Username Post: Diagnosing Autoride?        (Topic#207370)
chrome_ashes
Loc: Columbus, OH
Reg: 11-27-02
01-14-09 01:48 PM - Post#1606909
The Autoride on my Yukon just stopped working in the past couple of weeks and I'm not sure if it's the compressor or the module.
I used to hear the compressor kick on every time I turned the key to the "On" position. Now I don't hear anything at the compressor - no clicks or anything.
Does anyone know of a way to diagnose it?
'04 Suburban SLT, 5.3L
'55 Chevy 3200 - sold
'57 Chevy 3200 - sold
LMC Trucks
chrome_ashes
Loc: Columbus, OH
Reg: 11-27-02
01-26-09 01:47 PM - Post#1616161
    In response to chrome_ashes
No one has any advice?
Bad Bowtie
Bad Bowtie
Loc: TX
Reg: 07-04-03
01-27-09 11:35 AM - Post#1616929
Sorry none of my vehicles have Autoride feature....
nstlga
nstlga
Loc: Colorado
Reg: 12-01-05
01-27-09 01:28 PM - Post#1617025
When I had my '01 Tahoe, the A/R quit working. It was one of the sensors at the rear axle area that was bad. Dealer fixed it under warranty at that time.
That system will set malfunction codes. There are 16 possible codes that can be set on an '01.
He who dies with the most toys doesn't necessarily win, but had more fun getting to the finish line.
chrome_ashes
Loc: Columbus, OH
Reg: 11-27-02
01-27-09 02:11 PM - Post#1617054
    In response to nstlga
That's what gets me... there are no codes or anything.
I've read about a lot of people having to swap the entire compressor unit because of water ingestion or the Autoride control module when it goes bad.
Do you have a list of codes for that system? I haven't seen them in my Haynes and I haven't ordered my set of Helms manuals for it yet.
nstlga
nstlga
Loc: Colorado
Reg: 12-01-05
01-29-09 05:08 PM - Post#1618677
DTC C0000, C0550, C0551, C0575, C0580, C0585, C0590, C0615, C0620, C0625, C0630, C0855, C0660, C0690, C0711, C0870.
There are at least 5 sensors in the system, a couple of relays, and 3 fuses. 2 of the fuses are in the center up by the battery, and 1 is under the dash in that fuse panel.
Chevyguy04
Reg: 05-23-05
02-04-09 11:30 AM - Post#1622539
lets us know if you find anything out...I am having the same problem on a 2002 yukon denali, just havent had time to look at it. I was planning on checking the sensors by the axles first. I live in Michigan and we drop tons of salt, so I am thinkning corrosion.
Scott
2012 Chevy Tahoe
2007 Yukon Denali
2003 Corvette 50th
2002 Chevy 2500HD
1969 Impala 396
1955 Chevy Pickup 427 450HP
1969 Camaro z28
Chevyguy04
Reg: 05-23-05
02-04-09 11:41 AM - Post#1622548
    In response to Chevyguy04
did some searching and found this......
hope it helps
http://www.tahoeforum.com/showthread.php?t=2795
Scott
2012 Chevy Tahoe
2007 Yukon Denali
2003 Corvette 50th
2002 Chevy 2500HD
1969 Impala 396
1969 Camaro z28
Chevyguy04
Reg: 05-23-05
02-04-09 11:49 AM - Post#1622554
also found this is the compressor or shocks are bad.
http://www.arnottindustries.com/
they carry the parts that GM overprices
Scott
2012 Chevy Tahoe
2007 Yukon Denali
2003 Corvette 50th
2002 Chevy 2500HD
1969 Impala 396
1969 Camaro z28
chrome_ashes
Loc: Columbus, OH
Reg: 11-27-02
02-04-09 10:37 PM - Post#1622972
I read about water ingestion possibly causing a problem. It might make sense for me as the system died sometime around the rainy week we had recently.
And the updated replacement from GM mounts something up by the gas filler neck to prevent water ingestion.
Bogart
Lurker
Reg: 02-05-09
02-05-09 01:26 PM - Post#1623270
My autoride is also somewhat failing. What are the FUSE LABELS to check? I was told RTD is one of them.
chrome_ashes
Loc: Columbus, OH
Reg: 11-27-02
02-05-09 02:14 PM - Post#1623290
    In response to Bogart
Define "somewhat failing."
I'm not sure about what other fuses he referenced above, but I know the RTD fuse under the hood is the main one for the Autoride.
LMC Trucks
Execution time: 0.326 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:48 AM
