Username Post: Tighten up loose steering column        (Topic#210983)
brigdeja
Loc: New York
Reg: 03-03-09
03-03-09 05:47 AM - Post#1642570
Saw this in the frequently asked questions but no link. Does anyone have a detailed explanation or know where I can find one to tighten up my column?
Phazer
Phazer
Loc: Armpit of the Universe
Reg: 10-10-03
03-03-09 08:34 AM - Post#1642672
    In response to brigdeja
What year?
Tilt or no?
Have you ever had the top end of a column apart before?
My "To Do List" for this weekend:
Nothing but womens names...
and drugs....
92 Bravada
96 Sunfire
00 Impala
05 Stratus
90 Wrangler
77 Cub Lo-boy
87 Intruder VS700
95 Intruder VS1400
brigdeja
Loc: New York
Reg: 03-03-09
03-04-09 04:47 AM - Post#1643397
    In response to Phazer
Its tilt from a 1991. I havent had the top end of it apart.
Phazer
Phazer
Reg: 10-10-03
03-04-09 07:11 AM - Post#1643468
There are some links on this site to decent write-ups with pictures.
I'd have to suggest that you get someone that has done this before and watch over their shoulder. When you remove some of the parts, other parts can come "raining down" in your lap and you won't have a clue where they go.
Suggested tools are a "lock-plate" compressor and either a "pivot pin remover" or a 2 lb slide hammer that you can put a machine screw in the end.
and drugs....
92 Bravada
96 Sunfire
00 Impala
05 Stratus
90 Wrangler
77 Cub Lo-boy
87 Intruder VS700
95 Intruder VS1400
patgizz
Senior Moderator
patgizz
Loc: Cleveland, OH
Reg: 01-30-00
03-04-09 07:41 AM - Post#1643488
i've done it at least 10 times for myself and others. you can get to 2 of the 3 screws without going beyond the point of no return. i've never had one loosen up after doing the 2 i could reach except my 90, which the threads in their holes were already hogged out and it was a temporary "please get me through winter" fix and not even loctite could help.
Chevytech
Chevytech
Reg: 04-25-04
03-04-09 08:32 AM - Post#1643517
Here are some steering column sites with photos that tell how to repair loose tilt columns. The photos should be helpful.
http://www.fieros.de/en/articles/steering.html
http://elcaminocentral.com/article95.html
Looks like on this site he did the quick fix and did not take it apart far enough to tighten all four fasteners.
http://www.chevyasylum.com/column/tiltcol.html
Exploded View of a tilt column.
http://www.nastyz28.com/tech/e-tiltcol.html
Older car but good photos
http://buickperformance.com/tiltsteeringcolumnwob b...
03-04-09 09:00 AM - Post#1643546
    In response to patgizz
I'll admit to having done the same thing. I've never run across one that was too far gone, but I've had a couple of people get columns from me because theirs would not tighten up.
brigdeja, if you want to do it 100% right and get all the bolts, the links Chevytech provided will get you there.
Phazer
Phazer
Reg: 10-10-03
03-04-09 09:58 AM - Post#1643582
    In response to Chevytech
I knew someone would jump in and post the links, I was just too lazy to do it..
and drugs....
92 Bravada
96 Sunfire
00 Impala
05 Stratus
90 Wrangler
77 Cub Lo-boy
87 Intruder VS700
95 Intruder VS1400
355Cheyenne
355Cheyenne
Loc: Northern MN
Reg: 10-27-04
11-12-09 08:12 AM - Post#1804427
    In response to someotherguy
oops saved the the wrong thread. guess I just bumped it! :-D
98 Silverado k1500 4x4 350
Edited by 355Cheyenne on 11-12-09 08:14 AM. Reason for edit: No reason given.
Execution time: 0.262 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:55 AM
