 Page 1 of 31 1234>» Last
Username Post: 409 Dual Quad 4spd BA 6 Pass Station Wagon Find        (Topic#178113)
mmmaxwe
Reg: 12-28-07
12-28-07 04:05 AM - Post#1328615
Need some tech advice and/or someone who knows about early Chevy Station Wagons.
My buddy and I have recovered a mostly complete 62 Bel Air wagon 6 Pass. with the 409 2x4, original 4 spd car, less tranny, with a siren and a large set of radio transmitters in the rear of the car. I would like to hear some thoughts about this car and would like to find someone knowledgeable about these special cars. Car is mostly complete and will need a total restoration. Has what appears to be a factory mounted tach, (7K) on the column.
Currently researching all of the numbers and seems to be a numbers correct car. I will post photo's soon as I am waiting for the paper work to finalize and will do so soon.
The car will need to be completely restored as it has been sitting since the late 60's.
Contact information and thoughts would be appreciated.
LongIsland63SS09
LongIsland63SS09
Loc: Long Island, N.Y.
Reg: 11-08-03
12-28-07 10:18 AM - Post#1328773
    In response to mmmaxwe
Mike,
Welcome to Chevytalk!
Sounds like an interesting find. Possibly an old police car.
Post some pictures when you get a chance. Also post a picture of the cowl tag.
Thanks,
1963 Impala SS 409/340HP (Original Engine)
Saddle Tan/Saddle Tan, Tilt Steering Wheel, Factory Black Vinyl Top, 3:36 Posi, 4-Speed.
Anytime
Anytime
Loc: Chico, CA
Reg: 05-23-06
12-28-07 10:31 AM - Post#1328779
If it has the original motor, it is indeed a rare car and worth restoring. Check the motor ID pad on the passenger front side of the motor. It is just below the head on the deck. There should be two sets of numbers. The first will be a letter followed by a series of numbers. Those numbers should match the last part of the car's VIN ID number. The second set will start wit a T and if it was a 425HP block will end with a QB.
Mick
1964 Impala SS 409 - 400HP 4 speed Convertible
2010 Harley Davidson Electra-Glide
mmmaxwe
Reg: 12-28-07
12-29-07 03:28 AM - Post#1329347
    In response to Anytime
Need to get over to storage to double check the numbers. I was pretty sure the engine vin was correct to the body vin. The T series number ends with QB and I think in 62 would have been a 409 HP with 420 Ft Lbs of torque.
Does anyone know about the ACC Code "50" on the Cowl Tag. If memory serves me the car is a St. Louis build and the Acc Code is 50. I cannot determine what this means. I also would like to know if I can find out where the car was sent from the factory. I believe the person I bought the car from was the second owner and would like to know the origin from the factory.
Any thoughts??
VintageCarryall
Loc: Arizona
Reg: 10-08-06
12-29-07 10:29 AM - Post#1329529
For the record; the Cook County, Il (Chicago area) Sheriff's Department tended to buy highly optioned SW's back in the 1960's
Anytime
Anytime
Loc: Chico, CA
Reg: 05-23-06
12-29-07 11:08 AM - Post#1329549
There are others on this board more up on ACC codes then I.
Does it have a power rear window? Seems to me I recall 50 was a power S/W window...
In the 60's S/W were used a police supervisor and K-9 cars. Look for evidence of holes for screens that would have been installed behind the driver's seat or rear seat.
mmmaxwe
Reg: 12-28-07
12-29-07 02:33 PM - Post#1329700
Thank you,
I do not see any evidence this car has/had power windows or the rear power window. Do the Acc codes vary by manufacturing location?
I cannot find holes are any thing to indicate a cage or screen was in place for a K9 Unit.
Seems this one is a mystery waiting to solved. Does anyone know the production numbers for these cars. I am curious how many were made and how many may be left.
