Username Post: 96 Silverado door won't open        (Topic#207833)
hollywood72
Lurker
Reg: 01-20-09
01-20-09 12:10 PM - Post#1611707
The door won't open from in or out. Any suggestions as how to tackle this?
Bishop
Bishop
Loc: DMV Area
Reg: 01-06-07
01-20-09 12:16 PM - Post#1611711
    In response to hollywood72
You might have to brake the outside handle off and go at it from there to start, it's hard to get inside there if you can't open it period because you have to pull the whole panel off to get access to the guts.
Not only so, but we also rejoice in our sufferings, because we know that suffering produces perseverance
Romans 5:3
Phazer
Phazer
Loc: Armpit of the Universe
Reg: 10-10-03
01-20-09 12:44 PM - Post#1611731
Did this symptom happen at the same time?
That would be odd if it did.
My "To Do List" for this weekend:
Nothing but womens names...
and drugs....
92 Bravada
96 Sunfire
00 Impala
05 Stratus
90 Wrangler
77 Cub Lo-boy
87 Intruder VS700
95 Intruder VS1400
BadAssDonzi
BadAssDonzi
Loc: DFW
Reg: 07-27-08
01-20-09 01:25 PM - Post#1611762
I know this may sound stupid but make sure the door in question is not locked. Like Phazer said, it would be 1 in a million chance that it would break on both sides.
Pop the cover off on the inside door handle by the lock to see if the rod is moving/can be moved up and down to verify it is actually the handles and not just a weak door lock motor/acuator on that door, stuck in the middle where it looks unlocked but actually isn't.
If you think education is difficult, try being stupid.
1999 Chevy Suburban 1500 5.7L 2WD OBS
CDAUSA
Needs to Get Out More Member
Loc: Texas Panhandle
Reg: 12-31-01
01-20-09 01:26 PM - Post#1611764
    In response to BadAssDonzi
Is what I was thinking, but wasn't going to say it
01-20-09 01:54 PM - Post#1611782
    In response to CDAUSA
Right; try unlocking it from all possible methods. Inside lever, outside key hole, and power locks. Sometimes the rod can straighten out just enough that it won't unlock fully - usually the rod for the inside lever/power lock.
SuperSport
Reg: 07-03-01
01-20-09 04:58 PM - Post#1611978
    In response to someotherguy
My 90 model locks the driver's door every 21 slams. Sooner if I leave the keys in it.
Right now it's stuck closed with the seatbelt tangled up in the jamb, and it refuses to unlock.
If I recall.. The lock rod came loose and let the lever fall to the lock position.
Now I have a question:
Does the door panel come off with the door closed?
Or did I accept defeat too soon when I cut the hole in the door panel? (hot melt glued it back in)
So, I'm going to fix it right the second time. Whatever it takes. Last time I just clipped the rod back in the hole.
~SS~
Edited by SuperSport on 01-20-09 05:04 PM. Reason for edit: No reason given.
CDAUSA
Reg: 12-31-01
01-20-09 05:14 PM - Post#1612000
    In response to SuperSport
  • SuperSport Said:
My 90 model locks the driver's door every 21 slams. ~
Did somebody die in it? Sounds like spooks Possessed!
I've thought about that when people were having issues with a door, if it would come or not. I do think you'd probably have to remove the seat, or at least move it over, but probably.
01-20-09 07:31 PM - Post#1612159
Having the seat out of the way is pretty much required. I went through this recently on a regular cab with the newer interior; I'd imagine it might be a little harder with the 88-94 interior because the keepers are easier to mess up.
If you're really good with a slim jim, you might have better luck than pulling the door panel with the door closed. Just be careful not to scratch up your window too badly - it's very easy to scratch tempered glass. If you can hook the lock rod and pull it enough to unlock, you'd be set, then you could open the door and pull the panel for repairs.
SuperSport
Reg: 07-03-01
01-20-09 09:43 PM - Post#1612241
Had a 70 Charger that would start cranking if you slammed the door. It was later determined 10 yrs. after I sold it, the car had actually hauled a body of early demise, no lie. (used cars )
May be someone did croak in it, it's an old company truck, so they coulda worked themselves to death, or crashed it. It definitely shows signs of a complete makeover before re-sale.
I remember, I started to take the seat out and something happened. Then came the hole cutting in the lower left corner area, then some upside down contortionist activity.
If it's like mine, a slim jim won't catch the lever on the latch box, and the rod is unhooked, so...
