LMC Truck
Username Post: Early Sign of A Fuel Pump Going Bad??        (Topic#176960)
Husker Z
Husker Z
Loc: Kansas City
Reg: 05-11-04
12-12-07 09:15 AM - Post#1316800
My 99 GMC Sierra Z71, 5.3 has been a little tough to start the past couple weeks. I haven't been driving it hardly at all, for the past 9 months, but with the crappy weather, I've started to again. That said, when I start it cold in the morning, or after it sits all day at work, it takes a little longer to get it to start than normal. It always starts, but just takes maybe a second or so longer to start. Would the fuel pump be starting to go bad or does it just go from working to not and that's it?
Thanks in advance.
"Welcome to Nebraska, You'll Never Lose to a Nicer Place"
LMC Trucks
elcamino
elcamino
Reg: 03-30-00
12-12-07 09:21 AM - Post#1316806
    In response to Husker Z
From all accounts I have heard there is no early sign, they just die one day and the truck will not start.
2017 GMC Sierra Denali Ultimate 6.2L(420hp)/8-sp
2016 Polaris RZR 900 EPS
Husker Z
Husker Z
Loc: Kansas City
Reg: 05-11-04
12-12-07 09:25 AM - Post#1316809
    In response to elcamino
That's kind of what I was wondering. Well, what the heck would give me a slow start like that? Seems like it's just waiting for fuel. It turns over at the normal speed, it just hesitates before starting.
Squasher
Squasher
Loc: Northern California
Reg: 07-05-02
12-12-07 12:24 PM - Post#1316927
I think it's something to do with a presure relief valve sticking open. Before you start your truck, turn on the ignition to ON but dont start. wait 10 to 15 seconds. Turn OFF then ON and start the truck. If it works, it's may be that presure valve. I think the presure valve is on the pump itself, but I dont know for sure.
2001 GMC Sierra K1500 Z71 x/cab SLT 5.3L
Husker Z
Husker Z
Loc: Kansas City
Reg: 05-11-04
12-12-07 12:56 PM - Post#1316959
    In response to Squasher
Is that pressure relief valve part of the pump itself? If I replaced the pump, would that include the valve? Just curious.
Bad Bowtie
Bad Bowtie
Loc: TX
Reg: 07-04-03
12-12-07 01:12 PM - Post#1316972
Have u changed ur fuel filter in the last 12 months/12k? I would also clean ur mass air flow sensor and IAC valve on the throttle body. A can of Seafoam fuel treatment in the gas tank would be a great follow-up as well...
Squasher
Squasher
Reg: 07-05-02
12-12-07 01:23 PM - Post#1316979
I dont know, But I think it was part of the pump assebly. Mine pump was replaced under warrenty for the same problem. Or thats what they told me they did
2003YukonXL
2003YukonXL
Loc: Sumter, SC
Reg: 04-03-04
12-12-07 08:26 PM - Post#1317304
I blame the pressure regulator for a lot of fuel related problems on these trucks. if there's gas in the vacuum line, it's bad.
Jake Brodersen
2006 Ford Explorer XLT 2WD (The Wife's)
2005 Pontiac GTO 6MT (My Toy)
2003 GMC Yukon XL SLT 4WD (The Family Hauler)
12-13-07 04:16 AM - Post#1317421
    In response to 2003YukonXL
Pumps sometimes start to whine before they go up, but not always.
Erich2087
Erich2087
Reg: 10-06-03
12-13-07 05:03 AM - Post#1317439
Check the fuel pressure regulator for a diaphragm leak (fuel in the vacuum line). Change fuel filter if due.
If the regulator is fine, place a fuel pressure tester on the fuel rail schrader valve and cycle the ignition several times without starting the engine. (Follow all safety rules for this procedure). Normal reading should be 52-60 psi and eventually hold 6 psi in a few minutes and stay overnight.
My readings went from 58 psi to 0 psi in less than 30 seconds. It did not hold the factory spec of 6 psi in the system.
A bad fuel pump relief valve will empty the fuel rails over night (sometimes when hot), resulting a hard start the first time, and a start with the second/third attempt.
Only a fuel pump replacement will change this condition.
Eric
1990 5.7 Silverado C-1500
2001 5.3 Silverado LT
Husker Z
Husker Z
Loc: Kansas City
Reg: 05-11-04
12-13-07 06:19 AM - Post#1317484
    In response to Erich2087
Well, it hasn't failed me yet, so I guess I'll just keep an eye on it and see what happens. This morning it actually sat outside in the cold for the first time in the 4 years I've had it and it started just fine. Maybe it doesn't like the warm, comfortable garage.
toms94
toms94
Loc: Kansas
Reg: 10-27-04
12-13-07 09:18 AM - Post#1317597
I just had this problem with my 99 Silverado.....it was the Fuel Pressure Regulator. Took about 5 minutes to fix it. (and about $70 at my local parts store)
Just like was said above, pull the vacuum line off the FPR, gas ran out of mine (not good), if it smells like fuel or fuel runs out, the FPR needs to be replaced.
I'm betting this is your problem.
I see you're in KC, I'll be in KC this weekend, if you need help maybe we can get together and see if we can fix it.
2001 Corvette Mag Red Coupe Corsa/Haltech Custom MidAmerica Motorworks Mag Red/Light Oak Seat covers.
2009 Silverado 1500 LTZ Crew Cab Z-71 Volant CAI
[IMG]http://img.photobucket.com/albums/v281/toms94/Co rvette/2010/Cruisefest201 0101-1.jpg[/IMG]
Edited by toms94 on 12-13-07 09:19 AM. Reason for edit: No reason given.
Husker Z
Husker Z
Loc: Kansas City
Reg: 05-11-04
12-13-07 10:38 AM - Post#1317656
    In response to toms94
Thanks guys, I'll keep an eye on it for a while.
Tom, I'd love to work on my pickup this weekend, but we have two birthday parties and a Christmas party. Can't wait, let me tell you.
Husker Z
Husker Z
Loc: Kansas City
Reg: 05-11-04
12-18-07 06:24 AM - Post#1321302
Well, I did that this morning and sure enough, it started right up. So, is the pressure relief valve the same as the pressure regulator as mentioned also? If so, the poster said it took him 5 minutes to replace it, but I can't imagine getting to and replacing anything on the fuel pump itself in that amount of time. Anyone clear up what I need to replace and where it is?
Thanks again.
Squasher
Squasher
Reg: 07-05-02
12-18-07 07:51 PM - Post#1321908
Thanks again.
The relief valve (check valve) is in/on the fuel pump in the tank.
I dont know if it causes any other problems becides hard starting.
toms94
toms94
Loc: Kansas
Reg: 10-27-04
12-19-07 06:55 PM - Post#1322742
No they must be different things. The Fuel Pressure Regulator is on the fuel rail (drivers side) right about in the middle. Have you checked to see if it smells like or has fuel in the vacuum line attached to it?
Husker Z
Husker Z
Loc: Kansas City
Reg: 05-11-04
12-20-07 05:53 AM - Post#1322978
I haven't checked that yet, I simply performed that test where you turn the key to on for 15 seconds.
LMC Trucks
Execution time: 0.618 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:41 PM
