Username Post: The BEST TBI Cam        (Topic#132643)
2ToneGMC
Reg: 05-09-06
05-29-06 01:05 PM - Post#943508
I have a 1988 TBI 350 and I was wondering what the best cam would be. It already has L98 heads, Edelbrock intake, CFM tech throttle body, TB spacer, 14 psi fuel pressure, headers with dual exhaust, and an open air filter. I am currently running the 3702 Edelbrock cam and I am looking for an upgrade.
65_Impala
Reg: 12-29-02
Re: The BEST TBI Cam
05-29-06 03:08 PM - Post#943509
    In response to 2ToneGMC
Is that block set-up for a GM roller cam? If so, then I would use something like a LT1 cam (or it's other variations). A roller cam like this have a much better valve lift profile and would make good power without adding so much duration it kills the streetability.
You really didn't say what the application is or what you're expecting from the motor.
Peter
2ToneGMC
Reg: 05-09-06
05-29-06 04:28 PM - Post#943510
    In response to 65_Impala
The block is the older GM block, 4 bolt main, two piece rear main seal. I don't tow anything with the truck, and I only drive it on the weekend. I wsnt to have good streetability but also have good power through 5,000 rpm.
Thadd
DECEASED Member
Thadd
Loc: Rolling Hills, Ca,
Reg: 12-30-01
05-30-06 02:13 PM - Post#943511
Most cam manufacuters grind a "CompuCam". TBI (and other FI) engines can not handle a big overlap(when both valve are open at the same time), so the compucam (and blower cams) are ground on a big lobe center (114-118) to minimize overlap and not confuse the computer. I honestly think that a stock TBI cam would probably out perform your Edelbrock.
Pick a manufacturer and select one of their cams ground specifically for a TBI...You will love it
racereno
Junior Contributor
Loc: Smoky Mtns. NC
Reg: 03-10-02
05-30-06 05:00 PM - Post#943512
    In response to Thadd
Thadd mkes a good point, the factory computer (ECM) isn't real flexible. That's why cam cos have "Computer Grinds". If you need a lot more see the DynamicEFI link.
As others have said, cam companies grind what they think you need. I have the Crane recommended CompuCam for a pretty much stock 305 TBI with a Edelbrock Performer TBI intake and nothing more than a Flowmaster muffler. What I see is a decent torque increase at around 2500 RPM and up to 4500RPM. That's with the factory gear of about 2.73 or so and it's a good daily driver. If you're not doing alot of other stuff to the stock setup then you'll probably be pretty happy. If you want to look into something a little racier to make the TBI system more efficient on anything from a stocker all the way up to popular strokers then I'd recommend the ultimate TBI ECM setup here: Dynamic EFI.
65_Impala
Reg: 12-29-02
05-31-06 04:45 PM - Post#943513
In that case, I'd look for a cam with no more than about 118 degrees duration and the most lift you can get, which is likely around 0.45". At this level, custom tuning will need to be done directly on the engine since it's very unlikely anything mail-order will work. There are a few good mail-order guys around but it's hard with a really modified engine.
If you're running an auto you also need a higher stall converter. If it's a 700R4 then a S-10 or Vette converter makes a cheap higher stall unit, usually around 2400rpm.
Peter
1983G20Van
Loc: Bedford, Texas, USA
Reg: 11-13-02
05-31-06 06:25 PM - Post#943514
I may sound crazy, but as long as you have a pretty steady vacuum signal you can use as much cam as you want with TBI. My 305 only made 6-7 in/hg of vacuum in Drive @ 700 RPM with the A/C on. In park/neutral with the A/C off and idling at 700 it made roughly 12-13 in/hg of vacuum. I ran it using the stock 1227747 ECM, with DIY chip tuning. It was not that difficult to make it run, drive, and idle great. The L82 cam ( 291/287 advertised, 224/224 @ .050, .450/.461(.480/.490 with my 1.6:1s), 115 LSA, 114 ICL, advanced 4*) in the 305 sounded awesome as well. With the 3.73 gears, 700r4, and 2,800 rpm stall torque converter it was no slug either.
PS-65 MAP is 10.8 in/hg vacuum @ 700 rpm (transmission in Drive)
65_Impala
Reg: 12-29-02
06-01-06 03:36 PM - Post#943515
    In response to 1983G20Van
Yes, something like that cam would be good. I meant to say around 218 degrees duration. I've tuned an engine with 228 degrees and 0.480" lift with 112 LSA and it wasn't that hard but less duration and more LSA would be easier. It also wants a fair bit of rpm's to begin really making power.
Peter
Execution time: 0.248 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:17 AM
