Username Post: Pilot bushing fit        (Topic#146144)
Snake
Snake
Loc: Danville, CA
Reg: 06-08-05
12-11-06 07:13 PM - Post#1049178
I apologize for all of the questions lately
While trying to install a new pilot bearing tonight, I found that the diameter is way too big for the hole in the crankshaft. I have the old bushing that does fit, but I'm able to slip it right in and spin it around, so I'm thinking it's not a good idea to use that one.
Are there different size bushings throughout the years? The two new ones I have are never gonna fit in there. Even pounding on them with a socket isn't working.
Jake
Building a 57 Black Widow inspired 150 2 door sedan, with a 5.3 LS motor and 4l60e
+Remembering Eric Martin+
rewinder
Loc: alberta canada
Reg: 02-22-03
Re: Pilot bushing fit
12-11-06 08:07 PM - Post#1049179
    In response to Snake
I BELEIVE THERE ARE 2 AVAILABLE. I HAD THE SAME PROBLEM AND REQUIRED THE LARGER O.D.. I HAVE THE SMALLER O.D.ONE IN FRONT OF ME AND IT MEASURES 1.065 ON THE O.D. THE MFG. IS FEDERAL MOGUL AND THE PART NO. IS PB 656. HOPE THIS HELPS
REWINDER
clay69
clay69
Loc: MD
Reg: 10-10-01
12-12-06 02:46 AM - Post#1049180
    In response to rewinder
In my experience they do need to be a bit snug you don't want them to spin while in the crank. I would carefully sand the outside of the bushing until it fits by tapping it in with a brass drift or a hard plastic hammer.
07 Ducati monster
96 CE corvette
57 2DR Belair
91 flhs
98 Hardtail chopper
68 2DR Chevelle (sold)
54 Chevy (sold)
www.picturetrail.com/clay5769
12-12-06 03:08 AM - Post#1049181
    In response to clay69
In the history of the Chevy V8 engine, TO THE BEST OF MY KNOWLEDGE (and I believe others who are knowledgeable of Chevy engines will agree), there have only been 2 sizes of holes in the rear of Chevy V8 cranks. One hole is the "standard" size hole and the other was a bigger hole that was machined for engines that were to have a Turboglide behind them. When the Turboglide was discontinued, there was only ONE size hole in the rear of the crank. I know of no other size hole and I've been screwing with Chevys for over 40yrs.
The pilot bushing is supposed to be an interference fit--------------------SUPER TIGHT! The ideal tool for installing a pilot bushing is an old tranny input shaft. Place the bushing on the end of the input shaft (one end of the bushing hole is beveled, that goes toward the outside), put a little grease on it and drive it in with a big hammer until the bushing is flush with the hole in the crank (don't drive it deeper).
Tom Parsons
57belairman
57belairman
Loc: Missouri City Texas USA
Reg: 03-16-02
12-12-06 03:26 AM - Post#1049182
You can taper the leading edge slightly to help get it started. Not too much!! A light coat of grease helps too. If you have pounded on it too much you might have destorted it too. Get a new one and start over. Use a brass or alum drive punch.
Life is short, Eat dessert first, I always do!!
Picturetrail
57 2dr ht red
57 Convertible
57 Nomad
57 2dr Sedan
57 3100 Pickup
55 2dr Sedan
56 Suburban
Old_Longboarder
Old_Longboarder
12-12-06 03:45 AM - Post#1049183
I totally agree with this statement.
An old input shaft cut off just ahead of the bearing. They also work well for removing pilot bushings from the back of the crank.
"The most precious jewels you'll ever have around your neck are the arms of your children."
57_sedan_delivery
Old as Dirt Member
Loc: Hog Valley, Fla.
Reg: 02-19-01
12-12-06 03:57 AM - Post#1049184
I didn't cut mine off but left the gear in place as a 'handle' for aligning the clutch disc but when installing a pilot bushing I put a piece of wood over the end of the gear to tap on.
Mike W.
Founding father Desert Classic Chevys in Phoenix, Az.
1957 sedan delivery 454 TH400
1956 windowed sedan delivery US Dept of Ag car
1956 Chevy 3100 US Navy pickup
1959 rare GMC 100 fleet option 100 pickup
55_150coupe
Junior Contributor
55_150coupe
Loc: OFFLINE
Reg: 02-21-06
12-12-06 06:04 AM - Post#1049185
Can you put the bushing in the freezer before installing it to contract it a little?
Maybe also warm the flange with a torch too?
