"Win $100" Become a Supporting Member Click here find out how! "Win $100"
SSImpala65 (2)Woogeroo (6)gmgary (6)
mlc48 (3)tri5ss (4)monty56 (7)
1960 Sedan Delivery (3)
Nailheadv8 (5)
Art Morrison.com
Edlebrock July SpecialsMax Chevy.com
Hellwig Products IncClassic ChevyAmerican Auto Wire Performance Rod & Custom
The Car Guy GarageNewGMParts
Ciadella InteriorsGreg's OnlineShowwheelsusa.com
Impala Bob'sBob's Chevy TrucksBob's Chevelle PartsBob's Classic Chevy
"CT and its community has helped me so much in just the past few days as a member its unbelievable."
Join the ChevyTalk Mailing List Annual CT West Coast Get Together
Check out the post in SW Forum
Cruisin For a Cure 2010 (9/25)
Username Post: THE PIT STOP - Quick Reference Guide to Frequent Topics        (Topic#207493)
hilandr451
5th Year Gold Supporting Member and Moderator
hilandr451
Loc: Vacaville, Ca.
Reg: 01-02-02
01-16-09 09:16 AM - Post#1608421
This forum has been around for 10 years now and the number of conversations held within these "walls" is staggering. Equally amazing is the wealth of information stored here as a result of those conversations. However, sometimes accessing that information can prove a challenging, if not a daunting task.
In an effort to stream line this valuable resource I have put together a collection of links to the most frequent of those topics in one place to make it easier for you to access the answers you are looking for.
Please use the links below to access threads that might pertain to your questions. Once you are in a particular thread, feel free to add information or ask new questions as you wish.
---------------NEWBIES: DETAILED INSTRUCTIONS ON HOW TO POST PICTURES----------------- ---
Dee Dee's Picture Posting instructions
Hilander's "Posting Photos" with arrows & pictures and stuff.
---POWER TRAIN---
The Official 700R4 Transmission Swap Thread
Choosing the Right Manual Transmission for your Truck
---FRONT END & BRAKES---
'60-'66 Chevy/GMC Truck Disc Brake Conversion
Persh's Power Steering & Tilt Column Conversion
Hilander's Frontend Swap '89 3/4T Suburban to 1966 C-20
---DIFFERENTIAL & REAR SUSPENTION---
Gear Swap in a 12 bolt differential
---CAB INTERIOR & GLASS---
Door hardware/glass installation...what order does everything go in?
Wing Window Rubber
The "Official" Seat Swap Thread
Replacing Vinyl Bench Seat Covers
Steering Wheels
Big Back Window Conversion
---BED RESTORATION---
Making Your Own Bed Wood
Bed Wood Coatings: Product Tests
The "official" Bed Wood Coating Thread
---ELECTRICAL SYSTEMS & WIRING---
Fuel Gauge Problems?
90 ohm or 30 ohm fuel gauge & sender? (also side track: steering column ground)
Alternator Upgrades
Factory Tachometer Wiring
---MISCELLANEOUS---
Which Manual do I need?
A horn ring thread that turned into a "list of where can I find parts" thread
----------EXTERNAL RESOURCES----------
---ENGINE BLOCK IDENTIFICATION---
NASTYZ28 SBC Engine Block ID
YEAR-ONE'S Engine Identification Page
Yet Even More Engine Code Tables
---WIRING DIAGRAMS---
'60-'66 Scanned Wiring Diagrams (courtesy of Dave)
Highlander's simplified wiring diagram for '64-'66 Chevy truck headlight switch
Highlander's simplified wiring diagram for '60-'66 Chevy truck fuel gauge
How to use Bosch Relays: diagrams for every application, auto alarms, lighting, door locks you name it!
---TECHNICAL TIPS & IDEAS---
Technical tips page (courtesy of Dave, Woog & Persh)
Thanks for helping make this site the greatest '60-'66 Chevy Truck site on the web and the most comprehensive source for information on '60-'66 Chevy / GMC trucks, vans, panels & suburbans!
Check out the post in the SW regional forum
Edited by hilandr451 on 08-24-10 08:15 AM. Reason for edit: 08-24-10 added engine ID links
bobschevytrucks.com
bobschevytrucks.com
Execution time: 0.045 seconds.   Total Queries: 8   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:44 PM
