Username Post: 1965 C20 Engine        (Topic#211974)
oldskol
Loc: Reno, Nevada
Reg: 05-17-04
03-14-09 10:59 PM - Post#1651816
What 6 cylinder engine was available in the 1965 C20 trucks?
And how much HP/TQ can you get with a well built 6 cylinder from the era?
Thanks.....
Edited by oldskol on 03-14-09 11:01 PM. Reason for edit: No reason given.
bobschevytrucks.com Ecklers
sidworks
Loc: Sidney, B.C.
Reg: 12-03-05
03-14-09 11:02 PM - Post#1651819
    In response to oldskol
292 more than lkely would have been the prevelant eng
ron
http://www.sawmillcreek.org/showthread.php?208929-...
http://www.sawmillcreek.org/showthread.php?220902-...
http://forum.woodenboat.com/showthread.php?156542-...
oldskol
Loc: Reno, Nevada
Reg: 05-17-04
03-15-09 08:52 AM - Post#1652029
    In response to sidworks
Sid thanks for the reply......
Vaughn
Vaughn
Loc: Colorado Springs, CO
Reg: 08-08-04
03-15-09 07:30 PM - Post#1652610
Either the 230 or the 292 in 1965. 292 has a sawtooth style valve cover.
The 292 is 165 HP, the 230 is 140 HP.
oldskol
Loc: Reno, Nevada
Reg: 05-17-04
03-15-09 08:05 PM - Post#1652634
    In response to Vaughn
Thanks Vaughn. Any idea with a aftermarket cam and head work what kind of HP numbers I could get out of one of these motors? I have a forged 502 BB waiting patiently do drop into my 65 chevy truck. But I have heard some really cool inline 6's and thought about maybe building the motor if I could pump it up a little....
Dave
LGriffin
Loc: Gateway to Yosemite
Reg: 04-16-04
03-16-09 06:23 AM - Post#1652869
Check the side covers on your six, if they 6 inches high you have a 292, 4 inches 230/250. The stock hp on the 292 was about 175. The bottom end torque is better than a 350. I like the bottom end torque of my 292 and being able to off the line at just above idle. To find out what you can do with a 2230/250/292 for performance check out inliners.org
Larry
I don't own a vehicle that isn't old enough to drink.
Vaughn
Vaughn
Reg: 08-08-04
03-16-09 01:13 PM - Post#1653158
    In response to LGriffin
You can get wild with the 6 if you want, just depends on how much money you want to spend.
One of the inline 6's best quality is its low end torque. There are some cam swaps you can do, head porting or even supercharging/turbochargi ng that will improve on that.
The six cylinder motors respond to traditional hop up measures - airflow, cooling and whatnot.
I addition to inliners.org, there is clifford performance that deals strictly with inline motors, and there are some tech info on stovebolt.com (you have to look around a little to find them).
oldskol
Loc: Reno, Nevada
Reg: 05-17-04
03-16-09 11:56 PM - Post#1653588
Thanks for the post guys......!!!!
oldskol
Loc: Reno, Nevada
Reg: 05-17-04
04-27-09 12:35 AM - Post#1685857
Hey guys what type of mileage do the inline 6's get with normal driving? A buddy of mine was claiming he was getting 20 MPG on the freeway with his.....???
LGriffin
Reg: 04-16-04
04-27-09 06:24 AM - Post#1685931
I've heard of 15-18 mpg with the 250. I've gotten 16 mpg with my 292, I have an overdrive and 4.11 gears. your rear axle ratio is the limiter with out going to OD.
Larry
oldskol
Loc: Reno, Nevada
Reg: 05-17-04
04-27-09 11:15 PM - Post#1686619
Thanks for the info Larry......
Vaughn
Vaughn
Reg: 08-08-04
04-30-09 11:51 AM - Post#1688549
My C-10 327 with th350 and 3:08 rear, will run at 20 mpg fairly consistently.
christopherlutz
Loc: Flower Mound, Texas
Reg: 11-10-06
05-02-09 06:58 AM - Post#1689826
yes, but....if he has a stock 65 C20 rear end, he's got 4.56 gears.
Probably can only get 20mpg downhill
Lutzy
1965 C20 (completely dismantled)
2008 Chevy Silverado 1500 (5.3l V8)
2006 Honda Pilot EX
jhicken
jhicken
Loc: Flagtown, NJ
Reg: 12-28-01
05-02-09 08:35 PM - Post#1690245
    In response to christopherlutz
My '65 C20 came stock with a 175p 327. It averages around 16mpg. 4speed with a compound 1st. Not sure about the rear end.
-jeffrey
1965 C-20 Custom Camper
hilandr451
hilandr451
Loc: Anna Texas
Reg: 01-02-02
05-03-09 05:31 PM - Post#1690645
    In response to jhicken
Jeffrey, what a pleasant suprise! Good to see you chiming in again!
-The Hilander.
Silver 2017 Silverado 1500 double cab 2WD 5.3L
"Rattle can primer red" 1966 C20 Custom Camper 5.7L, 700 R4 trans 410 diff. front disc, p/s
Project Pics
Execution time: 0.47 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 04:49 PM
