Username Post: How to install a torque converter in th350        (Topic#200399)
tikiwagon
Loc: dorset, england
Reg: 04-23-04
10-06-08 02:08 PM - Post#1536437
Hi What is the best method to install the torque converter in a th350 box,Ive heard you have to hold it level and there should be 3 clicks as it engages?also do i put some fluid in it first(how much?)
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
10-06-08 02:38 PM - Post#1536455
    In response to tikiwagon
http://www.technovelocity.com/chevyhackers/tech_ar...
http://www.coanracing.com/PDFS/InstallInstructi ons...
http://www.partshp.com/ConverterInstructions .htm
http://www.transgear.co.nz/Installing-your-Hi-Sta l...
http://www.tciauto.com/Products/Instructions /instr...
these should help
Edited by grumpyvette on 10-06-08 02:47 PM. Reason for edit: No reason given.
68fastbak
Loc: fort lauderdale fl
Reg: 08-03-08
10-06-08 07:43 PM - Post#1536704
    In response to grumpyvette
fill'er up and pop'er in like my papy used to tell me
10-06-08 10:27 PM - Post#1536747
    In response to 68fastbak
pound it in with a hammer......then go buy a new pump.
tikiwagon
Reg: 04-23-04
10-07-08 01:53 AM - Post#1536786
    In response to bobb
Thanks for the links,Very helpful
Dave
BrianEsser
BANNED
Loc: North Star, Ohio
Reg: 06-30-01
10-07-08 05:30 AM - Post#1536846
3 clicks is common but not always the rule. Like when i rebuilt my current th350 for my S10 the convertor clicked once and slid into place. Depends if the stars are lined up and you have good karma that day I suppose.
Execution time: 0.258 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:59 AM
