 Page 4 of 31 « First<4567>» Last
Username Post: 2Loose 55 Gasser Questions        (Topic#212981)
jeffs55
jeffs55
Loc: Shelby Forest, Tennessee
Reg: 01-05-06
09-08-09 12:15 PM - Post#1768259
    In response to 2Loose
Now that's a cool load of stuff there.
'specially that shiny huffer/stuffer on the bottom.
Jeff
55 Handyman
66 F100 project
32 3 Window Coupe project
1948 Studebaker Champion
1977 Toyota Celica Coupe
2000 Blazer 4X4
My Pics
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
09-13-09 12:52 PM - Post#1771214
    In response to jeffs55
UPDATE:
Ran into a few problems, was doing a mock up of all available parts for the motor, blower, tranny (still missing a few parts) so I could set up the motor mounts, tranny cross member, and the radiator location.
Discovered that my crank was not drilled for a pilot bushing. Luckily I had another motor stored away that has an idential crank, and it is drilled for a pilot bushing. It's just that this motor decided not to release the crank easily to me!
It was a battle, but I finally prevailed!
Oh what fun!
Aloha,
Willy
Link to more pix
Another Link to more pix
jeffs55
jeffs55
Reg: 01-05-06
09-13-09 01:15 PM - Post#1771224
I see your problem there.
Jeff
55 Handyman
66 F100 project
2000 Blazer 4X4
My Pics
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
09-13-09 01:36 PM - Post#1771229
That's a new modification technique Jeff, it prevents pre-ignition!
W.
Thadd
DECEASED Member
Thadd
Loc: Rolling Hills, Ca,
Reg: 12-30-01
09-13-09 08:20 PM - Post#1771463
That Kona beer will do it to you every time
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
09-13-09 11:14 PM - Post#1771523
    In response to Thadd
I got the motor between the frame rails today, had to pull off the blower, just couldn't get it high enough (or maybe I wasn't high enough??? ) to get over the frame rails unless I did that.
Here's one pix. Took measurements while celebrating the milestone with some really good Mexican beer....
LINK TO THAT PAGE
Aloha,
Willy
Slow Old Man=Fast Old Cars
Some Photos
2Loose Home Page
Chevys:55.Hardtop;55.4drgasser;
55.4x4truck;58.prostreettruck
+57.Olds;70.BuickGS
Avatar:Bill Stinson
jk56chevy
jk56chevy
Loc: maryland
Reg: 02-27-05
09-14-09 09:23 AM - Post#1771718
Nice!! Persistence is a virtue. Keep up the good work!
1956 Chevy Belair
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
09-15-09 09:04 AM - Post#1772300
    In response to jk56chevy
I hope this isn't getting too detailed, but it seems some of the CT'ers like seeing how all this kind of work is created and put together, so I will keep posting as I put this project together.
Working on Sunday with the motor hanging between the frame rails, as the pic above shows, I measured and sketched out a cross member to be welded in under the pan, where I will mount the front motor mounts, but I wanted the center section of the cross member to be bolted in, so I could drop it out easily to pull the oil pan. The motor mounts will be on the two side pieces, which will be welded solidly to the frame rails. This is what I ended up with, took about four hours yesterday to lay it out, chop the steel, and weld it up. Painted it last night, will weld it in today and set up the motor mounts on it.
Aloha,
Willy
LINK: Scroll down at this page for more pix....
jeffs55
jeffs55
Reg: 01-05-06
09-15-09 09:17 AM - Post#1772304
Oh yeah, we love the details, 'specially if there's pics.
Lookin' great Willy.
Jeff
55 Handyman
66 F100 project
2000 Blazer 4X4
My Pics
Ronny's 55
Ronny's 55
Loc: Lancaster, SC
Reg: 12-28-03
09-15-09 06:20 PM - Post#1772642
Nice fab. work Willy. That is going to be cool.
Ronny's 55 http://www.picturetrail.com/ronnystoess
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
09-22-09 11:59 AM - Post#1776288
    In response to Ronny's 55
Making some headway, got the new front cross member welded in place under the motor, the "drop out" center section works nice, it will be easy to drop the pan if I have to while the motor is in the car.