Thank you,
4spd409
Loc: West Fargo ND
Reg: 10-10-02
12-29-07 03:24 PM - Post#1329744
The production numbers only break it down to series, body style and 6 or V8. There is no way to tell how many of this combination were made but I can take a guess that there were very few and the one you have if it is an original probably is the only survivor and may be the only one made with that combo. I have a 64 Impala wagon with a 340hp and 4spd and I know of two other 64s with 340hp and 4spds. I spoke with a guy from Seattle that said he had a 62 wagon with a 380hp 409 and 4spd. I don't remember if it was a Bel Air or Impala. You have an extremely rare car and it needs to be saved.
61 Impala Bubbletop
DonSSDD
DonSSDD
Loc: Nova Scotia, Canada
Reg: 08-21-01
12-29-07 04:21 PM - Post#1329791
    In response to 4spd409
If it was a police or fire spec etc., it was a special order, if you post all the info from the trim tag and/or a pic, someone may be able to figure it out.
59 El Camino, 62 Bel Air SC, 62 Bel Air SC(sold in Finland is 2011), 63 SWC Vette (sold)
Member #2194
Verne_Frantz
Verne_Frantz
Loc: hightstown,NJ USA
Reg: 08-22-00
12-29-07 04:51 PM - Post#1329821
No it doesn't. Just put an air-ride suspension on it. lower it and get some 22" wheels with rubber band tires. That way, you'll be keeping up with today's trend. Forget it's history!!!!!!!!!!!
Sorry, I'm just in a funk because NOBODY wants to restore one of these cars anymore.!
Anytime
Anytime
Loc: Chico, CA
Reg: 05-23-06
12-29-07 08:18 PM - Post#1330006
Wow!! That is a find!
Everything you need is available at Show Cars. They are the 409 parts guys.. dr409.com
If you can get more photos, we would love to see them..
Mick
mmmaxwe
Reg: 12-28-07
12-29-07 10:52 PM - Post#1330097
Question for all,
Is the Impala Body the same as the Bel-Air? I am not sure what body parts, doors etc... would work across the years. The front clip should be 62 only, I do not know if the Impala front clip is the same.
Anytime
Anytime
Loc: Chico, CA
Reg: 05-23-06
12-30-07 08:56 AM - Post#1330235
  • mmmaxwe Said:
Question for all,
Yes, they are the same in station wagons. The bubble top Bel Aire has a different top. The difference is in the trim pieces and mouldings.
4spd409
Loc: West Fargo ND
Reg: 10-10-02
12-30-07 05:14 PM - Post#1330573
The 50 looks like it was stamped in after the fact so it must be for a special order item. The front sheet metal is the same for all 62s. The front doors fit all 4 door sedans and wagons. Rear doors back is unique to the wagons and is the same for Biscayne Bel Air or Impala. Solid tailgates are hard to find as are gas tanks and the chrome frame for the rear glass. I'm very anxious to see photos. In my opinion this is a car that deserves a complete and correct restoration.
61 Impala Bubbletop
Dave_Neiling
Loc: Temperance, Mi. United St...
Reg: 12-10-01
12-30-07 07:54 PM - Post#1330717
If its original I hope you dont part it out as this would be a very rare car.
Dave N.
mmmaxwe
Reg: 12-28-07
12-31-07 12:13 AM - Post#1330912
    In response to Dave_Neiling
We will restore this car as original due to the fact there were not many made, even less left and this is an engine/vin matching numbers car with most all of the parts.
As for the rear doors will the bottom of the door work on 4drs if a person were to change the window frame?
I suspect the frames for the wagon were the same for the sedan in the event I need to get some frame parts.
mmmaxwe
Reg: 12-28-07
12-31-07 12:18 AM - Post#1330914
The only special order items I can come up with is the radio set and the siren. The car is a plain jane car with the biggest engine possible. No power steering, no power brakes, simple dash, 7k Sun tach, drum brakes, 409 steel wheels, no AC. Had chrome aircleaner, valve covers and oil tube cap.
I will post some pics as soon as I have the paperwork taken care of. Sorry for the delay, I promise complete photos of all as soon as we finish the paperwork.
Happy New Year to all,
M
Richard Martin
Loc: Davis Islands, Florida
Reg: 06-12-03
12-31-07 06:02 AM - Post#1330973
"409 steel wheels"
The 6" wide wheels are standard equipment station wagon wheels. There isn't a "409 wheel".
