LMC Truck
Username Post: 99 Suburban Coolant Leak, not intake manifold...        (Topic#115695)
squelly
Reg: 10-31-05
10-31-05 08:13 AM - Post#806983
First post, I'm an engine illiterate.... That said I seem to be leaking coolant from this spot in the engine.
This is not the Intake manifold gasket, right?
What is this part, and what should it cost to replace? I'm new to my area, and don't have a trusted mechanic. Your thoughts and input would be appreciated!
THanks!
LMC Trucks
HA139
Reg: 07-11-04
Re: 99 Suburban Coolant Leak, not intake manifold...
10-31-05 08:34 AM - Post#806984
    In response to squelly
Welcome to CT.. this place is great. The fitting that is leaking is the Heater Hose Fitting.. they are notorious for leaking. When you try to remove the fitting, it will likely break. Auto Parts stores in my area (Auto Zone & Oreillys) sell a tool that taps into the broken off section and turn it out. Some people use a small hacksaw blade the saw it out in small sections.I have replaced 3 of them using the tap in tool. When the last one went, I replaced it with a steel fitting and then rubber hose over to the connection under the air filter box. People around here love to give advice and help you out. Best of luck.
Michael
2009 Chevrolet Suburban
2007 Pontiac Grand Prix
Oklahoma City, Oklahoma
squelly
Reg: 10-31-05
10-31-05 09:23 AM - Post#806985
    In response to HA139
HA139 -- thanks for the reply. Do you have a part number or reference I can use to find that fitting? I'm looking thru Advance Auto parts, but none of the fittings seem to look like that one (and if you have a name for that tap tool, too, it would be great!)
HA139
Reg: 07-11-04
10-31-05 10:12 AM - Post#806986
I will see what I can find tonight after I get home.
Michael
squelly
Reg: 10-31-05
10-31-05 10:26 AM - Post#806987
much obliged.
HA139
Reg: 07-11-04
11-01-05 02:53 AM - Post#806988
Sorry it took soo long. The fitting extractor is called a Heater Hose Fitting extraction Tool. The part # I came up with is an Oreilly's part #. Dorman brand Part # 800-401 $ 9.99 . I got my new set up (1/2" steel fitting with end you jus put hose on and then put a hose clamp) @ Auto Zone for less than $10 with hose fitting etc. I cant come up with that part number. Hope this helps;
Michael
squelly
Reg: 10-31-05
11-01-05 09:47 AM - Post#806989
Great info, thanks. I appreciate you getting that info for me, it really helps!
Anonymous
11-02-05 07:47 AM - Post#806990
I personally would not remove the fitting but instead disconnect the quick connect and put on a new o-ring from the dealer and a little sil-glyde. Snap it back together and it will last another 10 years. That is what I did. It takes 5 minutes and you won't be drilling, sawing or swearing about the fitting breaking off in the manifold.
jp233
jp233
Loc: ATL, GA
Reg: 03-15-04
11-02-05 10:08 AM - Post#806991
    In response to
I recently replaced that fitting on my truck, and it wasn't that bad.
Mine was leaking just like yours was. That pewter piece is JUNK!!!!
Yup, it broke clean off right when I put the socket on it. I used a hacksaw blade to cut some slots then chiseled out the remains, vaccuumed out what I could (I could mostly grab big pieces with needle-nose pliers and pull them out), put some black silicone on the threads of the new one, tightened it up and no leaks whatsoever.
I have another one of the fittings, they come in packs of two from gmpartsdirect.com and I couldnt split it - do you want it?
'99 Ford F-250 SuperDuty 7.3L diesel
sold '97 Chevy Tahoe Z71
several Subarus
several bikes
not enough time
jp233
jp233
Loc: ATL, GA
Reg: 03-15-04
11-03-05 03:45 PM - Post#806992
    In response to jp233
a pair of those new fittings costs like $10 (i bet if you buy it in person at a dealer you can split it up).
the new steel p/n is 24503681
check out this thread: http://www.chevytalk.org/threads/showflat.php?Cat=0&Number=1301634&an=0&page=0#1301634
hope it helps
several Subarus
several bikes
not enough time
LMC Trucks
Execution time: 0.202 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 05:18 AM
