Username Post: Picture of GM serpentine on Ramjet 350        (Topic#174484)
Daryla1933
Daryla1933
Loc: Ft. Collins, Colorado
Reg: 11-05-04
11-11-07 04:27 PM - Post#1293724
Hi, guys. I'm making progress on the rebuild. Thought you might like to see the GM serpentine system (affordable compared to a lot of the aftermarket ones, but not nearly as spiffy...) on my ramjet 350.
I had the aluminum brackets powder coated so they're not so obvious.
11-11-07 05:39 PM - Post#1293767
    In response to Daryla1933
That looks good. The powder coat makes it blend in. I'm also using a Ramjet but have been having a little trouble getting it to run right. I think I have it figered out now though.
57 2dr HT (restoring)
Daryla1933
Daryla1933
Reg: 11-05-04
11-11-07 06:18 PM - Post#1293801
    In response to acardon
Thanks, Don. Yours looks good, too. Did you have any issues with the distributor and the firewall? Is it mounted in the stock location? What kind of problems are you having? What type of gas tank/fuel pump setup did you use?
How was that for 20 questions??
11-11-07 06:41 PM - Post#1293828
My engine is in the stock location and there is good clearance with the distributor. I should know, I've had it out 5 or 6 times. I have had a rough idle since I first started it. I finally figered it was an ignition miss and not a injector or sensor problem. After changeing the distributor and was going to change the coil I found that the boots on the GM performance wires were too long to allow the wire terminal to contact the distributor post.
I have an in-tank pump from Rock Valley.
I notice you have the valve covers off. I had a lifter making noise and found one real loose. I thought it was affecting the knock sensor.
Pistol
Pistol
Loc: Terryville, Ct.
Reg: 11-11-02
11-11-07 07:21 PM - Post#1293859
I think it looks pretty sweet
Pete
Awl speeling misteaks r myn
57 BelAir 2DRHT My-Pics
Daryla1933
Daryla1933
Reg: 11-05-04
11-11-07 07:40 PM - Post#1293869
That's good news about the fit - I set mine up with a bare frame and an engine block with front mounts. Then I built some side mounts. I'm hoping it fits well. Did you trim your boots to fit correctly? I went with a tank from Rick's. It fits great and looks pretty nice, too. I haven't got the fuel lines routed yet. What did you use for flexible lines from the fuel rails to the hard lines on the frame?
Pete, thanks for your comment!
Edited by Daryla1933 on 11-11-07 07:40 PM. Reason for edit: No reason given.
11-11-07 07:53 PM - Post#1293884
I used 6AN braided line for both supply and return. I used a 90 degree to 6AN in the rail. I had to cut about 1/4" off the boots to get the wire to snap down on the post. I'm curious to know if your wires are the same way?
I set my engine up the same way, used the stock front mounts to locate it.
And a question for you, does the book you got with your engine match the engine? The back part of the book I got (which says on the front cover is for a 350 Ramjet) has pictures of an LS type engine in the back part???
Edited by acardon on 11-11-07 07:58 PM. Reason for edit: No reason given.
Daryla1933
Daryla1933
Reg: 11-05-04
11-11-07 07:58 PM - Post#1293891
I'll check the wires and see how they fit. I imagine that mine will be exactly the same. Do you have pictures of install process?
Pilot20
Pilot20
Loc: Houston, TX.
Reg: 03-06-07
11-11-07 08:03 PM - Post#1293896
I also think it looks good.
57 Chevy 2 Dr Htp, 496 ci, 4L80E
77 Corvette Coupe, L-48
08 Corvette Coupe
11-11-07 08:06 PM - Post#1293899
Not any pictures of installing the wiring and the book wasn't much help on the routeing. If your book has pictures of the harness wire routeing, I need the part number. You can look through my picture trail. Link to Picture Trail.
11-12-07 05:14 AM - Post#1294096
I have the same system on my El Camino. I got it used for $50 including the pump, but no compressor or alternator. I don't rum the smog pump or the GM dummy pulley for the pump either. Just a shorter belt and it works fine. Another nice thing is they have a dummy pulley for the A/C compressor location to if you don't run A/C.
Daryla1933
Daryla1933
Reg: 11-05-04
11-12-07 06:23 AM - Post#1294124
    In response to Pilot20
Thanks, Pilot.
Don - I checked out your pictures and they look good. You have a really nice car. I like the stainless hard lines you used for the AC.
Jay - How did you know which shorter belt to use?
