear, not Chevy. They were used in Chevy trucks when you ordered leaf springs. Count the bolts again and I think you will find there are only 10.
You can still find out the gear ratio by counting it like I described above.
longhorn_man
Loc: Columbus Ohio
Reg: 02-02-02
04-06-09 07:54 PM - Post#1670476
there were plenty of dana rears in chevy trucks.... most big block 3/4 ton trucks got the dana, including my suburban.
1972 C/10 burb, 68 nose, SLAMMED... 402/TH400/3.07 <--- Chicks dig it!
1970 C/30 Longhorn, GMC nose...Caddy 425/TH350/4.10 one of 1404 built
www.longhorntrucks.freeservers.com
04-06-09 08:17 PM - Post#1670499
    In response to longhorn_man
Leaf springs or coils?
Loc: Bakersfield,ca
Reg: 03-14-09
04-06-09 09:42 PM - Post#1670550
i have leaf springs. and i need to replace them both but dont want to spend a fortune doing it got any hints. and my truck is a 3/4 ton CAMPER SPECIAL..
longhorn_man
Loc: Columbus Ohio
Reg: 02-02-02
04-07-09 03:35 AM - Post#1670632
Dana rears were in both leaf and coil rear end equipped Chevy trucks.
I have 2 out of big block 3/4 2 wheel drive ton leaf spring chevys in my garage, and just sold a dana big block 3/4 ton dana rear out from under my 2 wheel drive big block 72 suburban. (converted it to 1/2 ton)
I've been into these trucks for over 13 years now, and I have never heard anyone say that dana was a GMC rear. It was all but standard with a big block in a 3/4 ton truck, and would have 3.54 gears. There was no actual option number, but it pops up from time to time, however, again, the best way to locate one in these trucks, is to look under the back of a 3/4 ton big block truck... leaf Oor coil.
Danas have been found under inline 6, and small block trucks too, just very very uncommon.
First, you'll have to define fortune. A budget bolt on to one man, is another man's entire budget.
I wouold recomend starting your own thread, since this thread is about rear ends, and has nothing to do with springs.
New springs aren't cheap. That's all there is to it. You'll possibly need to have them made.
Edited by longhorn_man on 04-07-09 03:37 AM. Reason for edit: No reason given.
Loc: Bakersfield,ca
Reg: 03-14-09
04-07-09 09:04 PM - Post#1671287
yea i found a spring guy that will make a set of springs for me for 90 bucks each. well thanks for all the advice now i know what else i need to do for my decision.
04-08-09 02:07 PM - Post#1671695
Ok, if you say the Dana rears came with coil springs I will take your word for it, but the only ones I have ever seen in Chevys had leaf springs. These rears drive parts store guys nuts too, until someone tells them to look at GMC.
longhorn_man
Loc: Columbus Ohio
Reg: 02-02-02
04-09-09 01:29 PM - Post#1672397
yep... I know where there's 4 of them right now. all 8 lug, dana, factory coil, and all with 3.54 gears.
NONE of them for sale either. The old geezer hords stuff for no reason.
bobschevytrucks.com
Execution time: 0.112 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:49 PM
