Username Post: What does a typical rebuild cost?        (Topic#172461)
Snake
Snake
Loc: Danville, CA
Reg: 06-08-05
10-17-07 03:54 PM - Post#1276131
I'm trying to figure out if a crate motor or rebuild is more cost effective. If you have a decent long block without any major problems, what can you count on spending in machine work and assembly parts, considering the assembly is done at home and no big power adding is in the game plan?
Thanks very much,
Jake
Building a 57 Black Widow inspired 150 2 door sedan, with a 5.3 LS motor and 4l60e
+Remembering Eric Martin+
Nick P
Nick P
Loc: De Queen, Arkansas
Reg: 10-15-03
10-17-07 04:20 PM - Post#1276145
    In response to Snake
For the buck, you just can't beat the new crate engines. You can sink close to the same in a rebuild as a crate eng. But you finish it and it breaks, well start over out of your pocket. With a good crate and warranty, nuff said.
10-17-07 04:37 PM - Post#1276160
A few years back I built a 350 for my Nova for about $1000. Bored, new pistons, resized rods, new bearings and freeze plugs, new timing chain and lifters. A couple of things I had going for me was that the core I used had a good performance cam, and the crank only needed polishing. I scored a set of low mile Vortec 350 heads for a song. Bought a new Edelbrock manifold to top it off.
Thing is, if I hadn't found a fairly excellent core for the price, and hadn't found the heads for below market - I could have easily spent $400-700 more. The cost of machine work and parts has no doubt gone up at least 10-15% since I did that one. That would have put the cost a lot closer to crate engine cost.
57TOMMY
57TOMMY
Loc: Bay Area , Calif
Reg: 08-19-03
10-17-07 07:45 PM - Post#1276311
    In response to Rick_L
Hey jake,
When I was thinking of rebiulding my 283 I found out it was cheaper to pick up a crate motor by about 500 to 1000 dollars depending what you want done to the motor. The plus with a crate motor was , with most places , a 1 to 2 year warranty & everything NEW , not a reground crank with 100k on it.
Just my 2 cents
Tom
Stand up for what is right ,even if you stand alone.
SEWERAT
SEWERAT
Loc: Minneapolis,MN
Reg: 01-29-03
10-17-07 11:46 PM - Post#1276400
    In response to 57TOMMY
Snake,
It kind of depends on what kind of motor you want..... There are so many companies selling anything from a long block to a fully; force fed, fuel injected, super charged big block. I would go GM crate for something that will be a runner or a nice Ramjet if you want FI. But what are you wanting to have under the hood? 275 HP or 700??? FI, carb, blower, Rat, mouse, supercharged, NOS???? street, racing, pro street??? Give some more info on what you have in the budget and what you are going to do with the car....
Once upon a time, a guy asked a girl "Will you marry me?" The girl said, "NO!" And the guy lived happily ever after and went racing and drank a lot of rum whenever he wanted. The End
Jared1956
Jared1956
Loc: Missouri
Reg: 12-28-04
10-18-07 12:20 AM - Post#1276405
Anyone with money can own a Hot Rod.......not everyone can build one.
Nothing wrong with buying a crate engine.....but it just seems much more satisfying to me to crank that starter for the first time and hear that piece of iron that you have spent hours working on....come to life.
Not trying to put down guys that have to buy things.....lord knows there are many things that I have to pay to have done!!! Just trying to give Snake the justification to build his own engine, even if it costs a little more
To answer your question Snake, .........it depends!!
Ideally all you would need is rings, bearings, gaskets, oil pump, timing chain, and no machine work done. Your cylinders would just need prepped a little and that would be the extent of your machine work. If this was the case, you would spend a lot less than a crate engine.....say 200 to 300 bucks!!
But in the real world, cylinders need bored, so you need new pistons.......cranks are out of spec or have been turned one to many times before, so you need a crank.....cylinder heads need valve guides pressed in, and new valves.......by the time all of this is said and done....your at or well above the cost of a crate engine.
Your best bet is to disassemble your engine and check the cylinders.....mic the crank.......check the valve guides and valves........if any of these need major repair, just stop there and go out and get your crate engine and save yourself time and money.
http://www.picturetrail.com/jared1956
Edited by Jared1956 on 10-18-07 12:38 AM. Reason for edit: No reason given.
MikeB
MikeB
Loc: Plano, TX
Reg: 08-28-03
10-18-07 07:28 AM - Post#1276528
    In response to SEWERAT
  • SEWERAT Said:
It kind of depends on what kind of motor you want.....Give some more info on what you have in the budget and what you are going to do with the car....
