Username Post: Temperature sensor location        (Topic#142375)
GMCratblock
Loc: Bremerton WA USA
Reg: 05-19-02
10-16-06 01:46 PM - Post#1019203
I have a '02 2500HD, and I am installing the temp/compass mirror, but can't find the outside temp sensor location and pigtail for it. Anyone have one they can look at and tell me where it is at? The truck is wired in the cab for the mirror, but apparently the sensor is not installed.
2000 GMC K2500 Crew Cab 7.4l 2002 Chevy 2500HD std Cab 4X4 6.0l
ExaTorq
Loc: Dallas, TX
Reg: 07-16-03
Re: Temperature sensor location
10-17-06 02:21 PM - Post#1019204
    In response to GMCratblock
On the '03s it's behind the passenger-side turn signal light. Did you look there?
Brian '03 Tahoe 5.3L FFV/ Wester's 89/91 tune / Outlaw CAI
GMCratblock
Reg: 05-19-02
10-18-06 01:46 PM - Post#1019205
    In response to ExaTorq
Yeah, discovered that, but did not find the pigtail for it. I guess it isn't wired for it. I found the connector under the dash for the wires up under the headliner, now if I could find where they are out in the power center I could wire it up myself.
dcarey
Loc: Mineral, VA
Reg: 01-01-03
10-21-06 05:27 AM - Post#1019206
My 05' didn't have one. If your truck doesn't come with the temp/compass/auto dimming mirror, no harness or sensor on the truck. That's how mine was anyway. I bought the mirror, then bought the sensor from Mito, and wired up my own harness.
Dave 2005 5.3 Reg Cab Shortbed 4x4
GMCratblock
Reg: 05-19-02
10-27-06 05:28 PM - Post#1019207
    In response to dcarey
That is the direction I am going too. Sensor and harness is on the way. Based on my wire trace I should have a spot to plug into under the hood, just don't know if I will look that hard for it. Where did you run the wire into the cab?
Execution time: 0.255 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 10:23 AM
