Username Post: 02 Silverado knocking noise when warm        (Topic#116265)
whazzup
Loc: California
Reg: 11-07-05
11-07-05 10:49 AM - Post#811553
I get a knocking noise like its lifters when the engine is warm. I've tried a thicker oil but that didnt help. Took it to the dealer when it was under warranty but they didnt hear any noise. Seems to be loudest under the front wheel well on the driver's side. Motor seems to run fine though, noise is just annoying.
CaptainK
CaptainK
Loc: Maryland
Reg: 02-25-02
Re: 02 Silverado knocking noise when warm
11-07-05 01:57 PM - Post#811554
    In response to whazzup
Does the noise go away after driving for a bit?
'99 Silverado (NBS)
nodakbassmaster
nodakbassmaster
Loc: Poorhouse, SD
Reg: 03-14-04
11-07-05 07:03 PM - Post#811555
don't know what you have for mileage but try some Techron feul system cleaner or a seafoam treatment and that might help. Maybe seafoam first
'09 Silverado 3500HD CC LB D/A LTZ Z71, Mods Annonymous Member #3
whazzup
Loc: California
Reg: 11-07-05
11-07-05 08:51 PM - Post#811556
    In response to nodakbassmaster
I have about 45k miles and the noise can only be heard while idling. Not sure if the noise stops when driving, can't hear over the road and engine noise. Its more of a clacking noise then knocking. Almost like valve clatter but I cant hear it very well from the hood, only off to the left front wheel well.
I'll have to try some of that foam stuff. What is it suppose to do?
nodakbassmaster
nodakbassmaster
Loc: Poorhouse, SD
Reg: 03-14-04
11-08-05 05:17 AM - Post#811557
it's a cleaner- suck 1/2 to 3/4 of a can in through a vacuum line (i use the brake booster line) just slow enough the engine doesn't die. Shut the truck off for 20 to 30 minutes and then crank it back up. It will smoke like hell for a little while but it helps clean carbon and junk out of your engine. It has helped people with similar noise before, and it's cheap and easy!
HDANDY
Loc: Nooksack WA
Reg: 03-05-04
11-09-05 11:52 AM - Post#811558
Got yer problem to a tee,let me know if anything helps. I've had it while warm for about 30k but only at idle, or i should say when idling it goes away after 900 rpm or so. Did see a tsb quite a while ago that stated my exact symptoms but havent given it a go yet...
Engine Knock or Lifter Noise (Replace O-Ring) #02-06-01-038 - (12/02/2002)
2001-2002 Chevrolet Camaro
2001-2003 Chevrolet Corvette
2001-2002 Pontiac Firebird
2002-2003 Cadillac Escalade, Escalade EXT
2000-2003 Chevrolet Suburban, Tahoe
2001-2003 Chevrolet Silverado
2002-2003 Chevrolet Avalanche
2000-2003 GMC Yukon, Yukon XL
2001-2003 GMC Sierra
with 4.8L, 5.3L, 5.7L or 6.0L V8 Engine (VINs V, T, Z, G, S, N, U -- RPOs LR4, LM7, L59, LS1, LS6, LQ9, LQ4)
Condition
Some customers may comment on an engine tick noise. The distinguishing characteristic of this condition is that it likely will have been present since new, and is typically noticed within the first 161-322 km (100-200 mi). The noise may often be diagnosed as a collapsed lifter. Additionally, the noise may be present at cold start and appear to diminish and then return as the engine warms to operating temperature. This noise is different from other noises that may begin to occur at 3219-4828 km (2000-3000 mi).
Cause
The O-ring seal between the oil pump screen and the oil pump may be cut, causing aeration of the oil.
Correction
Inspect the O-ring seal and replace as necessary. Use the applicable part number listed below. Refer to the Engine Mechanical sub-section of the appropriate Service Manual.
Parts Information
Part Number
Description
Qty
12557752
Seal-O/Pmp (O-ring)
(F and Y Cars)
1
12563963
Seal-O/Pmp (O-ring)
(C/K Trucks)
1
Parts are currently available from GMSPO.
