Username Post: 454 Oil Filter size?        (Topic#212783)
56BUDDY
Loc: Union City, CA
Reg: 12-31-02
03-24-09 07:45 AM - Post#1659563
I'd like to change the oil on a 454 BBC for the family of my late friend's 55. Are all big block oil filter sizes the same? If so, what's the number/manufacture of the oil filter? I know, just crawl underneath and look stupid! But, I don't have the car and I'd like to pick one up before I get the car.
Thanks!
Mel
Mel
69 SS396
69 SS396
Loc: Lakeland, Fl
Reg: 11-30-08
03-24-09 07:50 AM - Post#1659568
    In response to 56BUDDY
It should take the Fram PH13. There are other brands that are a diff color than Fram orange so it can be matched to the engine color. I know no one can see it but this is where my OCD kicks in
The fate of empires depends on the education of youth-Aristotle
Kids will be kids, but parents should be parents.
Sean
http://www.picturetrail.com/myelkyss
1969 El Camino SS396 "Misty Meaner"
Edited by Yellow63 on 03-24-09 07:52 AM. Reason for edit: No reason given.
56BUDDY
Loc: Union City, CA
Reg: 12-31-02
03-24-09 08:11 AM - Post#1659588
    In response to 69 SS396
Sean,
Hey thanks! I appreciate it. So, the big block oil filters are the same size as a small block?
Thanks again.
Mel
Mel
SSuper Dave
Loc: Pearland TX
Reg: 10-02-05
03-24-09 08:59 AM - Post#1659621
Small block and big block are the same, get an AC PF1218. Leave the Frams for the Fords!
1968 Caprice coupe, 327/275, TH400, Ash Gold/Ivy Gold, Tach Dash, Tilt, Buckets, Console, AM/FM, Rear Defog, Disc and Rallys.
1970 El Camino, 350, TH400, 12 bolt posi, a blank slate!
03-24-09 09:33 AM - Post#1659651
Just to clarify, the thread size and gasket location are the same for all Chevy V-8 factory spin-on oil filters, which means that they will physically screw on to the engine and not leak. However, the filter can is offered in several different lengths, which affects oil capacity, and in some cases, external clearance.
34CABRIOLET
34CABRIOLET
Loc: northern indiana
Reg: 09-01-05
03-24-09 09:40 AM - Post#1659656
KEEP YOUR GM ALL GM
old # PF35 it can be run on small blocks as well
if you want a little more capacity.
jeff
WHEN YOU TURN ON YOUR CHEVROLET....
.....DOES IT RETURN THE FAVOR?
55DRIVER
Loc: Chicago burbs
Reg: 11-10-08
03-24-09 09:32 PM - Post#1660207
    In response to 34CABRIOLET
I've been using Fleetguard LF692's for years on my 454. It's a 2 qt. truck spec filter. The extra length also makes it easier to remove with the headder tubes nearby.
MikeB
MikeB
Loc: Plano, TX
Reg: 08-28-03
03-24-09 09:45 PM - Post#1660219
The old PF35 has been replaced by the PF1218. You can also use the shorter PF454 for header clearance.
Last time I read an oil filter test, they cut open the cannisters and the Fram had a LOT less filtration material than the AC Delco.
03-25-09 06:06 AM - Post#1660388
    In response to MikeB
All of the above is good info.
Originally, in the spin-on version, the stock Delco filter was the 25, the larger was the 35 and then the BIG 2qt version for trucks (don't know the number).
As mentioned, forget the Fram.
WIX is accepted as one of the better filters available (there are other good brands) and now I ONLY use the longer, 2qt truck filter on all my Chevy engines. Chevy changed from the cannister to the spin-on filter with the 68 models and it doesn't matter if it is the 302 Z28 engine, 350, 396, 454 or anything in between------------IF IT'S A 68-LATER CHEVY ENGINE, it accepts the SAME filter!
Execution time: 1.324 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:23 PM
