Username Post: L31 Camshaft choice? (for max torque)        (Topic#164101)
MadMike
Loc: Dawsonville Georgia
Reg: 05-11-01
07-08-07 07:38 AM - Post#1203195
I'm researching a new camshaft for my 1999 350 vortec engine (L31) (in a suburban).
It's been suggested I run a Comp Cams tripower extreme (TPX254HR) 254/264, .477/.471 lift
... I'm also looking at the GMPP HT383 camshaft.
The comp cams looks a little more aggressive and is supposed to be used with a fast-flash gizmo to optimize the injection to work with the cam, whereas the HT383 seems to compliment the larger cubes of a 383 (which I don't have).
My 350 has a free flowing induction and free flowing exhaust (true duals, stock manifolds). 105000 miles.
I'm after torque, for towing.
Anyone have any 1st hand experience with either of the above 2 cams, or a different opinion? My engine runs fine and tows alright now... I'm just doing my homework.
Thanks,
MadMike
bored&stroked
Reg: 01-03-03
07-08-07 03:56 PM - Post#1203500
    In response to MadMike
Your stock cam is probably best for low end torque. Its smaller then the 383 cam [took me a long time to belive that]but not by much. I highly doubt you'll see anything using it compared to stock. Have you considerd a stock LT1 cam? Its 201/207@.050, should make peak torque in the 3000-3300rpm range.
78 c10: 11:1 388,M20,5/5" drop.-playtoy
98 gmc sierra: 5/6" drop, 17" eagle alloy's, flowmaster 50 series.-daily driver
06 CBR600F4i- freakin rocket ship
MadMike
Reg: 05-11-01
07-08-07 05:01 PM - Post#1203535
    In response to bored&stroked
I got the specs on the other cams:
Camshaft-Part # 14097395 Billet Steel Hydraulic Roller Camshaft. (i.e. HT383E)
Intake Lift- .431" Intake Duration @ .050" 196
Exhaust lift- .451" Exhaust Duration @ .050" 206
Lobe Centerline-109
Stock L31
Intake Lift- .414"
Exhaust Lift-.428"
Intake Duration @.050"- 191
Exhaust Duration @ .050-196
Lobe Centerline-111
Comparing stock against the HT383... doesn't look like much. The tripower extreme may be worth checking into.... or I should just shelve the whole idea.
I may just look into adding 33 cubic inches to what I already got (along with the cam).
Randy_W
None
Reg: 01-06-02
07-08-07 06:12 PM - Post#1203580
Your true duals are hurting your low end torque, I had true duals on my '96 4dr Tahoe and it killed the off idle response and hurt torque below 3599 rpm. I went to a Magnaflow straight through 2 into one with 3" outlet and mine felt like I had 50 more horsepower at the bottom end.
Randy
DON'T mess with Old Men, we didn't get old by being, STUPID!!!
"The veneer of civilization is very thin!" (Arlo)
Randy_W
None
Reg: 01-06-02
07-09-07 06:48 PM - Post#1204446
    In response to Randy_W
Of course I meant '3500 rpm'.
Randy
1983G20Van
Loc: Bedford, Texas, USA
Reg: 11-13-02
07-09-07 07:06 PM - Post#1204467
The Ramjet/HT383 camshaft is actually the GM Marine 350 TBI camsahft. That engine makes 285-320 HP @ 4,600-5,000 rpm depending on the heads and 365-370 ft/lbs of torque @ 3,200.
Execution time: 0.194 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:32 AM
