Username Post: Blast Cabinet vacuum/filter        (Topic#197304)
CharlieC
CharlieC
Loc: Flower Mound, TX,
Reg: 03-27-02
08-26-08 09:24 AM - Post#1508054
After using my Bead Blaster w/o a vacuum, I realized it was going to be a constant issue with glass bead squeezing out of the smallest cracks and making a mess around the cabinet and visibility while blasting, always a bit tough.
I read about this somewhere on the internet, but basically built a water pipe for my cabinet. Those of you with "adventureous" teenage years might remember how those worked...
Took a pool chemical bucket (need one with a top),
    cut two holes
    insert one piece of PVC extending close to the bottom
    insert another fitting that goes into the bucket but does not touch the water
    fill bucket halfway with water
    put your top on
    attach the pipe extending into the water to your bead blasting cabinet.
    attach the pipe that is NOT in the water to your vacuum. ($2 at a garage sale)
You know have a Blasting Cabinet vacuum setup you can use with any vacuum which keeps the beads in the cabinet and you can actually see what you're doing while blasting.
Charlie
'74 K5 Blazer 4x4
'14 Ram 2500 Diesel MegaCab 4x4
BigDogSS
BigDogSS
Loc: SoCal
Reg: 12-21-01
08-26-08 01:46 PM - Post#1508277
    In response to CharlieC
Hi Charlie,
I built one of these a couple of years ago and it works great!! Thanks for the post.
BTW, here is where I got the instructions from, and maybe you did too: Glass bead dust collection system
Matt
Matt
Loc: SAV
Reg: 09-26-01
08-27-08 07:13 AM - Post#1508770
    In response to BigDogSS
I guess I didn't have an adventurous life when I was a kid. I don't understand how this works.
From the best I can understand.... the bucket traps the sand while you're vacumming, so that the sand isn't ruining the vaccum - right?
Big Steve
Big Steve
Loc: Riverside, CA
Reg: 04-17-06
08-27-08 08:13 AM - Post#1508811
    In response to Matt
From what I've been told, back in the 70's this would be known as a bong. Of course I would have no first hand knowledge of such an item. This is a very cool idea, and looks to be a tremendous solution to a vexing problem. I love it when a problem can be solved on the cheap!
I may be getting older but I refuse to grow up.
'99 Suburban - sold my '93 extra cab sportside
CharlieC
CharlieC
Reg: 03-27-02
08-27-08 11:11 AM - Post#1508941
    In response to Matt
Matt,
Think of the water as simply a filter for the vacuum. The dust/beads floating around in the cabinet get sucked into the water, vs directly into the vacuum.
The other purpose is to also vent the air pressure you're putting inside the cabinet while using it.
Charlie
'74 K5 Blazer 4x4
dzl9y4
Loc: Missouri
Reg: 08-19-07
08-27-08 03:59 PM - Post#1509129
There's system like this that I brought from home depot (I think) when doing the sheet rock in my garage. It has a vented sanding head for that mesh type grit cloth. Hose sucks dirty air from hand pad to pail, bubbles thur the water an clean air is pull out to the vacuum unit.
After about three hours of sheet rock sanding I'd have a couple of inches of stuff in the pail an very little on the floor. It worked great.
Current Cars:
1947 Chevy Coupe, Street Rod. SBC 700R4 PS PB Air
1957 Bel Air 2DrHt. 427 SBC 6Spd Man. PS PDB Air
1962 Impala SS 2DrHt 327 Auto PS PB Air
wings59
wings59
Loc: Bakersfield Ca
Reg: 01-30-05
08-27-08 07:18 PM - Post#1509269
I like it ..Looks easy enough to make.
Larry
Larry
59 Impala Sport Coupe
36 Dodge Street rod..........owned 27 years
Gray Headed Mule
Gray Headed Mule
Loc: Fort Worth, Texas
08-28-08 10:20 AM - Post#1509648
    In response to wings59
You can buy a miniture one from a "head shop"!
Mule
I'm sexy and I know it!
My 49 Chevy Fleetline Deluxe Restoration Project
wings59
wings59
Loc: Bakersfield Ca
Reg: 01-30-05
08-28-08 07:45 PM - Post#1510034
    In response to Gray Headed Mule
Larry
BrianEsser
BANNED
Loc: North Star, Ohio
Reg: 06-30-01
08-29-08 08:35 AM - Post#1510334
This is one reason why I love CT!
jeffs55
jeffs55
Loc: Shelby Forest, Tennessee
Reg: 01-05-06
02-22-12 02:40 PM - Post#2193911
    In response to BrianEsser
Hey Mule! You been lurking for a while?
Haven't seen you post lately.
Or have you been on the 49-54 forum?
I like the big bong theory, I may have to do me one.
FIRE IT UP!
Jeff
55 Handyman
66 F100 project
32 3 Window Coupe project
1948 Studebaker Champion
1977 Toyota Celica Coupe
2000 Blazer 4X4
My Pics
az58cameo
az58cameo
Loc: Payson Az
Reg: 11-16-09
02-22-12 06:07 PM - Post#2193981
    In response to jeffs55
I NEVER Inhaled, Nor Did I Have SEX With That Woman!
Execution time: 0.548 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:17 PM
