Username Post: Testing Dex-cool        (Topic#176048)
DenaliXL
Reg: 02-25-07
12-01-07 08:11 AM - Post#1308302
Can you test Dex-cool with a standard Antifreeze tester? I mean the kind with the turkey baster bulb on the top and the arrow that floats to the protection temperature. I know its just a density tester and wasn't sure if Dex-cool has the same density as other anti-freeze. The tester says "Tests All (ethylene glycol) Antifreeze".
Please lets not start a thread about the virtues of Dex-cool (a.k.a. Red Death), etc. Just trying to learn how to work with it.
black95jimmy
black95jimmy
Loc: Venice, FL
Reg: 01-05-02
12-01-07 09:42 AM - Post#1308344
    In response to DenaliXL
I would say use the tester, Specific Gravity of Dex is 1.13, Green stuff is 1.12.
82 Monte Carlo SC, 355 w/Vortec heads, roller rockers, 670 Street Avenger, TRUE DUALS.
2009 Sub.5.3L LTZ 30 Gallons of gas @ $2.49/gal. bla bla bla.
Reg: 06-30-00
12-01-07 09:43 AM - Post#1308345
I also test electrically:
http://polarislabs1.com/electrical-test.htm
It's what anodes are for:
http://www.flex-a-lite.com/auto/html/anode.html
Edited by Mike on 12-01-07 09:57 AM. Reason for edit: No reason given.
DenaliXL
Reg: 02-25-07
12-01-07 09:48 AM - Post#1308346
    In response to Mike
Thanks. That's exactly what I wanted to know!
DenaliXL
Reg: 02-25-07
12-01-07 09:51 AM - Post#1308348
Interesting.
Squasher
Squasher
Loc: Northern California
Reg: 07-05-02
12-01-07 11:06 AM - Post#1308383
I have tried Prestones Ethylene Glycol (sp?) float guage on the dex-coolant and it didn't work. I dont know if it was a bad gauge or the coolant isn't compatible with the guage.
Prestone says to use the test strips to test thier Dex-Cool coolant. I think test strips are also needed for Propylene Glycol coolants.
2001 GMC Sierra K1500 Z71 x/cab SLT 5.3L
elcamino
elcamino
Reg: 03-30-00
12-01-07 04:32 PM - Post#1308589
    In response to Squasher
Yes for PG coolants, I happen to have some of those test strips because I have it (Amsoil PG) in my 93 Lumina winter car.
btw-The test strips have an expiration date so be careful of what you buy.
2017 GMC Sierra Denali Ultimate 6.2L(420hp)/8-sp
2016 Polaris RZR 900 EPS
Execution time: 0.207 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:59 PM
