Username Post: Electro-Hydraulic Control Unit (EHCU)        (Topic#152744)
felixcajaput
felixcajaput
Loc: Akron, Ohio
Reg: 11-05-05
02-26-07 07:36 PM - Post#1106249
Good Evening..
I would rather be working on my 62 chevy c-10, but my newer truck and i have a difference of opinion. I have a 2003 GMC Sierra 4WD 5.3L V8. Today as my wife was driving the truck and turning into a parking lot, the ABS light came on, and a funny noise was heard from underneath the truck.
I have located the noise, according the Haines Repair Manual, its called a Electro-Hydaulic Control Unit (EHCU). Anyway, this unit runs continously even when the truck is turned off. Any suggestions!?
The unit is clean and dry from foreign materials. I tried taking my truck to a couple local part stores (AutoZone & Advance) Neither one can check my codes, because of ABS lights are considered (Soft) codes. I have unplugged the unit so it will not continuously run. However now as some probably know it sounds bells intermitanly, making me think there is a short somewhere in the circuit.
I believe i can probably fix the problem myself but i don't want to just throw money at it. (That never seems to work.) And i don't want to be fooled if i take it to a dealer or service shop and again throw good money after bad.
I am hoping someone else has had this problem, and can help out. Any suggestions would be appreciated.
Thanks, - Jeff
redvett01
Loc: Wickenburg, AZ
Reg: 10-23-03
02-26-07 07:56 PM - Post#1106274
    In response to felixcajaput
The problem is your module chec here http://www.modulemaster.com/
K1500 04 Silverado EXT
felixcajaput
felixcajaput
Loc: Akron, Ohio
Reg: 11-05-05
02-27-07 09:08 AM - Post#1106643
    In response to redvett01
Redvett01, YOU ARE A LIFE SAFER!!! Thank you for your suggestion. Soon as i get off work, i am going to disconnect and send my unit.
Thanks again..
redvett01
Loc: Wickenburg, AZ
Reg: 10-23-03
02-27-07 09:49 AM - Post#1106677
Glad to help.
Execution time: 0.981 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 07:30 PM
