Username Post: Are Suburban doors/Truck doors the same?        (Topic#128146)
boogie
boogie
Loc: Louisiana
Reg: 07-11-02
04-02-06 01:30 AM - Post#908488
Will '90 Suburban front doors fit a '84 K20?
The doors are rusted bad at the bottom on my '84 Truck and I found a '90 suburban donor with good doors.
Thanks!
'85 GMC C1500 SWB 355 sbc
DetroitDan
Loc: NH
Reg: 04-10-04
Re: Are Suburban doors/Truck doors the same?
04-02-06 03:45 AM - Post#908489
    In response to boogie
yes. The only difference I am aware of is if they have electric windows you'll have two extra buttons on the drivers side. I always wanted to wire something extra to those two buttons, but never got around to it. Would have been some neat James Bond stuff. I put 78 Suburban doors on a 79 K10. Cabs, doors and bed were interchangeable from 73 to 87 on the pickups, and the doors up to 91 on Blazers and Subs. Gotta love the interchangeability of those trucks. Virtually every drivline part is interchangeable too. You could use the entire front clip and radiator support, the 89-91 Sub/Blazer nose was a common mod. My 81 K20 had a 90 GMC Jimmy nose on it, gives it a more modern look.
"Turn signals, they're not just for smart people anymore" 66 Caprice 2 dr 327/350 66 Impala 2 dr sport, 5.0 HO, 2004r, SOLD 69 Camaro 350/350, daily driver SOLD
Chevy_Stepside
Chevy_Stepside
Loc: San Francisco, Ca, USA
Reg: 07-08-02
04-02-06 06:14 AM - Post#908490
    In response to DetroitDan
I am about to interchange an 88 suburban trans and transfer case in my 79 so I can have some overdrive... Now I think I might even cut the burb frame down to put my 65 short box body on... only time will tell...
"A man and his truck, It's a beautiful thing"
The tour is on again. May 1st 2011. $5 I ride 100 miles. http://main.diabetes.org/site/TR?pg=personal&a mp;f...
Senior Chevytalk Moderator
04-02-06 02:38 PM - Post#908491
    In response to Chevy_Stepside
Only the front doors!!
boogie
boogie
Loc: Louisiana
Reg: 07-11-02
04-02-06 03:36 PM - Post#908492
Thanks for the info guys! Nice to come here and find out for sure
Suburbanator
Reg: 12-04-03
04-02-06 03:55 PM - Post#908493
The back doors would work on a 3+3 right?
1969 Chevelle on the dyno
1965 Custom Camper
04-03-06 05:19 PM - Post#908494
    In response to Suburbanator
Yup
87Last1
Loc: Southeastern PA.
Reg: 01-09-04
04-24-06 03:48 PM - Post#908495
I come across a 87 Sub in the bone yard today and the doors are in excellent condition and the door panels are to.No rust at all under the bottom and checked all over the outside for bondo with a magnet.They have pwr windows and door locks also.I can buy them for $250.oo with all the wiring and ect.I will be taking them out and will be able to tag everything for reinstalling them. My 86 C10 has roll up windows and will be making the swap in the future.Has any one made this change and what [if any] problems did you have? Also other than the wiring harness is there any thing else I should remove? How does the price sound for these?I live in the north east and doors like these are hard to find.Thanks in advance for any comments or advice.
86 Silverado Short Box,350/330,700R4 Trans,308 Posi,Frost White
85 Monte Carlo SS,305 Cu In,373 Posi
70 Monte Carlo,ZZ454/440,331 12 bolt posi,Astro Blue/Blue vinyl,loaded
70 Monte Carlo ZZ427/525, 12 Bolt 331 Posi,Tac Gauges, Turquoise/Blk Vinyl
RanchTruck
Loc: Whitewright, Tx.
Reg: 12-04-03
04-25-06 08:25 AM - Post#908496
    In response to 87Last1
The doors will fit, make sure you get the entire harness. It will include the relays for the locks. It will also have the switched and non-switched hot leads. Do not cut the back door leads off, just unplug the rear doors (plugs are in the door post). Good Luck with your project.
1980 K30 454,4 speed, dually. Honest Ranch Truck
87Last1
Reg: 01-09-04
04-25-06 02:12 PM - Post#908497
    In response to RanchTruck
I was thinking about where to disconnect the rear door harness,I'll look for those plugs that you mention.I'm heading for the yard tomorrow.Hope they are still there and not damaged,you know how those guys move things around and how gentle they can be.LOL Thanks for the info
Execution time: 0.284 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 08:01 AM
