Join the Community today
Username Post: 38 fuel gauge question        (Topic#199484)
navyson
navyson
Loc: California,USA
Reg: 01-12-06
09-23-08 02:01 PM - Post#1527939
I finished the wiring of my 38 and switched on the key and the original 38 fuel gauge needle popped into position. The gas tank is currently totally void of fuel. The problem is that the needle pops up to halfway between empty and a half tank. The gas tank is new from TANKS, INC. and the sender is new from CHEV'S OF THE 40's. I followed the installation directions for the sender to the letter. It seems that the gauge is getting more current than it's supposed to. Does anyoe know what's going on? An adjustment somewhere?
1938 Master Deluxe 4 door Chevrolet; 1964 Corvette, Sport Coupe
Royer
Needs to Get Out More Member
Loc: Bloomfield Hills, Michiga...
Reg: 09-25-01
09-24-08 03:20 AM - Post#1528291
    In response to navyson
If you disconnect the wire at the gauge unit that goes to the tank sending unit, you should see the needle move to and beyond the "Full" mark. If it doesn't, Id say your gauge (instument panel) unit is likely defective. Also, grounding the same wire momentarily should cause the needle to move to "Empty".
If both these checks are satisfactory, I'd suggest that you try pulling the sending unit from the tank and bending the arm a bit so that the potentiometer sits lower with the float on the bottom of the tank.
Royer
bowtiefan
bowtiefan
Loc: Vacaville, CA
Reg: 02-19-04
09-24-08 06:49 AM - Post#1528408
    In response to Royer
I just went through this last week on our 57 Corvette. Assuming the float is the same basic design as the Corvette, mounts to the tank from the top, you have to bend the arm down if it reads low and up if the gauge reads high. At first this seems backwards, but once you realize how it works, you'll understand.
Ken
38 & 39 2dr sedan, 41 coupe, 54 convertible, 56 Nomad, 57 210 2dr sdn, 70 Camaro RS, Corvettes; 57, 61, 65 396 coupe, 67 427 convert, 69 & 72 T-top, 88 coupe,91 ZR-1, 07 Z06, 16 Z06, 07 Silverado, 09 BMW 135i vert.
http://www.picturetrail.com/ken58
navyson
navyson
Loc: California,USA
Reg: 01-12-06
09-24-08 09:51 AM - Post#1528526
    In response to bowtiefan
Wow! I'm confused! Can you explain the arm bending principle to me. I thought the arm when down would have a low current flow , showing "empty" on the gauge and when the arm is all the way up the current flow is high showing "full" at the gauge. Adjustment of the float would just be for bottom of tank and top of tank.
I took this sending unit out of the original tank and put it in the new "Tanks, Inc." tank. maybe the float is sitting different in the new tank and the potentiometer is registering a quarter tank of gas instead of empty?
Edited by navyson on 09-24-08 10:19 AM. Reason for edit: No reason given.
navyson
navyson
Loc: California,USA
Reg: 01-12-06
09-24-08 10:24 AM - Post#1528544
Royer,
This must be what you are telling me to do, for the empty position, bend the arm so the potentiometer is at the lowest point and the float is at the tank bottom?
Royer
Reg: 09-25-01
09-24-08 10:26 AM - Post#1528546
And the arm could very well have been bent slightly in the process of removing it from the original tank, while it was out laying on the bench, or during installation into the new tank. Trust me, you need to assure that the POTENTIOMETER is in the "Empty" position when the FLOAT is in the "Empty" position.
And make certain that the tank has a good solid ground to the frame (I recommend running a dedicated wire or ground strap) as too often the nicely painted surfaces on a restored vehicle present more problems in this regard than did the original as it came out of the factory seventy years ago.
Royer
navyson
navyson
Loc: California,USA
Reg: 01-12-06
09-24-08 03:02 PM - Post#1528725
Royer
Looks like it's going to be a troubleshooting weekend!