I second that. I wanted a 327, so had to build it myself. Here are some approximate prices if doing a rebuild:
Magnaflux, hot tank and/or bake block, deck, bore, hone, install oil plugs and freeze plugs: $150 at a large mass engine rebuilder to $450 at a performance engine shop.
Line boring, if necessary: $150
Grind crank journals: $75
Check rods for trueness: $50. Straighten, resize if necessary: $100 for 8.
Balance: $175. May not be needed for mild engine using all stock-weight GM rotating parts.
You can price components such as pistons, rings, bearings, cam, lifters, timing chain, oil pump, and gaskets.
And, of, course you'll want to get a valve job and have the head decks cleaned up. The heads may also need new guides. You could easily spend $300 or more here. That doesn't include new springs and retainers, which will add another $75-$125 for a decent set.
In my experience, you will always spend more than your budget when doing a rebuild or starting with a bare block.
With something like the GMPP 330 HP motor, you get ALL NEW parts, a mild performance cam, and Vortec heads for around $2500. Very hard to beat.
Then again, it's kinda cool to have the satisfaction of doing it yourself.
Edited by MikeB on 10-18-07 07:38 AM. Reason for edit: No reason given.
No_Dice
"13 Year" Silver Supporting Member
No_Dice
Loc: San Jose, CA
Reg: 04-23-01
10-18-07 07:52 AM - Post#1276544
    In response to MikeB
Jake - In my experience the type of motor that you need is the question. If you are going for a lot of horsepower, blower, exotic induction, etc then using a reputable engine builder is the way to go. If you are building a street car that is for cruising and local shows? Get a simple crate. My motor is more than I need and I now know that I would have been better off with a crate motor and spending more energy on the details and finish. If I were starting over on my car I would get an Edelbrock crate motor.
Snake
Snake
Loc: Danville, CA
Reg: 06-08-05
10-18-07 01:01 PM - Post#1276787
    In response to No_Dice
Thank you for all of the advice guys.
What I'm shooting for is a nostalgic looking cruiser, so hp can be pretty conservative to save some coin. I would love to say I have a 327 but if I can do a 350 crate for a lot less, and have a warranty to boot, I think I would have to go that route. Just slap some finned parts on it and we're golden
I'm wondering if these rebuilt 327's on ebay for $2000 are worth a look, or if that would just be asking for trouble.
Jake
Tri5man
Tri5man
Loc: Possums Crotch, KY
Reg: 06-26-07
10-18-07 01:43 PM - Post#1276820
I've heard of too many horror stories of machine shop screw ups to be messing with a rebuild. A crate motor is a no brainer. If I were buying one, it would be the 290 HP one for less then $2000 warantee included.
56 Bel Air 2 door post, 350/4 speed
www.picturetrail.com/tri5man
No_Dice
No_Dice
Loc: San Jose, CA
Reg: 04-23-01
10-18-07 01:48 PM - Post#1276827
    In response to Tri5man
Snake - ping Smedding (ask busy) and ask them what they could do with your 327.
busyguy8
busyguy8
Loc: SF Bay Area, CA
Reg: 11-21-04
10-18-07 02:18 PM - Post#1276853
Dice,
Smedding doesn't do rebuilds anymore. They haven't for a couple of years now.
-b
Aquired a '56 2dr hdtp BelAir on 6/9/05!
Link to my pics!
-bill
No_Dice
No_Dice
Loc: San Jose, CA
Reg: 04-23-01
10-18-07 02:20 PM - Post#1276854
    In response to busyguy8
maybe they have a shop that they refer folks to? There is nothing in San Jose that I have heard of...folks mostly use crates.
MikeB
MikeB
Loc: Plano, TX
Reg: 08-28-03
10-18-07 04:45 PM - Post#1276983
No way would I buy a rebuilt 327 on eBay.
Snake
Snake
Loc: Danville, CA
Reg: 06-08-05
10-18-07 04:46 PM - Post#1276985
Also, sadly, the 327 went away with the 55 when I sold it . I will have to pick up a core from craigslist or something if I go that route.
Jake
J.
J.
Loc: Campbell, CA
Reg: 01-17-02
10-18-07 05:57 PM - Post#1277054
PM sent.
1955 Bel Air 4 door 265 V8 TKO 5 speed
Cool like Lemonade
Big T
"12th Year" Silver Supporting Membe
Big T
Loc: Simi Valley CA
Reg: 04-14-06
10-18-07 07:16 PM - Post#1277133
I had a 350 I was going to rebuild for the 55. Wound up buying the 350HO crate to save money.