JCHEVY
JCHEVY
Loc: Bakersfield CA
Reg: 07-05-03
11-12-07 04:26 PM - Post#1294496
Is that The serpentine system GM Performance Parts sells? If not what is it from? It looks great with the brackets Powder coated. That was good thinking. The one GM performance parts sells comes with AC compressor, alternator, water pump etc, for well under a $1000. Way more cost effective then other brands. I've been thinking of using that set up also, but hadn't heard or seen any one using it.
57 Two door Handyman Wagon If I only Didn't have to work! http://www.picturetrail.com/jchevy
2Loose
"9th Year" Platinum Supporting Member
2Loose
Loc: Sandwich Isles
Reg: 03-17-03
11-12-07 08:24 PM - Post#1294678
That looks great! I get so tired of looking at all the dang bling blang these days, and I hadn't seen the GM setup, Nice Job !!!!
Willy
Daryla1933
Daryla1933
Reg: 11-05-04
11-12-07 08:24 PM - Post#1294679
    In response to JCHEVY
I got mine from Summit - $765 complete. It came with everything including mounting hardware. I'm pretty happy with the finished product.
Gray Headed Mule
Gray Headed Mule
Loc: Fort Worth, Texas
11-13-07 02:24 PM - Post#1295137
  • acardon Said:
Don??????????? Did you mount your engine in the rear of your 57?????? Did you get confused and thought you were working on your Corvair?????
Mule
I'm sexy and I know it!
My 49 Chevy Fleetline Deluxe Restoration Project
11-13-07 02:57 PM - Post#1295149
    In response to Gray Headed Mule
Daryla1933, you can cut an old serpentine belt into and wrap it around the pulleys, then mark the length on the old belt. You can then buy one by length. I just did that with a V-belt to go around the alternator, because I didn't want to run the power steering pump for the test runs.
Mule, my car has been apart for so long, I forgot where everything goes.
11-13-07 04:48 PM - Post#1295206
Sorry Daryla1933 I didn't see your question earlier. Mine was actually listed by part number in the Jaguars That Run book on converting to EFI, But Don's method would work just as well. Just remember to have someone putting tension on the tensioner to replicate it having a belt on it. You can do it with twine as well. Wrap it around and mark where it meets itself and measure it.
4dr 57
4dr 57
Loc: The Texas Hill Country
Reg: 11-10-04
11-13-07 05:18 PM - Post#1295226
Oh Yea, that Looks Great!
Very Nice!
I'm not a big fan of hot air intakes though. Stalth Conversions/Jags That Run mentiond above may have something for this problem. They are good folks with quite a few conversion parts.JM2C
Stan
Wife: "Don't race the Police car, Stan!"
Daryla1933
Daryla1933
Reg: 11-05-04
11-13-07 08:25 PM - Post#1295359
    In response to 4dr 57
Thanks, everyone. That's good info about the shorter belt. Since the idler is already there I'll probably go ahead and use it, but options are always good.
Stan, you mentioned hot air intake. Will it improve my performance at all to find a plumbing method that moves the air cleaner to a different location? I've thought about doing something with a dual intake that come in through the side filler panels, but I'm nervous about having that "import" or rice burner look!
Daryla1933
Daryla1933
Reg: 11-05-04
11-13-07 08:27 PM - Post#1295363
Don,
Where did you install your air temp sensor (I think that's right) - I know that Street and Performance sells an air cleaner housing with a bung in it for that purpose, but the standard GM air cleaner doesn't have any provisions. Any thoughts?
11-13-07 08:37 PM - Post#1295372
I built a short tube out of 16 gauge sheet metal, the same size as the throttle body where the air cleaner goes. I drilled it and put the IAT in it. The air cleaner clamps to it and I used a sheet of rubber and a clamp to hold it to the throttle body. I plan to build a wide stainless clamp to clamp the air cleaner and the extension together. You can just see part of it in the above picture.
Daryla1933
Daryla1933
Reg: 11-05-04
11-14-07 06:21 AM - Post#1295531
Great idea on the IAT - I can just see it the picture.
todd77malibu
todd77malibu
Loc: Westmoreland, TN , USA
Reg: 02-09-01
11-14-07 06:40 AM - Post#1295540
I have the exact same setup on my 77 Mlaibu classic. Seems to fit well and looks nice and clean.
77 Malibu Classic Coupe
08 Chevy Silverado Crew Cab Z-71 4x4
www.youtube.com/user/todd77malibu
Edited by todd77malibu on 11-14-07 06:41 AM. Reason for edit: No reason given.
Execution time: 0.108 seconds.   Total Queries: 17   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 09:49 PM