Thanks!
bowtiefan
bowtiefan
Loc: Vacaville, CA
Reg: 02-19-04
09-24-08 07:51 PM - Post#1528947
Yes, you bend the arm as you said, but you need to check the 'full' location also. On my Corvette, when I raised the arm to the 'full' location, the float was actually higher than the mounting plate where it goes into the tank. What I did was fill the tank and then bend the arm until it read full on the gauge. (Since the tank is right behind the seat, I could see the gauge as I made the adjustments. You don't have to totally mount the sending unit to the tank to check it, at least I didn't on the Corvette, but be sure that the bracket is parallel with the mounting surface. A little bit off there translates to a bigger difference on the sending unit and thus an inaccurate gauge reading) Don't know where it will read when empty, haven't used up enough gas yet. If you have an empty tank, it might be easier to adjust to empty, and not worry about the 'full' location. You'll find that out when you eventually fill it up.
At least, this is how mine went, so hopefully it will give you some idea of what you might be up against. Good luck.
Ken
navyson
navyson
Loc: California,USA
Reg: 01-12-06
09-25-08 03:20 PM - Post#1529439
Thanks Ken,
I'll be taking the tank back out this weekend for the sending unit adjustments. Hopefully a bend here and there will tweek it to the right reading.
David Hayward
Deceased RIP David
David Hayward
Loc: New Forest, UK
Reg: 04-10-99
09-25-08 11:39 PM - Post#1529689
I am making this thread sticky as it is of such interest.
Royer
Reg: 09-25-01
09-26-08 03:27 AM - Post#1529719
I haven't worked on a '38 model year Chevy gas tank myself, but are you sure that pulling the tank is necessary? Usually there is a small acces panel in the trunk floor that can be removed to access the sending unit. And if there isn't, you might want to consider cutting such an opening (which can be closed with a piece of sheet metal after working on the sending unit) rather than going to the trouble of pulling the tank.
Royer
bowtiefan
bowtiefan
Loc: Vacaville, CA
Reg: 02-19-04
09-26-08 06:00 AM - Post#1529792
If you are going to remove the tank, my thought would be to make sure that you set it so that it is in the same position as when it is in the car. Then use some jumper wires, including ground, so that you can see the results of your adjustments without having to replace the tank. In theory, this ought to work!
Good luck
Ken
navyson
navyson
Loc: California,USA
Reg: 01-12-06
10-01-08 01:44 PM - Post#1533189
Yes, in order to get to the sending unit the gas tank needs to be dropped down.
navyson
navyson
Loc: California,USA
Reg: 01-12-06
10-01-08 01:54 PM - Post#1533195
Here's the results of last weekend: I dropped the gas tank and removed the sending unit. It was positioned wrong and was hitting the curved side of the tank. I read the installation directions and adjusted the float so it hit bottom when the tank is empty. I carefully measured and remeasured. I then reinstalled and repositioned the sending unit as it described. Then I did what you have described exactly. The gauge needle popped up to a quarter of a tank! It is till a mystery. Seems like it is getting too many amps or something. I even tried my really old sending unit with the gauge, same thing. Could the old gauge be to weak to resist the amperage flow or something? I don't think the needle is bent, it is otherwise in good shape.
bowtiefan
bowtiefan
Loc: Vacaville, CA
Reg: 02-19-04
10-01-08 07:14 PM - Post#1533426
I know it's a PITA, but try bending the arm so that it is at the top when full and let the empty be where ever it ends up and see what happens. Beyond that, you are talking electrical and I only do mechanical.
Ken
Royer
Reg: 09-25-01
10-02-08 03:04 AM - Post#1533530
Forget about putting the sending unit in the tank for a minute. Simply connect the sending unit to the wire which runs up to the instrument panel display unit and connect a temporary grond wire from the body of the sending unit to the negative battery terminal. Turn the ignition key "on" and see if you can get the display unit to read "Empty" at some point. And see if you can get it to read "Full" at some other position of the float. If you can't, then try running a new wire from to connect the sending unit to the instrument panel fuel gauge display. If you still can't achieve both "Empty" and "Full" readings at some position of the float, you have either a defective sending unit or disply unit.
I'd suspect the sending unit if the gauge can be made to read "Empty" with the ignition off.
