Username Post: a few useful calculators        (Topic#175739)
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
11-27-07 06:06 AM - Post#1305429
http://www.idavette.net/tech/ratioc.htm
heres some calculators you might use
http://www.angelfire.com/fl/procrastination/mo tor....
http://www.thirdgen.org/calculations
http://www.bgsoflex.com/holley.html
http://www.rickwrench.com/bunchofcalculators.html
http://www.ford-trucks.com/calculators/index.php
http://hotrodworks.net/hotrodmath/hotrodmath .html
http://kb-silvolite.com/calc.php
http://www.wallaceracing.com/dynamic-cr.php
http://www.dsm.org/tools/calchp.htm
http://www.wahiduddin.net/calc/calc_hp_dp.htm
http://users.erols.com/srweiss/calccr.htm
http://users.erols.com/srweiss/index.html#jcalc
http://wahiduddin.net/calc/calc_da.htm
http://www.diamondracing.net/cocalc.htm
http://www.crower.com/misc/valve_timing_cha rt.html
http://www.bob2000.com/carb.htm
http://www.ondoperformance.com/page2.html
http://www.rbracing-rsr.com/camshaft.html
http://www.rbracing-rsr.com/runnertorquecalc.html
http://www.engr.colostate.edu/~allan...ngth/pipe.h...
http://purplesagetradingp ost.com/sumner/bvillecar/...
http://www.rceng.com/technical.aspx
gear spread sheet that comes in handy THANKS TO 1FATGMC
HERES OTHER INFO LINKS
http://www.wallaceracing.com/reargear.htm
http://users.erols.com/srweiss/calcmph.htm
http://users.erols.com/srweiss/calcrpm.htm
http://users.erols.com/srweiss/calcrgr.htm
http://users.erols.com/srweiss/transc.htm#tabtop
http://users.erols.com/srweiss/transc.htm#Auto
http://www.pipeflowcalculations.com/airflow/index....
http://victorylibrary.com/mopar/header-tech-c.htm
http://www.uucmotorwerks.com/html_pr...torquemyth....
http://tom.marshall.tripod.com/exhaust.html
http://www.engr.colostate.edu/~allan...a/effarea.h...
http://www.pontiacracing.net/js_header_length1.htm
http://www.wallaceracing.com/runnertorquecalc.php
http://auto.howstuffworks.com/question172.htm
http://www.auto-ware.com/software/eap/eap.htm
a few resources to allow you to calculate the ideal results
http://www.tmossporting.com/tabid/1805/Default.asp...
heres some differant calculators
http://www.kb-silvolite.com/calc.php?action=comp2
http://www.smokemup.com/auto_math/compression _rati...
http://not2fast.wryday.com/turbo/com...pressure.sh...
average the results
Edited by grumpyvette on 12-24-07 05:31 AM. Reason for edit: No reason given.
rumrumm
rumrumm
Loc: Macomb, IL
Reg: 10-18-01
11-27-07 06:35 AM - Post#1305453
    In response to grumpyvette
You should place this next to the books and references post so it can be accessed easily.
Lynn
"There's no 12-step program for stupid."
383 sbc, Eagle, AFR, SRP, CompCams, Edelbrock, FiTECH. Dyno #'s: 450 hp @ 5700, 468 ft. lbs. torque @ 4300.
http://photo.net/photos/Lynn%20Johanso n
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
12-05-07 10:07 AM - Post#1311348
    In response to rumrumm
http://www.compcams.com/Camquest/default.asp
comp cams is now offering a free cam sellection software,THIS IS A USEFUL TOOL, this is useful in seeing the lift/duration/LCA they suggest for your application, in most cases they get fairly close so its a tool thats useful, now you don,t necessarily need to buy a COMP CAM but a cam with a similar lift/duration/LCA from your favorite manufacturer probably should be fairly close to whats recommended
grumpyvette
grumpyvette
Loc: FLORIDA USA
Reg: 03-16-01
12-06-07 07:18 AM - Post#1312032
"HEY GRUMPYVETTE!,Interesting that it says going to a single plane wouldn't hurt my tq. curve it would also raise my peak tq. by 20 and give me 40 hp."
software simulations are only as good as the data paramiters used, and its RARE for a single plane to best a good dual plane intake below about 5500rpm, in tq or hp so keep that in mind!
your looking to increase the AVERAGE hp/tq more than the PEAK hp/tq if you want a fast car!
Ive seen a 20hp gain in PEAK hp on a 496 BBC resulting from a single plane intake swap from a good dual plane intake slow the cars 1/4 mile times over two tenths of a second, your gearing, suspension, traction,power to weight ratio and AVERAGE RPM band has a huge effect on the TOTAL performance.
the only way youll know if the software guess is correct is TESTING the parts on YOUR particular combo,in the real world
BTW
this software
is a P.I.T.A. to use but its is usually far closer to correct, and when you make a bad choice in components it points out the flaws and suggests where you can improve the combo
Edited by grumpyvette on 12-06-07 07:19 AM. Reason for edit: No reason given.
1FATGMC
1FATGMC
Loc: Southeast Utah
Reg: 04-29-04
12-07-07 09:41 AM - Post#1312932
Hey Grumpyvette the link to my gear calculators doesn't seem to be working. It should be:
Thanks for including it and hope they help some of the guys here. If you want to fix the link and delete this that is fine or leave this post.
Thanks for all that you are doing for us,
Sum
1FATGMC Lakester Construction
Execution time: 0.252 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:00 PM