Also, what about this post?
http://www.chevytalk.org/threads/showfla...rue#Post1534283
Loc: San Francisco, CA, USA
12-12-06 08:33 AM - Post#1049186
    In response to 55_150coupe
When I worked in the parts business we stocked an undersized bushing to be used when automatic engines were converted to stick. Apparently, some of the factory installed crankshafts were not bored to finished diameter. I have never run into this problem on replacement engines or cranks.
Unfortunately, I never bothered to mike one of those undersized bushings, so I don't know what size they were. I believe the normal ones are about 1.095". It would probably be best to mike your crank bore, especially if you suspect the engine originally came with an automatic.
Live more responsibly. Eat lower on the food chain. Eat vegetarians.
Snake
Snake
Loc: Danville, CA
Reg: 06-08-05
12-12-06 08:36 AM - Post#1049187
Thanks very for the help everyone.
I'll measure it and try to figure things out from there.
Jake
beejay
beejay
Loc: Pflugerville, Texas
Reg: 06-01-04
12-12-06 09:38 AM - Post#1049188
Jake,
I believe you're putting in a 5-spd, aren't ya? If so, are you going to use the bearing or bushing to fit? A couple of guys have used the bushing rather than the bearing. Just curious.
Bruce
Bruce
http://www.picturetrail.com/beejay3/"
Snake
Snake
Loc: Danville, CA
Reg: 06-08-05
12-12-06 09:56 AM - Post#1049189
    In response to beejay
I got a bushing with the clutch kit, but also bought a bearing which I planned to use instead. After reading up on them a little there are reports of them coming apart on here so I'm going to switch back to a bushing I think.
Jake
beejay
beejay
Reg: 06-01-04
12-12-06 10:05 AM - Post#1049190
Jake,
I think that's an excellent choice. That's what I'm gonna use when I get around to doing my car.
Bruce
Bruce
Seon
Loc: Lake Camanche, CA
Reg: 07-14-02
12-12-06 02:19 PM - Post#1049191
    In response to 57belairman
Never put grease on the o.d. of the bearing. It'll cause it to spin in the crank after awhile. Always tap it in dry.
Snake
Snake
Loc: Danville, CA
Reg: 06-08-05
12-12-06 02:39 PM - Post#1049192
    In response to Seon
Is it ok to lubricate the inner part of it where the tranny input shaft sits?
Jake
12-12-06 02:48 PM - Post#1049193
If it makes you feel good, OK, but don't over do it and allow lube to get on a friction surface.
The bronze bushing is made from a material called "Oilite", it has oil impregnated in it. The caged needle bearings need little lube, a touch of it would be ok. The sealed ball bearings are permanently lubed internally, do not use lube.
Remember that your pilot bearing and your throwout bearing only have relative motion when the clutch pedal is depressed - the rest of the time the pilot bushing, crank, and input shaft spin together, and the throwout bearing does not rotate on its retainer.
Snake
Snake
Loc: Danville, CA
Reg: 06-08-05
12-12-06 03:21 PM - Post#1049194
    In response to Rick_L
That makes sense, thanks again.
Jake
Coley
Loc: Milledgeville, IL. 61051
Reg: 11-23-00
12-12-06 07:41 PM - Post#1049195
I always put some inside and some on the outside to help it slide in. Never had one come loose yet.....
Any man that thinks he is too old to learn new things, probably always was....
12-13-06 03:39 AM - Post#1049196
I've been screwing with these old Chevys for almost 45yrs.
As a result, I have formed an UNSCIENTIFIC opinion about pilot bushings/bearings.
First, the GOOD bronze bushing is my preference. They are softer than the nose of a tranny input shaft and all they will do is wear and the hole will become enlarged. The tranny nose won't become damaged.
I've seen, as well as personally had the roller bearing type of pilot bearing go bad. One of them was essentially powder!!! When the rollers go bad, they CAN damage the nose of the tranny input. Not good!
Very honestly, as long as it is in good condition, the roller bearing is probably better------------------------but in my personal opinion and observations, the potential damage that can result to the input far outweighs the benefit of a roller bearing!!! If you do use the bearing, there is no question that it needs to be thoroughly greased. How much grease? I don't know, but once the bearing is filled with grease, you can't add any more.
I am also a strong believer of greasing a bushing, but, once you put plenty of grease in the bushing hole, then insert the nose of the tranny input shaft, there is no way to add additional grease. But grease it anyway.
