Username Post: A/C all of sudden blows hot air        (Topic#195357)
Jimmy Foxx
Reg: 07-30-08
07-30-08 06:17 PM - Post#1488845
Well. A/C is blowing hot air. Driving home from work it was blowing nice cold air, then i just fell hot air. the A/C low pressure lines our cold, but not cold air.
any suggestions?
CaptainK
CaptainK
Loc: Maryland
Reg: 02-25-02
07-31-08 03:52 AM - Post#1488990
    In response to Jimmy Foxx
What year & model truck?
Might be low on freon, bad pressure switch. Did the air stay hot or did it ever cool back down?
Welcome to the site
'99 Silverado (NBS)
elcamino
elcamino
Reg: 03-30-00
07-31-08 05:56 AM - Post#1489035
Low Pressure Switch
My 2001 GMC would do this. It was still under warranty so I had the dealer check it out. Been over 6 yrs but I seem to recall it being a low pressure switch.
Prior to finding the bad switch I had a hard time convincing them it would go cold to warm in a heart beat. They sat in shop with motor running and it blew cold. I convinced the sm to take a ride with me and 5 miles down the road it went hot just like I said. He was convinced, it was 92° that day. I guess the vehicle movement is what make the switch short out.
When he showed me the bad switch you could see a greenish tint on the terminals. Never acted up again. They had to take one from a new truck on the lot as I was not willing to leave without the A/C fixed. It was either that or give me a loader.
2016 Polaris RZR 900 EPS
DeLong
Banned Member
Loc: Rural Illinois
Reg: 06-06-02
07-31-08 07:02 AM - Post#1489072
    In response to elcamino
My Ferd work truck did this and they said it was the fan clutch. Im not to sure they were right since it still does it once in a while. I just figure its part of driving a ferd.
00 Yukon SLT XL 5.3
98 Lumina Police Package 3.8
88 2500 4X4 5.7
87 Mustang LX 5.0
67 Mustang Fastback 289
65 Mustang Fastback 289
Jimmy Foxx
Reg: 07-30-08
07-31-08 06:05 PM - Post#1489556
    In response to DeLong
it doesn't cool down, i tried putting a shot of r-134a+. it;s a 99 silverado 4x4 standard. low pressure switch would turn the compressor on and off. down thing it;s that because i got cold low pressure lines. unless the switch controls the hvac. same with the clutch. either way im going to look into it. you never know
kvet
Loc: Maine
Reg: 09-23-08
09-23-08 02:43 PM - Post#1527921
I have a 2000 silverado that had a similar problem. I changed the thermostat but it didn't fix the problem. I had the heater core flushed and it's as good as new. There is a kit you can buy to do it yourself but I had my local mechanic do it for about $80. Hope this helps.
kvet
Loc: Maine
Reg: 09-23-08
09-23-08 03:21 PM - Post#1527959
    In response to kvet
Sorry, I gave bum info. I had the heater blowing cold air, that's why I had the heater core flushed. Sorry had a dislexic moment.
chevyjim
Loc: Florida, USA
Reg: 10-20-04
09-24-08 12:04 PM - Post#1528568
My 04 Sub does that on the drivers side occasionally, while the passenger side is still blowing ice cold. Check the door motor that regulates heated air to maintain temperature. Mine just gets confused, cycling the ac switch or temperature control works for me.
Jim,
Merritt Island, FL
2004 Suburban
2000 Blazer
SC_Paul_66
Loc: Upstate SC
Reg: 10-07-08
10-07-08 01:28 PM - Post#1537192
    In response to chevyjim
Our 06 work truck does the same thing. It goes from COLD to HOT. Not - from cold to not as cold. But from A/C to Heat. One way to get the heat off is to simply turn the truck off. I have to do it all the time while out making deliveries. I even do it while going down the road. I know that is not smart but on hot days you do what you have to do.
Execution time: 0.819 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:22 PM