Am I a numby for cutting the hole? I swear I remember interference at the windshield pillar... Aww jeez, do I really want to do a 700r swap on this thing? (factory TH400)
(note:never buy an auction truck without checking the trans type)
~SS~
CDAUSA
Reg: 12-31-01
01-20-09 10:12 PM - Post#1612261
SuperSport
Reg: 07-03-01
01-21-09 06:09 PM - Post#1612863
So the answer is, I'm a dumbass for cutting a hole in my door panel.
If that's true... In my defense, I'm sure I must have been in a helluva hurry, and seat bolts were seizing and ready to break.
Well at least I have easy access this time.
~SS~
Phazer
Phazer
Reg: 10-10-03
01-21-09 06:37 PM - Post#1612895
Just call it a future speaker hole.
and drugs....
92 Bravada
96 Sunfire
00 Impala
05 Stratus
90 Wrangler
77 Cub Lo-boy
87 Intruder VS700
95 Intruder VS1400
CDAUSA
Reg: 12-31-01
01-21-09 07:17 PM - Post#1612924
Yeah, what Ken said, I'd also call it too difficult to lay over in the floorboard and get the bolts out, didn't have any help to move the seat without tearing something else up---------and any other thing that comes to mind in the next 30 seconds
SuperSport
Reg: 07-03-01
01-21-09 09:40 PM - Post#1613030
Durn Dremels make cutting things too easy.
And I really hate broken bolts, one seat bolt is still not seated, it's seized.
If I can't make the rod stay put, I'll run mig wire from the lock lever. Jackleg it! It's a beater!
~SS~
01-21-09 09:48 PM - Post#1613035
I've got a parts truck here that has a driver's door with no door module - that is, no inner skin that holds the window regulator, inner handle, etc. and also has no door glass. What it DOES have, is some mechanic's wire holding the two interior rods, with instructions written in Sharpie pen on the white painted sheetmetal of the door: "Pull to unlock" "Pull to open" I kid you not!
SuperSport
Reg: 07-03-01
01-21-09 10:20 PM - Post#1613051
Well, I was planning on hiding my wire if it comes to that. But if it's a new trend in customizing, I may consider it.
In the meantime, I'm cruising with the shoulder belt hung over my shoulder, for looks.
It's just too dang cold to do anything, and I'm 80 years old this week.
~SS~
SuperSport
Reg: 07-03-01
01-22-09 11:09 AM - Post#1613295
Was just in my truck, I swear if there's a way to take the door panel off with the door closed, I'm not seeing it. And I'm not normally put off when it comes to taking things apart.
Is the door/dash design that much different in 1990?
My door panel closes against the side of the dash, and the door panel, I believe to be one piece.
~SS~
01-22-09 11:19 AM - Post#1613303
You can't completely remove it, but with the seat out of the way, you can peel it back enough to access the door latch. Of course it's near impossible to see what you're doing in there and hard to reach the latch itself because the rear window channel is in the way...if your lock rods are completely disconnected, both the inside and the key one, you may still be able to manipulate the latch to unlock it.
SuperSport
Reg: 07-03-01
01-22-09 12:10 PM - Post#1613335
Pretty soon, I'll stop working from memory, and have a clear picture of it. But it seems I remember the lock button still connected, but with the key lock unhooked, it stays locked no matter what the button does.
Guess I'll open my little hatch and turn myself upside down.
~SS~
01-22-09 12:41 PM - Post#1613355
The key and internal lever lock rods connect to separate places on the latch, so either one can be disconnected and the unlock function still work from the other. They hinge off the same pivot point in the latch, but aren't dependant on each other, if that makes sense.
SuperSport
Reg: 07-03-01
01-22-09 07:33 PM - Post#1613699
Mine didn't work that way. The lock button has a bound-up feel to it. As I said, the lever on the latch box falls down when the lock rod comes out, and I think that binds the latch box, keeping the interior button from working.
~SS~
pippy
pippy
Loc: birmingham/ montgomery al...
Reg: 12-26-02
01-27-09 02:35 PM - Post#1617079
i wouldve just rolled the window down and got a light and looked inside the door and got a stiff wire to see if i could get it to open.
mercedes benz tech
1975 chevelle
1977 chevelle 4dr
1997 E 300 diesel Benz (runs on fryer oil too!)
1998 E 300 TURBO DIESEL
Execution time: 0.261 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:17 AM