Royer
David Hayward
Deceased RIP David
David Hayward
Loc: New Forest, UK
Reg: 04-10-99
10-02-08 11:39 AM - Post#1533799
I am discounting a holed sender unit float..they did and do rust and you can get a pinprick hole not visible to the naked eye! However, I suggest that you do check the 'business end' anyway.
David Hayward
Deceased RIP David
David Hayward
Loc: New Forest, UK
Reg: 04-10-99
10-04-08 02:14 PM - Post#1535270
    In response to David Hayward
This may be of some interest: a link to the gas gauge page in the '38 Shop Manual:
http://chevy.oldcarmanualproject.com/shop/1938/38c...
navyson
navyson
Loc: California,USA
Reg: 01-12-06
10-11-08 06:26 AM - Post#1539580
David,
Thank you for the 38 Chevy on-line manual. So far it appears that there is too much current flowing through the fuel gauge when the tank is empty. This is probably due to not enough grounding. I am still doing tests to see if an additional ground will decrease the current flow to the gauge when the tank is empty.
Thanks!
Royer
Reg: 09-25-01
10-11-08 07:55 AM - Post#1539631
The addition of a dedicated ground wire from one of the retaining screws on the tank sending unit to a good, solid ground on the frame will NEVER do any harm.
Royer
David Hayward
Deceased RIP David
David Hayward
Loc: New Forest, UK
Reg: 04-10-99
10-11-08 09:23 AM - Post#1539665
I agree with the very 'well-grounded' suggestion!
Don D
Loc: SC, USA
Reg: 04-13-06
03-07-09 04:32 PM - Post#1646093
I also have an issue with my 1939 Master Deluxe fuel gauge. I replaced the fuel tank and float assy. With the float assy removed and connected to the gauge (tank side)with key on, I move the float from empty position toward full the needle drops below the empty mark. Move the float position back to empty the needle moves up to the empty mark on the gauge. Wires are connected per my 39 wiring diagram. Any suggestions. Ground is good.
39 Chevy Master Deluxe, 216 engine
Royer
Reg: 09-25-01
05-09-09 10:58 AM - Post#1694316
    In response to Don D
Are you certain that the replacement sending unit is really correct for your car? It sounds to me as if the resistance range (from the "Full" to the "Empty" positioned isn't correct for this application.
Royer
navyson
navyson
Loc: California,USA
Reg: 01-12-06
05-21-09 06:05 AM - Post#1701879
Hi Royer
Good question! I bought the sending unit from Chev's of the 40's so I don't know anything about the sending unit's resistance vs the gauges. I have put in about 2 gallons of gas in the tank and it still doesn't register anything but empty. When I turn on the ignition the gas gauge arm jumps into position to about 1/8 of a tank. I did all the test that have been mentioned previously except grounding the tank. I felt the tank is grounded to the engine via the stainless steel fuel line to the fuel pump. It is still a mystery and I have been reluctant to fill up the tank and have the gas gauge register empty. I would have to either use up all the fuel, 14 gallons, or drain the tank to fix the problem. The gas gauge passed all of the test procedures so I know it's the sender that might have the problem. Seems like it's getting too much amperage or something. It's still an unsolved problem.
gary635g
gary635g
Loc: Oldtown Idaho Yuma Az
Reg: 10-28-09
09-25-10 05:24 AM - Post#1980663
Just replaced sending unit on 41 Chev from chev of the 40's 2 and 1/2 gallons barely move gage off mt another 5 moves to 3/8 ohm Readings 0 mt 30 full.Gary
gary635g
gary635g
Reg: 10-28-09
02-03-11 03:16 AM - Post#2041351
    In response to gary635g
Still working this problem. The phonelic(sic) float would only lift the sending unit i/2 I told Chev of the 40's they provided me another unit because they do not have only the floats. Re-installed yesterday with two floats and added 7 gallons reads 1/2 will see how it does when filled. Poly tank being only 6 inches deep where unit goes in aggravates the problem.
Execution time: 0.253 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:48 PM
