Username Post: 305 distributor in a 350 motor        (Topic#179385)
bowtie454
Loc: pleasant grove,alabama
Reg: 04-25-07
01-11-08 09:47 PM - Post#1340801
I just finished a very successful engine swap in my 1985 silverado.I ditched the old 305 paperweight and installed a 350 but i am using the 305 distributor.The 350 is a real brute and runs very strong but am i short-changing myself on performance with the 305 distributor? I'm just wondering if there is any performance difference between the two factory distributors since there are more cubic inches in the 350.thanks.
Limey Tri Chevy
Limey Tri Chevy
Loc: Hertfordshire, England U...
Reg: 10-19-05
01-11-08 11:28 PM - Post#1340838
    In response to bowtie454
The curve may be slightly different from that of a 350 dizzy but not that much to matter unless your trying to squeeze every available hp from the engine. I don't know if your running a carb or inj' with an ECU in your truck. I guess it would make more of a difference if you had a 305 ECU operating a 350 engine that the dizzy it'self.
'57 Bel Air 4dr wagon
'57 210 2dr. 9.3 @ 155 mph 0-60 in 1.47 seconds
'55 Bel Air 2dr
'02 H/D Lightning
'08 Anniversary Custom 1200 Sportster
'30 Model A sedan
My pics
Bad Bowtie
Bad Bowtie
Loc: TX
Reg: 07-04-03
01-12-08 07:49 AM - Post#1340924
    In response to Limey Tri Chevy
I will work fine stock. I would recommend u visit performance distributers or summit racing and add the coil, module, and brass terminal dist cap/rotor kit they sell. It will help "liven" things up a bit!
It's not manditory, heck, u could add it on later down the road as well...
bowtie454
Reg: 04-25-07
01-15-08 08:04 PM - Post#1343651
    In response to Bad Bowtie
thanks!i just added headers and new dynomax raceflows..sounds SWEET!I'm definitely considering an ignition upgrade later on but i just replaced all the distributor guts with oem style ac delco parts and its doing really well...SMOOOTH!
Execution time: 0.284 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:32 PM
