Username Post: screw hole for distributor cap screw        (Topic#179322)
cptkid570
Reg: 05-02-03
01-11-08 08:18 AM - Post#1340267
Ok,
Trying to reinstall my distributor cap and the threaded hole in the distributor that the screw for the distributer cap goes into broke! I now realize that it’s plastic. I’d think it would be more durable. Maybe mine is just old and brittle. It broke straight across the hole. I didn’t over tighten it or anything.
Anyway, has anyone ever had this happen to them? If it was the cap that broke, it would be an easy fix, but this is the part on the distributor. Anyone have any suggestions on what to do? I’m hoping that maybe there is enough plastic left under there that I can get a nut to wedge under it and just use a longer screw with a nut. If that doesn’t work, what are my other choices without having to buy another distributor? Use some RTV gasket maker and just seal it down???
CDAUSA
Needs to Get Out More Member
Loc: Texas Panhandle
Reg: 12-31-01
01-11-08 09:59 AM - Post#1340346
    In response to cptkid570
Yes, it has happened numerous times and reported here with the same issues. I've only fixed one for another guy and lucky or not, he had an intake leak that he had been putting off so the fix was involved at that time. But up until the time he did the fix, I did make a small tab with a hole in it, long on one side to fold under the body and use a longer screw and nut to hold it.
Most have fixed theirs with either a new distributor or like this one, I got a new body and moved the guts of the old over into it. But most of their ideas of "new" meant rebuilt from a "zonz" store and that is not something I would choose.
I've also seen people use a loop of wire over and under the body of the distributor, then just twist tight. Maybe one of those long plastic zip-ties would be a better choice.
But for me, I would choose one of those options til it was time for it to come out.
I've always re-used the original screws that came in mine, and just snug it down. I'm knockin on wood too.
cptkid570
Reg: 05-02-03
01-11-08 10:36 AM - Post#1340377
    In response to CDAUSA
I also wish the screws were just phillips head and not the hex that they are, but that's a whole different point..haha
Thank you for your ideas, I appreciate it very much.
Phazer
Phazer
Loc: Armpit of the Universe
Reg: 10-10-03
01-11-08 01:16 PM - Post#1340496
Related but not the same. OEM screws for the flat/horizontal cap are #10475922 and retail for $1.24 each. Also listed are "oversize" screws for stripped holes, #10457666 and retail for $6.21 each.
Needless to say, that's an "ouchy" price, but at least they list them in case they strip out.
My "To Do List" for this weekend:
Nothing but womens names...
and drugs....
92 Bravada
96 Sunfire
00 Impala
05 Stratus
90 Wrangler
77 Cub Lo-boy
87 Intruder VS700
95 Intruder VS1400
cptkid570
Reg: 05-02-03
01-11-08 01:18 PM - Post#1340498
    In response to Phazer
Good info.. problem is, mine didn't strip out, the tab that the screw hole is in broke (1/2 of it broke off)..
01-11-08 02:34 PM - Post#1340536
Yep, you're at the crossroads of rig it or replace it. I've seen some manage to get it held down with a zip tie on the side with the broken tab, but that's a last ditch effort if you ask me. You don't want the cap wiggling or cock-eyed.
Just be sure that since you're a Vortec, when you do go to replace the distributor, mark not only the position of the distributor body but the rotor as well. They both need to be very, very close back in place when you stab the new distributor or you'll have heck getting it to run right. Then, you may still need to fine-tune the timing with a Tech II or similar scanner.
CDAUSA
Reg: 12-31-01
01-11-08 03:06 PM - Post#1340559
I'm not sure if I understand your concerns, but that I rigged up I just used a machine screw with a self locking nut, washer and tab. It's a booger to get to though.
What I referred to in using a zip tie, is going full circle around (over the top) the cap and hooked under the body of the distributor. Going inbetween chosen terminals of the cap to keep it centered. Get the cap centered and that thing pulled tight, it ain't going anywhere.
cptkid570
Reg: 05-02-03
01-14-08 07:23 AM - Post#1342435
I was going to use a screw with a nut on it, but the screw I'd gotten didn't match the threads perfectly, but it worked out well because the new screw somehow grabbed onto the tab and held it down, so all is good. If need be, I will get in it with a nut, but all seems fine.
Execution time: 0.277 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 06:11 PM