Yesterday I welded up a cross member from 1-1/2" black pipe for the tranny tailshaft support, and wanted to make that height adjustable, so then I fabbed two 1/4" plates with three pairs of threaded holes on each side that match the plates welded onto the ends of the tranny support. Then I spent a couple of hours under the car, welded the 1/4" plates onto the frame rails on each side to match the tranny support, then drilled each hole through the frame rail walls, and ran the tap through on each hole, so I now have threaded holes at three different levels that I can adjust the tranny support up or down with. I bolted everything up, tried each level, 3/4" adjustment each, and it all worked great! It's set in the middle position now and seems to be aimed directly at the differential.
If I need to "fine tune" that, I can put a small spacer under the tranny support. Will try to get a couple of pix.
Also laid out my front motor supports on cardboard, now that the tranny tailshaft is centered and supported, I have the front of the motor centered and aligned and can weld the motor mounts in place. Will be fabbing the front motor mounts today and welding them in place.
Aloha,
Willy
awsum55
awsum55
Loc: O.P. Kansas
Reg: 09-27-01
09-22-09 12:51 PM - Post#1776309
Lookin' better all the time Willy.
Five things that you cannot recover in life:
* The Stone after it's thrown
* The Word after it's said
* An Occasion after it's missed
* The Time after it's gone
* A person after they die
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
09-23-09 11:35 PM - Post#1777262
    In response to awsum55
Another update, got the motor mounts fabbed and welded in, and the motor and tranny installed. It all has to come out again, still need to do the final assembly on the motor.
Getting there,
Link to more pix, scroll down to the bottom of the page....
No work for a few days now, am heading out tomorrow to SoCal to go to CFAC! A really good event!
I registered to take this car, but obviously, the car's not going to make it!
Aloha,
Willy
jeffs55
jeffs55
Reg: 01-05-06
09-24-09 09:26 AM - Post#1777404
Take a piece of it. Like the hood badge or something.
Jeff
55 Handyman
66 F100 project
2000 Blazer 4X4
My Pics
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
10-01-09 10:26 AM - Post#1781278
Jeff, I took some photos of the project along with me. Talked to several other tri-five gasser owners there, shared some good ideas. CFAC was a really fun event this year, as always. There were some awsum owner built cars there!
Picked up a radiator and fan setup while I was there, now setting up the install.
Posted some pix here.
The fans are pretty close to the blower belt, but there is adequate running clearance. Might lose a fan or two if I lose a belt at high rpm! The whole setup is a tight fit, anybody see any problems with this setup that I don't see?
Aloha,
Willy
Gray Headed Mule
Gray Headed Mule
Loc: Fort Worth, Texas
10-01-09 08:26 PM - Post#1781568
Your mirror is crooked!
Mule
I'm sexy and I know it!
My 49 Chevy Fleetline Deluxe Restoration Project
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
10-01-09 10:39 PM - Post#1781612
    In response to Gray Headed Mule
That's not the only thing!
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
10-03-09 11:30 AM - Post#1782366
Made up some pockets to set the radiator 1.5" lower into the frame rails, where it will now clear the underside of the hood. Still need to reinforce the frame a bit more at those pockets. Will start installing the front bars of the 12 pt cage, and hang the radiator supports off of that.
Aloha,
Willy
Added more pix to the bottom of this page.
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
10-05-09 11:38 AM - Post#1783365
Whacked a hole in the hood and it clears the blower pulley/belt, the blower will be hidden when the hood is on, Sneaky !!!
That's a "spare" hood I got from steves55 when I was over for CFAC'06.
The hood cleared my radiator, just as I thought it would after I "lowered" the radiator with those frame pockets.
More Hood Pix Here
And I welded in another front frame crossmember/support and whacked off the start of the flip front end.
Those tubes by the front tire are the front "legs" of the 12-pt cage, the radiator supports will be mounted on those.
More "Flip" Pix Here (Scroll down)
I need more hours in the day, Man, I wanna hear that baby fire up!!!
Aloha,
Willy
jeffs55
jeffs55
Reg: 01-05-06
10-05-09 01:50 PM - Post#1783440
Lookin' good Willy.
Notice the covered engine trick. I've seen pro stock drivers do that to keep their secrets.
I watched the Bob Glidden crash (on TV) back in the 80s (I think it was).
Crazy, hit the wall and roll over crash.
Tears up the car pretty bad.
They show his wife and pit crew all watching in horror.
He's hurt, but not badly. He gets out and the first thing he does is throw his racing jacket over the engine.
