Username Post: Ball Joint and Tie Rod Torque Specs        (Topic#151482)
Winmon
Winmon
Loc: Sequim, Wa.
Reg: 10-01-03
02-12-07 03:07 PM - Post#1094589
How tight do ball joints and tie rods need to be torqued down to?
Bagged '62 Bel Air - 450hp LS2 - T56 - 9" Rear End
Pictures Here:
Photobucket
dav56
dav56
Loc: sumner,washington
Reg: 01-13-03
02-12-07 03:59 PM - Post#1094638
    In response to Winmon
Dave,torque the ball joint to 70lbs,tie rod ends 60.That should put you in the ballpark.Make sure to replace the cotter pins.
http://www.cardomain.com/ride/503656
inferno 55
inferno 55
Loc: Rogers, Arkansas
Reg: 11-10-02
02-12-07 04:25 PM - Post#1094665
Control arms to frame: 65-75 ft lbs.
Ball Joints: 45 ft lbs
Pitman arm: 100-150 ft lbs
Idler bushings: 30-35 ft lbs
Tie rod ends: 29-43 ft lbs
Control arm bushings:Curb height, all weight on them: 45-55 ft lbs.
Pitman arm ball: Tighten screw tell stops, then back off 3/8 to 3/4 and line up cotter key.
Bob
http://www.picturetrail.com/inferno55
55Chevy h/t 350 TPI/700R4
55Chevy p/u 327/350
64VW Baja conv 1800
09-250,6.4 4X4
08-300 awd
38 chevy truck 327/350
dukeofbluz
dukeofbluz
Loc: IL
Reg: 12-15-03
02-12-07 05:51 PM - Post#1094750
    In response to inferno 55
I noticed when I installed my new springs that if I tighted my ball joints up the nut would be too far above the cotter key hole? Am I missing something?
Jeffrey
MY YOUTUBE VIDEO!!!!
MY PICTURE TRAIL
Snake
Snake
Loc: Danville, CA
Reg: 06-08-05
02-12-07 05:57 PM - Post#1094759
    In response to dukeofbluz
Duke, same here.
I thought the castle nuts w/ cotter pins (ball joints, tie rod ends) were specifically used at points where you don't want to torque the nut very much? What am I missing?
Jake
Building a 57 Black Widow inspired 150 2 door sedan, with a 5.3 LS motor and 4l60e
+Remembering Eric Martin+
02-12-07 06:12 PM - Post#1094774
    In response to Snake
You DO want full torque on the ball joint and tie rod pins. It should be obvious they are not something you want to come loose.
On the other hand, you don't want to overtorque them, the tapered pins are hard enough to get apart without overtorquing.
Likewise, since the ball joint and tie rod nuts are not something you want to come off the car even if they are slightly loose, the cotter pins take care of that.
If the cotter pin hole is not lining up with the slot in the castellated nut, probably the problem is the wrong nut. Most of these nuts are availabe in half height and full height. Most any auto supply has a good selection of castellated nuts.
If a full height nut does not do it, then the hole is probably misdrilled (can you say Asian made?).
As a last resort, put a hardened washer under the nut.
This is definitely something you want to get right.
Winmon
Winmon
Loc: Sequim, Wa.
Reg: 10-01-03
02-12-07 06:31 PM - Post#1094791
    In response to Rick_L
Thanks guys! Rick, that is good info.....
Pictures Here:
Photobucket
inferno 55
inferno 55
Reg: 11-10-02
02-12-07 07:41 PM - Post#1094879
When you buy a kit, they should have the different castle nuts like Rick says. If they don't line up with the hole there is something wrong.Never back off, but tighten a little to align. If you look close you can see the different thickness nuts in photo.
Bob
55Chevy p/u 327/350
64VW Baja conv 1800
09-250,6.4 4X4
08-300 awd
02-12-07 08:02 PM - Post#1094908
To follow up a bit on the torque specs and 33vicky's last comment...
The lower ball joint is 9/16-18 thread, the upper is 1/2-20, and the tie rod end is 7/16-20.
We see recommendations in this thread of 45 ft-lb and 70 ft-lb for the ball joints, and 29-43 up to 60 ft-lb for the tie rods.
I couldn't find any torque spec's for ball joints or tie rods in the shop manual, assembly manual, or a later year shop manual.
A grade 8 1/2" bolt would be recommended to be torqued to 80 ft-lb, and a 9/16" bolt to somewhat more than that. And a grade 8 7/16" bolt would be recommended to be 65 ft-lb.
I would tighten the ball joints to 60-70 ft-lb, and tighten more until the cotter pin hole lines up in the castle nut. For the tie rods, I'd go to 40-45 ft-lb, and tighten additionally until the cotter pin hole aligns with the castle nut. So, all of the recommendations here are in the same ball park. Again, you don't want to get carried away, but you want them secure. And as 33vicky said you don't want to torque and back off, better to torque to a slightly low value and then add some.
Winmon
Winmon
Loc: Sequim, Wa.
Reg: 10-01-03
02-13-07 06:37 PM - Post#1095689
Thanks for the info!
Pictures Here:
Photobucket
jrhopkins
Loc: washington state
Reg: 12-23-16
09-21-17 11:57 AM - Post#2708392
once tightened, how stiff should the spindle be to turn? I put new ball joints in and maybe tightened the castle nuts too tight initially and now the spindle is hard to move. I can pivot it with effort but the other wheel which I haven't done yet is quite easy to move.do I need to separate the ball joints and redo it?
09-21-17 05:45 PM - Post#2708434
    In response to jrhopkins
I don't think torque on the ball joint nuts will have anything to do with how much friction you have.
Have you lubed the ball joints yet?
Execution time: 0.368 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 02:30 PM