Last, this is just one of those little things which needs to be inspected EVERY time the tranny is pulled or the clutch is removed. CHECK THE BUSHING!!!!!!!!!!!!!! OK, how do you "check" the bushing. I do it with the clutch removed. I use an old input shaft inserted into the bushing. Over the years I have learned just how much looseness there should be between an input nose and a brand new bushing (one of those things you just learn from years of experience). When I insert an input nose into a used bushing and wiggle it up and down, I can tell if the play is OK or too much. Once you learn how to remove a used bushing with grease and an input, it is too quick and easy to change the bushing. The effort and expense of replacing a pilot bushing is so cheap and easy that it is difficult to justify not doing it.
Tom Parsons
Rons55
Loc: Upstate New York
Reg: 02-20-06
12-13-06 09:27 AM - Post#1049197
Not to interupt this thread, but what is the best and easiest way to remove a bushing or bearing.
Thanks, Ron
Snake
Snake
Loc: Danville, CA
Reg: 06-08-05
12-13-06 09:46 AM - Post#1049198
    In response to Rons55
The most common method I've heard is to pack the inside with heavy grease, then use a dowel that barely fits the ID of the bushing to drive it out hydraulically.
Jake
Rons55
Reg: 02-20-06
12-13-06 09:52 AM - Post#1049199
Thanks Jake, that's the same method I heard also. Was just wondering if anyone here had some "majic" way.
Thanks, Ron
inline0_0
Loc: Arizona desert
Reg: 03-10-04
12-13-06 10:30 AM - Post#1049200
As DZ AUTO said in his bottom line, or, SnapOn has made a puller for yrs. specifically for this, or, you can tap threads, put a bolt in it & use a heel bar to pry it out or slide hammer connected to the bolt. Once drilled a line of interconnecting holes & collapsed it. Whatever you got handy will do. Doug
12-13-06 10:30 AM - Post#1049201
There are pullers made for pulling them, but I can't see spending the money unless I found one that the grease method couldn't get out. At that point I'd problably just get out the chisels, hammers, and grinders rather than making a trip to the store.
12-13-06 11:02 AM - Post#1049202
It's not "majic", but I run a 5/8"-18 tap into the bushing until it bottoms out. Keep on turning the tap, and it will pull the bushing. If the bushing is very badly worn, you may need to go to the next size larger tap.
Old_Longboarder
Old_Longboarder
12-13-06 11:35 AM - Post#1049203
Magic way?
If the crank is out of the engine, you can stand it on end and use 30 weight oil instead of grease to hydraulic the bushing out.
Old Ken 55
Junior Contributor
Old Ken 55
Loc: Elk Rapids, Michigan
Reg: 02-16-05
12-13-06 11:48 AM - Post#1049204
I used a socket and but it in a extenion backwards. Wrap the socket with duct tape to get it to fit snug the load the inside of the bearing with grease and tap the socket in the hole. You'll have to do it a few times but it works. Good Luck
http://www.picturetrail.com/gallery/view?uid=4453 9...
Rons55
Reg: 02-20-06
12-13-06 11:54 AM - Post#1049205
Great feedback and thanks for the idea on tap for a bolt method. Sound like a good alternative. Going to install a TKO600 I have soon and of course Keisler sends you a roller bearing. We have one on a 383 for the last five years without a problem so far, but with all the comments I still think a good bronze bushing is the way to go. Thanks again guys, and great site. Ron
CJS57
CJS57
Loc: New Milford , Connecticut
Reg: 01-18-05
12-13-06 12:07 PM - Post#1049206
I turned down a stock bushing to fit my undersize bone stock 57 283 pilot hole, when I converted to stick from powerglide. Someone else posted my older thread showing the details.
-----Also I called the Tremec Engineering Dept. and they approved my use of a bushing rather than a bearing with regards to warranty issues. They also said it will work fine. It is still working great too!
-----I agree that some early 283 cranks that came with Powerglide were never finish reamed and so that is why this situation happens sometimes.
-----Also to remove the old bushing you can just use that size of a bolt from Home Depot for about a buck, no need to get a tap, just grind some flutes into it and put a slight taper on its nose.
1957 Belair 2Dr Hdtp, 58,000 original miles, original never rebuilt 283 engine, 245hp, Dual Fours, Tremec TKO 600 5-speed, 3.70 gears, AACA Senior in 1985
previous trifives:
1955 Belair Convt
1956 210 2dr Sdn
chronamyd
Reg: 05-02-12
06-18-12 05:43 PM - Post#2238896
Hi Jake Their are 2 different pilot bearings. the standard size one is 1.095 od and the other one is 1.065 od. the part # for the large one is PB 656 and the part # for the smaller one is PB 656-P the P stands for powerglide. In the early days if a chevy was ordered with a power glide trans GM did not finish sizing the crank hole. I am going through this right now. Thanks Dwight
Execution time: 0.198 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:41 PM
