LMC Truck
Username Post: 94 4.3 vortec into a 89 S10 blazer        (Topic#160393)
jimdinger
Reg: 05-23-07
05-23-07 07:35 PM - Post#1171586
Hello,new guy here I hope you can help meout with a project I have in my garage.
I have a 1989 S10 Blazer with a bad 4.3,Throttle body
injection.I recently acquired a 1994 Vortec 4.3,plus the computer and wiring harness for under the hood and the radiator.My question is this,will I experience any problems where the wiring harness connects to the fuse box on the firewall?My blazer has the digital dash will that be a problem?
Also someone told me the tranny wont shift properly,will it? Thanks for helping me out with this.
LMC Trucks
jimdinger
Reg: 05-23-07
05-24-07 06:33 PM - Post#1172271
    In response to jimdinger
Any help? I need this done by this weekend.
59 EWW
59 EWW
Loc: Kansas City Kansas
Reg: 08-31-03
05-24-07 08:46 PM - Post#1172340
Seriously this is not a one weekend project, engine swaps like this need some planning to work out the problem areas.
I believe the 94 would of had a 4L60e transmission and the 89 I believe a 700r4, this will be a problem, 94 wiring harness will not plugin to the 700R4 tranny.
If time is important I would see if a TBI intake for V6 vortec heads is available, GM performance parts sell a TBI to vortec heads intake for small block V8 motors, but I'm not sure if they make one for a V6.
If you can get a TBI intake for the vortec motor you can use all the 89 computer componets and the 89 tranny.
Like I said this is mixing apples and oranges it takes some planning.
Ernie
59 Biscayne 2dr
65 Elcamino
97 Z71,K1500,5.7
06 GMC Canyon
jimdinger
Reg: 05-23-07
05-24-07 08:49 PM - Post#1172343
    In response to 59 EWW
Hey thanks,I got the stock TBI intake from the bad motor,will the intake and water ports,plus all bolt holes line up correctly?
59 EWW
59 EWW
Reg: 08-31-03
05-24-07 08:53 PM - Post#1172344
No, thats why you need a different (intake) to make all the 89 stuff work with the vortec motor.
Ernie
59 Biscayne 2dr
65 Elcamino
97 Z71,K1500,5.7
06 GMC Canyon
jimdinger
Reg: 05-23-07
05-24-07 08:55 PM - Post#1172345
OK looks like I go to the guy I got the motor ftom and get the tranny,I have digital dash so will that be an issue with my speedo working?
59 EWW
59 EWW
Reg: 08-31-03
05-24-07 09:06 PM - Post#1172350
Getting the 94 tranny would help, the speedometer will be a problem, the 89 and 94 use different types of systems for the speedometer.
There are adapters made to convert the speedometers to different systems, I dont have any info for you at this time. I'm sure someone else does.
If it was me I would be looking for a different intake, easier,faster,and possibly cheaper in the long run. If one is available.
Something else just came to mind, fuel pumps, I'm not 100% sure but the 94 vortec may of had a high pressure fuel pump, the 89 would of had a low pressure pump. So the fuel pump would possibly need to be changed.
Ernie
59 Biscayne 2dr
65 Elcamino
97 Z71,K1500,5.7
06 GMC Canyon
Edited by 59 EWW on 05-24-07 09:15 PM. Reason for edit: No reason given.
jimdinger
Reg: 05-23-07
05-24-07 09:57 PM - Post#1172370
yeah I just thought of the fuel pump also,anyother experts out there want to throw there 2 cents in on this? It would help me out a lot.
Senior Chevytalk Moderator
05-25-07 05:08 AM - Post#1172490
Wow you're in a hurry. Checkout http://www.s10forum.com/
jimdinger
Reg: 05-23-07
05-25-07 06:50 AM - Post#1172557
Well the thing has been sitting for a week,and for me a vehicle sitting for a week with out running is a long time.Thanks for the link.
LMC Trucks
Execution time: 0.238 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:39 PM