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Usage
Labor Time
J1060
Pickup Tube and Screen - Replace
F Car
3.7 hrs
Y Car
4.3 hrs
C Truck
1.3 hrs
K Truck
2.1 hrs
'07 D/Max Ally Crew Cab White SB Hijacker 16k usdp '06 Cougar 314 5er Bunkhouse
butch02denali
butch02denali
Loc: Middleton, MA
Reg: 04-14-03
11-10-05 05:18 AM - Post#811559
    In response to HDANDY
Another possibility could be the injectors. Some get pretty noisy when hot. More of a clicking sound, higher pitched than a lifter sound. (sounds are very difficult to describe with words!!!)LOL
Butch 02 Sierra Denali Wester's 91/93 Hot tune/Outlaw intake Custom Exhaust/Aeroforce Interceptor gauge
whazzup
Loc: California
Reg: 11-07-05
11-14-05 07:33 AM - Post#811560
Great info guys! Thanks alot for the replies.
So if there is a service bulletin will the dealer repair my truck under warranty since I am out of warranty now?
Do you have the exact TSB number so I can reference it when calling the dealer?
HDANDY
Loc: Nooksack WA
Reg: 03-05-04
11-14-05 07:55 AM - Post#811561
Engine Knock #01-06-01-022
Engine Knock #01-06-01-028
Engine Knock #01-06-01-028A
Cold Engine Tick #01-06-01-005
Engine Oil Consumption #01-06-01-011
Engine Oil Consumption #01-06-01-011A
Not Related
Engine Knock or Lifter Noise #02-06-01-038
Hope this helps, to my knowledge tsb's are an awareness recognized by gm that the consumer absorbs as a cost to them......... I guess the info is free. The last number #02-06-01-038 is the one I posted
hauler
hauler
Loc: Europe
Reg: 11-11-05
11-19-05 10:41 AM - Post#811562
My truck has 100 000 & the same noise you describe, but I just ignore it.
77 C 30 custom deluxe LPG powered 87 1/2 Ton GMC fully loaded Y2K Silverado 1500 Whipple Supercharger Bigfoot 9.5 slide-in camper
NC_Redneck
NC_Redneck
Loc: Northern California
Reg: 07-09-04
11-20-05 06:27 PM - Post#811563
    In response to hauler
SEAFOAM!
2002 1500 Z71 Ext.Cab S.B. Victory Red 33in. Mud Terrain Tires Flowmaster Exhaust TrueFlow Cold Air Intake Kit Wester's Hot Tune 1970 El Camino
nodakbassmaster
nodakbassmaster
Loc: Poorhouse, SD
Reg: 03-14-04
11-20-05 06:49 PM - Post#811564
    In response to NC_Redneck
that has gotten rid of some peoples and made others quieter
NC_Redneck
NC_Redneck
Reg: 07-09-04
11-20-05 07:07 PM - Post#811565
I swear by that stuff.
HDANDY
Loc: Nooksack WA
Reg: 03-05-04
11-20-05 07:29 PM - Post#811566
definately da bomb....gotta do it alot though.You'd think that once it was done it would quiet up....guess all those times I passed f*rd's and Do*ges built up a little carbon huh...That is it dont take much.
nodakbassmaster
nodakbassmaster
Loc: Poorhouse, SD
Reg: 03-14-04
11-20-05 07:37 PM - Post#811567
willz06jw
Reg: 11-22-17
11-22-17 07:10 AM - Post#2715298
I fixed this problem on my truck by changing the Oil Pump Inlet Tube O-Ring. The lifters are the first part that don't get enough oil after this o-ring breaks down. All Chevrolet mid 2000s era 5.3L O-Ring fails around 150-190K.
Oil Pump Inlet tube O-Ring Replacement
https://www.youtube.com/watch?v=g1e3kx3mOMY
Execution time: 0.262 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:53 PM
