Username Post: 6V to 12 VOLT CONVERSION        (Topic#196833)
Smokey
Senior Site Adminstrator
Smokey
Loc: "Small town USA"
Reg: 12-06-99
08-19-08 08:45 PM - Post#1503322
A BIG Thanks to Bob Hayden for his hard work on this:
http://chevy.oldcarmanualproject.com/miscellaneous...
RadioGuy
RadioGuy
Loc: Victoria BC Canada
Reg: 12-24-01
04-24-09 12:26 PM - Post#1684158
    In response to Smokey
I am thinking you are going to have to do a lot more to your 6 volt tube radio than just replace the dial bulb! I know in the old days you would try to drop the voltage to the radio with a heavy duty resistor but I certainly don't recommend that today. There are qualified people who can convert your 6 volt radio to a 12 volt radio. You have two chcices.
Antique Automobile Radio in Florida http://www.radiosforoldcars.com/
has an extensive dealer network that can install their 12 volt FM conversion internally. This is a high quality product that allows you to run a stock or custom speaker configuration. Everything internally is removed except the antenna input and the tuner. Exterior look remains completely stock. Costs run $400 - $500.
The second alternative is to find a radio service centre that is fully qualified to convert the radio to 12 volt and maintain it as a tube radio. There are several things that must be done including changing the vibrator and transformer. Most 6 voilt tubes have a 12 volt equivalent but there are load differences and the new tubes usually need to be balanced with an additional resistor or two to perform to peak capability. Cost is likely in the same range as the conversion, more if the radio is original and needs some up-grading to modern capacitors etc.
Actually a third alternative would be to buy a repro radio from Antique Automobile or one of their dealers.
formerly "seshea"
Stephen Shea
Victoria BC
1957 Belair 2 dr hdtp
arnieg141
arnieg141
Loc: nj
Reg: 10-06-08
05-05-09 02:31 PM - Post#1691847
    In response to RadioGuy
go with the voltage steep down for a couple of bucks and they sell fm converters for abot $30.00 that just plug in your anteni wire and tuck under dash or buy an am/fm/cd sterio they sell $35.00 up and stike it in glove box or under dash don't just waste your money unless your building a 100 point show car
Edited by arnieg141 on 05-05-09 02:50 PM. Reason for edit: No reason given.
Royer
Needs to Get Out More Member
Loc: Bloomfield Hills, Michiga...
Reg: 09-25-01
05-12-09 10:14 AM - Post#1696316
Had you considered the alternative of a small six-volt motorcycle/lawn tractor battery in the trunk just for powering the radio? Much cheaper than any of the alternatives mentioned so far, and charging with a trickle charger once a month or so should be plenty.
Royer
05-12-09 08:59 PM - Post#1696675
    In response to Royer
Good to see you post Royer.
People have been wondering where you were.
chaimv
Reg: 11-27-08
05-30-09 02:31 PM - Post#1707625
Hi Guys
I was wondering can i use the origional ignition swith and starer button from my 6V system when i do the conversion to 12V or do i need a new swithc
thanks
arnieg141
arnieg141
Loc: nj
Reg: 10-06-08
05-30-09 02:35 PM - Post#1707629
    In response to chaimv
YES ON BOTH
05-30-09 08:26 PM - Post#1707854
    In response to arnieg141
LOL Yes, on using the original ignition switch and button. No you don't need a new switch.
arnieg141
arnieg141
Loc: nj
Reg: 10-06-08
05-30-09 11:45 PM - Post#1707923
    In response to Bob_Hayden
what he said
chaimv
Reg: 11-27-08
05-31-09 07:29 AM - Post#1707997
thanks
WARCOY99
Loc: ROUND ROCK,TX
Reg: 07-08-05
06-05-09 11:52 AM - Post#1711615
DO you have a diagram of the wiring for a 6 to 12 volt? my car works fine, but i have to unhook the battery or the battery dies when off. I;m not sure what it is but its not that anything is left on.
06-05-09 04:39 PM - Post#1711765
    In response to WARCOY99
Disconnect your alternator when you shut the engine off, including the plug-in connector, and see what happens then.
KaelFarmer
Loc: Eau Claire, WI
07-01-09 10:15 AM - Post#1727103
To get your car to stop running when turning off the ignition switch, use a DA plug for the alternator. It looks like the standard plug for the alternator, except it has a diode built into the excitor wire. Many aftermarket retailer sell them for about $20, but if you have a starter/ alternator rebuilding service locally you can probably get one for about $10.
It will have 2 wires (one red with a ring terminal and either a black or yellow one). Connect the ring terminal to the battery post on the back of the alternator. Connect the other wire to a switched positive conection (positive terminal of the coil works well)
Kael
WARCOY99
Loc: ROUND ROCK,TX
Reg: 07-08-05
07-01-09 11:41 AM - Post#1727155
thanks i'll try it...sorry for the delay but i never got noticed that you replied.
OLD CAR
Loc: OREGON
Reg: 05-29-01
10-16-09 12:15 PM - Post#1789314
I use a volt-a drop which is a now called a "voltage reducer" One wire off the battery to the unit mounted in front of the radiator on a bracket to disapate the heat when Iam driving and then a wire to a fuse and then to the radio and that been working great for years now.
www.fillingstation.com #FS-129.
54infrance
Loc: france brittany florida n...
Reg: 02-27-10
03-08-10 12:59 PM - Post#1876255
    In response to OLD CAR
Do you need to change anything on the convertible motor or switch when going from 6 to 12v?