VintageCarryall
Loc: Arizona
Reg: 10-08-06
12-31-07 07:29 AM - Post#1331024
    In response to Richard Martin
  • Richard Martin Said:
"409 steel wheels"
The car may have 15" wheels; I believe that many fleet cars came equipped that way.
mmmaxwe
Reg: 12-28-07
12-31-07 06:15 PM - Post#1331480
    In response to VintageCarryall
Thank you for the clarification. I was going off some other things I have read stating the 409's all had the wide steel wheels.
M
mmmaxwe
Reg: 12-28-07
12-31-07 06:17 PM - Post#1331482
The wheels were 14 inch wide style wheels Noticed this when we put some tires on the rims to roll the car around
4spd409
Loc: West Fargo ND
Reg: 10-10-02
12-31-07 07:43 PM - Post#1331558
You mentioned that it had chrome air cleaner valve covers and oil fill cap. 62s had silver painted valve covers and black air cleaners. The factory chrome didn't come until 63.
61 Impala Bubbletop
mmmaxwe
Reg: 12-28-07
01-01-08 12:46 AM - Post#1331711
Perhaps the chrome was an add on after the fact. I noticed when I was looking at repops I could not find the chrome for the 62, The numbers on the car match for 62 as stamped in the block against the vin. Perhaps the owner wanted to add a few touches under the hood sometime after 63.
I have attached a pic of the engine compartment as we found it. If in fact chrome did not come out until 63, then this will save us a few dollars on the resto. I can get painted covers and a black aircleaner much cheaper.
Edited by mmmaxwe on 01-01-08 12:50 AM. Reason for edit: No reason given.
DOC396
DOC396
Loc: ohio
Reg: 06-10-04
01-01-08 06:54 AM - Post#1331781
no pics only red x? doc
DOC396
DOC396
Loc: ohio
Reg: 06-10-04
01-01-08 07:42 AM - Post#1331820
    In response to 62sedan
thanks 62, can't wait to see more pics now! doc
Mangus
Reg: 12-26-02
01-01-08 09:14 AM - Post#1331879
    In response to DOC396
How cool is that!!!!!
I dont know about the others here at CT but I have warm fuzzy dreams about finding cars like these.
Spot a round taillight out in a field, or notice the grill of a 58-64 chevy from a dirt road.
Walk out, check the find over. Pop the hood and a dual quad 409! Wow!!
Finding a W block is cool enough in these cars, a 409/409 is way too cool.
And the police wagon coupled with that turquoise green, killer.
Nice find and post stories of the find and more pics if you can.
Mangus
My cars:
62 Bel Air, off to work we go, 283, 3 speed on the floor, 17 MPG, black/red...gorgeous.
64 Impala, 383, 11:1, silver blue wild ride!
63 Impala, project.
VintageCarryall
Loc: Arizona
Reg: 10-08-06
01-01-08 09:24 AM - Post#1331888
    In response to Mangus
Can someone say 'frame-off' restoration for that wagon?
IMHO; it would be as unique as an original 1961 SS car.
doubleE
doubleE
Loc: Eagan MN
Reg: 06-02-03
01-01-08 09:40 AM - Post#1331903
That is one of the most impressive "field" finds I've seen! I noticed the tach sender box on the drivers side inner fender. Another indicater that the 409 is authentic. I'm curious as to what is mounted just forward and a little higher on the inner fender. Maybe a clue to it's original use.
One thing I would have expected to see was the big washing machine Delcotron alternator in lieu of the generator if this was an original police or fire dept vehicle. Of course this could have been replaced years ago.
It would be great to see more pictures of the whole car in the state you found her. Eye candy for us car crazy nuts
Eric
la63belairwagon
Reg: 11-19-07
01-01-08 09:50 AM - Post#1331912
    In response to doubleE
MORE PHOTOS !!!
MORE PHOTOS !!!
Richard Martin
Reg: 06-12-03
01-01-08 09:56 AM - Post#1331914
In my opinion this rare and special car was not a factory police package car even though it may have been used for that purpose.
Execution time: 0.117 seconds.   Total Queries: 15   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:54 AM