Jeff
55 Handyman
66 F100 project
2000 Blazer 4X4
My Pics
WagonCrazy
WagonCrazy
Reg: 06-07-05
10-05-09 06:06 PM - Post#1783590
Good work Willy. You waste no time making progress on that gasser of yours.
I'm up to my eyeballs in teenager stuff, and cant' seem to find a minute to mess with my Nomad.
Frustrating.
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
10-05-09 10:46 PM - Post#1783746
    In response to WagonCrazy
OK, A question for you guys....
As it can rain here quite a bit (Ya wouldn't know it lately, but yes, it can!!! And I've seen 24 inches of rain in 24 hrs, it was like living under a waterfall!!!) I was thinking of setting the scoop on the carbs backwards facing the windshield.
As I recall with the "shoeboxes", there is a high pressure area right in front of the windshield, so it would actually enhance air flow I would think, and keep most of the rain out. If I can set the scoop up so it can easily and quickly be turned around (like, pull off to the side of the road when I see a heavy black cloud wetting the road ahead....) and turn it around???
I don't have a scoop yet, but here is one at Speedway Motors:
but I don't know how it is mounted or how easy it would be to turn it around along the side of the road....
But the price is right !!!
AND it is low profile, I want to keep visibility from the driver's seat as good as possible....
The cops around here are pretty tough, I don't want to give them any reason to give me a lot of grief, there will be reason enough once they see this machine....
Any ideas on "forward face" vs "rear face" on these setups???
Aloha,
Willy
PS, I spent today welding up the tilt bar for the front of the frame that I cut off yesterday, it is coming along nicely!!!
Pix later....
jeffs55
jeffs55
Reg: 01-05-06
10-06-09 05:36 AM - Post#1783820
You wouldn't drive it in the rain would you??
I know, I know, you could get caught out in a downpour.
Make a rotatable pad that you could connect with a choke cable.
If it starts to rain, pull the knob and turn it around. You won't even have to get wet.
Jeff
55 Handyman
66 F100 project
2000 Blazer 4X4
My Pics
Gray Headed Mule
Gray Headed Mule
10-06-09 06:28 AM - Post#1783842
I'm a thinking that these things have like a super duper radiator type clamp to hold them on.
Mule
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
10-06-09 10:10 AM - Post#1783942
Heck, I could motorize it, just hit the switch and 'rrrrrrrrrr' it turns around !!!
I'll have to order one, am thinking maybe I could just drill two holes in the top of the scoop to line up with an air filter bolt on each carb with wing nuts on top, then it would be easy to do!
Willy
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
10-07-09 09:51 AM - Post#1784504
Got the frame section of the flip front end welded up and in place. Now to set up the fenders and get it all reinforced and functional!
Aloha,
Willy
More Pix Here (scroll down)
MPandC
MPandC
Loc: Leonardtown, MD
Reg: 03-09-06
10-07-09 09:55 AM - Post#1784508
It's looking good Willy, nice fab work!
Robert
MP&C Shop Projects
jeffs55
jeffs55
Reg: 01-05-06
10-07-09 01:27 PM - Post#1784602
    In response to MPandC
Gonna be soooo cool, man.
Jeff
55 Handyman
66 F100 project
2000 Blazer 4X4
My Pics
56sedandelivery
56sedandelivery
Loc: Everett, Wa.
Reg: 02-26-08
10-07-09 03:09 PM - Post#1784658
There's a Cliff's Classics sponsored; 56 Chevrolet 210 4 door sedan, bracket racing in the Portland/Woodburn area. Done up like a TAXI with yellow paint, stripes, and lettering; even has a TAXI light on top. Maybe an idea to draw on with the 4 door theme of things with your gasser. Butch/56sedandelivery.
2Loose
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
10-08-09 10:53 AM - Post#1785123
Would love to see pix of that!
We pretty much settled on a "Hawaii surf cruzer" motif for this one. Surfboard on top (bolted in place!) and a "hula doll" waggin her hips on the rear package shelf! Even decided to call it the "Hip Shaker", which in Hawaiian is "Kikala Ho'oluli". Don't think I can get that on a license plate though! Maybe try for a plate that sez "HIP SKR" or "HIP SHK" or "HP SHKR", they only allow up to six letters in Hawaii.
Aloha,
Willy
Execution time: 0.554 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:00 PM
