Username Post: My truck jerks hard when shifting 1st to 2nd, why?        (Topic#132130)
90chevyc2500pu
90chevyc2500pu
Loc: Flagstaff, AZ
Reg: 11-02-05
05-21-06 09:34 PM - Post#939504
ok so i have a 1990 c2500 with a 5.7 350 (fuel injected) and a 700r4 transmission.... my problem is that i get this hard jerk between 1st and 2nd gear... it seems like it doesnt happen when i speed up fast or speed up really slow, it only seems to happen when accelerating at a "normal" rate...
does anyone know what im talking about.. im think of selling my truck but i need to know what the problem is before i sell it. if anyone needs me to explain more ill try to the best of my ability, but it will be in lamens terms, i cant really talk technical, try to use lamens/easy to understand terms with me, that would really help....
thanks for any helpful input its greatly appreciated
-Patrick
Patrick My Truck At Car Domain
90chevyc2500pu
90chevyc2500pu
Loc: Flagstaff, AZ
Reg: 11-02-05
Re: My truck jerks hard when shifting 1st to 2nd,
05-21-06 09:41 PM - Post#939505
    In response to 90chevyc2500pu
forgot to mention it doesnt do it as hard when it warms up... but it does it really hard when the engine and transmission are cold after sitting out all night... i hope someone can tell me what is wrong
robin58
Loc: Louisiana
Reg: 10-27-04
05-22-06 04:56 AM - Post#939506
Did anyone maybe install a shift-kit in that transmission?
1953 Chevy 3100 1990 Chevy C1500 Ext Cab 350 - 238,000 1995 Chevy S10 Ext Cab 4.3L - 229,000 1995 Chevy Suburban K1500 4X4 350 - 198,000 1997 Chevy Metro LSi 1.3L - 185,000 (35plus mpg )
90chevyc2500pu
90chevyc2500pu
Loc: Flagstaff, AZ
Reg: 11-02-05
05-22-06 01:27 PM - Post#939507
    In response to robin58
i personally dont know, but im having the gm shop look at it tomorrow. so ill go from there
MustGoFaster
MustGoFaster
Loc: Oregon
Reg: 11-28-03
05-23-06 12:05 PM - Post#939508
thats an expensive move. now you're going to have to sell your truck for sure!
Al
91 K1500 EC/SWB, 322k original miles
79 Jeep Cherokee Chief, off-road toy
07 Mazdaspeed3, bolted track rat
JasonZ
Loc: San Antonio Texas
Reg: 02-21-03
05-23-06 12:38 PM - Post#939509
    In response to MustGoFaster
Al
No way he has to sell his soul now.
Why cant any of you people having trouble with their trucks live nearby me.
Don't go BROKE trying to look RICH. Act your WAGE!!
90chevyc2500pu
90chevyc2500pu
Loc: Flagstaff, AZ
Reg: 11-02-05
05-23-06 01:27 PM - Post#939510
    In response to JasonZ
well i ment wednesday, i lost track of time...
the guy before me didnt install a shift kit, he said he never did anything to the transmission, so i guess the answer to that is no... does anyone haave any ideas as what this is, ive heard from others that it can be "link slippage"? and others say their truck has been doing it for years and nothing serious has happened and it hasnt gotten worse...
thanks
robin58
Loc: Louisiana
Reg: 10-27-04
05-24-06 03:39 AM - Post#939511
Well add me to the group of mine has always done it. And it's kept doing it after two rebuilds for other issues.
Unless you have other problems with the transmission, I'd save the money until something really goes wrong.
Just make sure you get more than one opinion locally and whatever you do, do absolutely NOT go to some quick lube place and have them do a transmission fluid "flush". Those types of establishments rarely drop the pan and resort to sucking the fluid out instead which can cause all kinds of issues in a short period of time particularly if it's been a long time since that fluid was changed.
transman618
transman618
Loc: Cumming,GA
Reg: 06-06-04
05-24-06 04:48 AM - Post#939512
I would check the TV cable first, it could be adjusted too tight. Secondly, these transmissions have a tendancy to have wear in their accumulators. The aluminum pistons in the accumulators have a pin going through the center of it. The pin will eventually wear the bore out until it is "Egg shaped". When this happens, the accumulator will leak causing rough shifting. Basicly what an accumulator does is cushion the shift. If it is leaking, the shift will be harsh. The 1-2 accumulator is mounted inside the pan in the right rear side of the transmission. If the transmission is otherwise operating properly, you can have the shop check this accumulator.
transman
GM MASTER TECHNICIAN
SR. TRANSMISSION BUILDER
90chevyc2500pu
90chevyc2500pu
Loc: Flagstaff, AZ
Reg: 11-02-05
05-24-06 11:32 AM - Post#939513
    In response to transman618
yea i decided not to take it to the shop today, i figured since there are others that have this problem even after rebuilds... tyhe transmission is working properly except for that jerk, but theres no other problems with it... if anything gets worse within a month i will have the shop look at it, but for now theres no need for a shop.
thanks for all the input ill post again if anything gets worse.
MustGoFaster
MustGoFaster
Loc: Oregon
Reg: 11-28-03
05-24-06 02:03 PM - Post#939514
mine slams so hard into second gear it rattles your teeth loose. it all so slams into 3rd, and even the converter locks in with some serious punch. gotta love a trans thats built!
Al
Lowgear
Lowgear
Loc: New England
Reg: 01-19-05
05-25-06 12:41 PM - Post#939515
Mine does something like that after it sits for like 4 or 5 days without being driven. Also my truck still won't go above 70! I think it might be the converter. Instead of having it fixed though I spent 2 grand on an r/c boat im building. With money I don't have anyways. I have messed up priorities weeeeeeee!!!!
custom 93 c1500
blown 68 camaro
EricZ71
EricZ71
Loc: Western Massachusetts
Reg: 02-11-04
Re: My truck jerks hard when shifting 1st to 2nd, why?
05-26-06 02:28 PM - Post#939516
My 700r4 does the same exact thing, a significantly hard shift from 1st to 2nd, that seems more noticeable when the engine / trans is cool. It's done this since I bought the truck 3 years ago and hasn't gotten any better or worse. I just keep changing the trans fluid at the specified intervals and it seems to be pretty happy otherwise.
Eric
1983 Chevy K30
eddie_truckn
eddie_truckn
Loc: Eufaula, Alabama
Reg: 10-25-04
05-31-06 11:31 AM - Post#939517
Man, wish I'd read this post! I did exactly what you said not to do. Now my tranny is shifting hard if every gear.
Got a feeling it going to be expensive..........
1990 C1500 Sportside "A KEEPR" 350 Vortec 700R4 Too much custom junk (stuff) to list!
Execution time: 0.561 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 01:56 AM