Chris Jones
ChrisQ
ChrisQ
Loc: Washington, DC
Reg: 12-11-09
03-18-10 11:36 AM - Post#1882233
    In response to 54infrance
This is probably dumb question. I have a marine battery in belair right now. Is that bad? Is there a paticular 12Volt battery I should be getting?
arnieg141
arnieg141
Loc: nj
Reg: 10-06-08
04-21-10 01:10 AM - Post#1902198
    In response to ChrisQ
MUST READ ON GAS GAUGE http://www.fifthaveinternetgarage.com/tech_tips/te...
OLD CAR
Loc: OREGON
Reg: 05-29-01
05-15-10 04:41 PM - Post#1915417
I dont think so use a seperate wire from the voltage reducer run it through a switch and than the top motor it will have a circuit of its own.
ralph47
ralph47
Loc: new franklin, ohio
Reg: 10-28-08
05-15-10 05:18 PM - Post#1915448
watch using a voltage reducer with a high amp load like that...12v to that motor may not hurt it
54 Chevy Handyman Wagon
48 Chevy Pick Up
39 Chevy Coupe
62 Olds F85 Cutlass Convertible
http://s370.photobucket.com/albums/oo148/ralph47_ p...
BIGDADDY5
Reg: 05-24-10
05-24-10 09:39 PM - Post#1920201
    In response to ralph47
I'm new here and new to fixing up cars. I have no idea what i'm doing. I want to rewire a 1949 fleetline from a 6v to a 12v. can you tell me where to start.
ralph47
ralph47
Reg: 10-28-08
05-25-10 05:47 AM - Post#1920276
    In response to BIGDADDY5
start with the other posts here..and pay attention to gas gauge postings.
12 v generator and regulator..although it seems a lot when changing to 12v switch to internal regulated alternator. of course all the bulbs, radio voltage reducer..maybe a 12v starter solenoid..not all change...starter motor should be ok, some say heater motor will be fine too...don't quote me on that though.
48 Chevy Pick Up
39 Chevy Coupe
BIGDADDY5
Reg: 05-24-10
05-25-10 09:58 AM - Post#1920375
johnnymv1
johnnymv1
Loc: Phoenix, AZ
Reg: 04-15-11
06-05-11 01:01 AM - Post#2099490
So im getting started on my 12v conversion and i have a couple questions. First of all im keeping the generator getting it converted to 12v to keep the original look so heres my questions does my 54 belair have a ballast resistor and if so where is it, I need a 12v coil with an internal ballast resistor does anyone have a part number for me? also need the part number for a 12v voltage regulator Or can i just use the parts from a 55 belair? I know you fine getelmen can help thanks in advance.
h0tr0d18
Loc: Fort Mcmurray, Alberta
Reg: 02-28-11
06-07-11 07:58 AM - Post#2100434
    In response to johnnymv1
Did you ever get an answer on this johnny? I am looking to convert my 53 to 12V and I have a 12V generator, just curious if I need anything else to run that generator?
Dean50
Dean50
Loc: Detroit area
Reg: 01-02-07
06-08-11 04:27 PM - Post#2101114
I'm sure you can use any generic 12V stuff. My car was 12V when I got it and has a small coil with internal ballast and Delco-Remy 12V voltage regulator. I would think any NAPA or such would have the parts. The list at the beginning of the thread is pretty thorough.
Good luck. Don't forget about changing all your bulbs, flasher etc.
Dean50
OldJules
Reg: 05-27-10
07-24-11 09:50 AM - Post#2117422
I would sure like to hear of a good solution to the gas gauge problem in the 6V to 12V swap. I'm aware of the voltage reducer. I had a reducer on mine and it apparently burned out or whatever they do and allowed 12V to the reciever, so now the reciever shows full all the time, I assume it's shot. Does the 6V sender work if I have the receiver converted to 12V.
Edited by OldJules on 07-24-11 10:05 AM. Reason for edit: No reason given.
Zombie Dave
Loc: Wichita, Kansas
Reg: 08-20-05
09-26-11 07:20 PM - Post#2141184
    In response to OldJules
Is this the same for 52 Chevy conversion ? I have a 52 and it's been converted. I'm just not sure yet that all the steps were taken and parts were swapped. Fuel gauge doesn't work and something is draining the battery.
1964 Impala
305 Engine
Edited by ratrod67 on 09-26-11 07:21 PM. Reason for edit: No reason given.
worthop
Loc: N.Y.C.
Reg: 11-08-11
11-08-11 08:48 PM - Post#2156009
    In response to Zombie Dave
I think I may be missing something regarding the headlight wiring....it looks like the headlight harness is connected to the Batt terminal of the voltage regulator....what did you guys do with that?
Rukee
Reg: 02-01-12
02-01-12 12:35 PM - Post#2185960
    In response to worthop
Hey guys, first post, please bare with me.
Have a `49 Deluxe 4dr here that someone put in a 350 csb w/single wire alternator. Trying to convert the system to 12v, have all the bulbs swapped but don't know were to put the reducer for the gas gauge. I can hardly see behind the dash at all!! Is there a convenient location to wire it in?? Also the parts list showed a IR4 from NAPA for the gas gauge, but it's discontinued, they gave me a IR1 instead, is that going to be an issue?
Edited by Rukee on 02-01-12 12:36 PM. Reason for edit: No reason given.
Execution time: 0.18 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:16 AM