Tom
55 4 door BelAir
Big T
Big T
Loc: Simi Valley CA
Reg: 04-14-06
10-18-07 07:17 PM - Post#1277134
Tom
55 4 door BelAir
57TOMMY
57TOMMY
Reg: 08-19-03
10-19-07 06:06 AM - Post#1277393
    In response to Big T
Hey Snake,
Check with Busy about Smeding, They no longer do rebuilds , but if you want a crate motor they are hard to beat. You can also go to your nearest GM dealer & pick a motor with a year warranty. I went with the 350/290 GM motor, I think they are about $1700.
Tom
Edited by 57TOMMY on 10-19-07 06:14 AM. Reason for edit: No reason given.
Nick P
Nick P
Reg: 10-15-03
10-19-07 07:56 AM - Post#1277470
You are still alive..................Good to know.
56BUDDY
Loc: Union City, CA
Reg: 12-31-02
10-19-07 11:13 AM - Post#1277641
Snake,
Lots of good points here. Jared has a good point too about building your own.
One point that I would like to add...what do you want? Is this going in a car for the long run or will it be put up for sale? If that's the case, then the cash would be a factor. But, if you're going to keep this car...I'd go with the crate motor. I bought the HO Deluxe at Crown Chevrolet in Dublin. That's the complete engine including a 600 Holley, long water pump, HEI distributor and flex plate. I was looking for a cruiser with alittle punch. Still working the bugs out but, no regrets. This car will NEVER be sold. So, it was put together for the long run.
Good Luck on your decision.
Mel
Mel
inline0_0
inline0_0
Loc: Arizona desert
Reg: 03-10-04
10-19-07 12:05 PM - Post#1277689
    In response to 56BUDDY
I put together my 235 using no-name plain brown wrapper rebuilder parts. Approx. 120K to 140K mi. later it was still using no oil, & ran well, I pulled it & sold it. Built the inline 292 I'm using now same way. Only have 40K to 60K on it, OK so far, gimme a few more yrs, I'll let you know how it did.
Doug
Old Buzzard
Loc: Madison, GA.
Reg: 10-13-07
10-19-07 03:50 PM - Post#1277850
    In response to inline0_0
And, the GM crates usually have a hyd roller cam. A good item, considering the quality of today's oils.
If you price a rebuild, and add a hyd roller into the equation, it gets to be considerably more $$, and still no warranty.!
Chuck
Hotrodding and dragracing since 1955..
Injector inspector, and certifiable EFI nut.
Back to 55, again, for the 6th time.
Snake
Snake
Loc: Danville, CA
Reg: 06-08-05
10-19-07 07:18 PM - Post#1277881
    In response to Old Buzzard
I think I am sold on the crate idea, especially if Crown in Dublin has a good price.
Once again thanks to all of you for the help here, one more thread to prove Chevytalk rules.
Jake
Snake
Snake
Loc: Danville, CA
Reg: 06-08-05
10-23-07 07:41 PM - Post#1280495
I need to bring this back to the top for an additional question:
It looks like the $1500 250hp and $1900 290hp GM crate engines are very similar, which would you go for? They both use a hydraulic flat tappet cam and cast iron heads. Is the upgrade to the 290 worth the extra coin?
Thanks again,
Jake
57TOMMY
57TOMMY
Reg: 08-19-03
10-23-07 09:09 PM - Post#1280550
Hey Jake
I got the 290 motor & although it took some time it now runs great. My first build & I had some vacumm & carb issues. If you want me to be honest.
If I had it to do again I would save the cash & get the standard motor. I am not all that interested in burning up my new tires.
Just my two cents
Tom
Snake
Snake
Loc: Danville, CA
Reg: 06-08-05
10-23-07 09:31 PM - Post#1280566
Thanks Tommy I really appreciate your help here.
On a side note I have been looking at 3x2 setups and I think I am going to put one on this crate motor. That should provide some tinkering potential that I miss out on by not building an engine
Jake
J.
J.
Loc: Campbell, CA
Reg: 01-17-02
10-23-07 09:52 PM - Post#1280576
it may be best to get the engine set up with a standard 4bbl to keep things simple. get the engine running this way to iron things out, then throw on the deuces!
J
Cool like Lemonade
MilesB
MilesB
Loc: Melbourne, Australia
Reg: 04-17-06
10-23-07 10:45 PM - Post#1280594
    In response to J.
I have the GMPP 290. I believe the difference is the cam. They don't have the 250 here or I probably would have bought it and saved the extra for a cam and Vortec heads.
Photobucket
Snake
Snake
Loc: Danville, CA
Reg: 06-08-05
10-24-07 07:54 AM - Post#1280728
    In response to J.
Good idea J. From what I read though, if you run it with a progressive linkage and set up the outer carbs as dumpers, you only have to tune the primary/middle carb, which should be relatively easy. Just have to make sure your outer carbs are not causing a vaccuum leak with ill-fitting butterflies.
Jake
Execution time: 0.276 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:23 AM
