Username Post: Exessive Rear Tire Bounce......        (Topic#108635)
Chevydudesixty9
Chevydudesixty9
Loc: El Paso, TX
Reg: 07-16-05
08-03-05 06:55 PM - Post#753651
I have a 99 silverado Ext.Cab and i have exessive tire bounce on the right hand rear side. I thought the tires were lumpy but ive rotated them and this still keeps happening. This only happens at high speeds. Around 75MPH. The Steering Wheel also begins to bounce around. Its now to the point were I have to Slow down to correct the Problem but it gets Very Destracting. Also There is alot of Front End bounce. I cant hit a speed bump or dip at more than 10 mph because Ill be In the Passenger Seat from so much bounce. Will lowering the truck with a good kit slove thall of this. Im thinking is the suspension. Not sure.
Please Help.
99 Silverado Ext.Cab 5.3
CDAUSA
Needs to Get Out More Member
Loc: Texas Panhandle
Reg: 12-31-01
Re: Exessive Rear Tire Bounce......
08-03-05 07:15 PM - Post#753652
    In response to Chevydudesixty9
Shocks control movement, start there first. If the bounce also bounces the bed---the shock may be seized and will soon break or break one of the mounting points.
What tires and how much air are you running in them? And I suppose this is in an empty bed?
nodakbassmaster
nodakbassmaster
Loc: Poorhouse, SD
Reg: 03-14-04
08-03-05 07:37 PM - Post#753653
    In response to CDAUSA
my vote, shocks!
'09 Silverado 3500HD CC LB D/A LTZ Z71, Mods Annonymous Member #3
WVRidgeRunner
WVRidgeRunner
Loc: This week: Hill AFB, UT
Reg: 03-20-04
08-03-05 07:44 PM - Post#753654
    In response to nodakbassmaster
That would be a SHOCKing experience. I would be SHOCKed if replacing the SHOCKs didn't fix the problem. I second the vote for SHOCKs...
WV Ridge Runner
- 05 Impala LS
- 03 Black Silverado 2500HD 4X4 LB CC LT
- 93 S-10 4X4 Blazer (Tahoe LT)
- 79 Monte Carlo
- Harleys, 4-Wheelers, etc...
- New! 07 Cobalt
nodakbassmaster
nodakbassmaster
Loc: Poorhouse, SD
Reg: 03-14-04
08-03-05 07:51 PM - Post#753655
    In response to WVRidgeRunner
wasn't that 4 votes
Chevydudesixty9
Chevydudesixty9
Loc: El Paso, TX
Reg: 07-16-05
08-03-05 09:24 PM - Post#753656
So you think its shock? LOL. I guess if 3,4or 5 people( I didnt count) say its shocks then its shocks. Would help to get a complete lowering system. Beltech? Ive been wanting to lower my truck but I wanted to find out what was the problem first so i didnt mess it up more. A lowered suspension will also correct the front end problem right?
CaptainK
CaptainK
Loc: Maryland
Reg: 02-25-02
08-04-05 01:06 AM - Post#753657
Quote:
wasn't that 4 votes
Yup, and make it 5 now
'99 Silverado (NBS)
brad6841
brad6841
Reg: 03-10-05
08-04-05 01:51 AM - Post#753658
I vote canootervalve assembly (shocks)
And also lowering your truck will make it handle better but it may also make your ride rougher. The stiffer suspension parts will make the truck ride rougher over bums and uneven pavement. Just a thought if the bums are annoying now they might get worse with the lowering kit.
Brad
2001 2500HD 4X4 LS
sebring95
sebring95
Reg: 06-14-03
08-04-05 02:18 AM - Post#753659
I would just replace the shocks first. They're very likely the culprit, but if not then changing the entire suspension could cause other problems without fixing the first one.
Most of us with fairly new trucks have found the GM shocks to be sub-par even at low miles. You're probably about five years overdue
'03 Silverado 4x4
WVRidgeRunner
WVRidgeRunner
Reg: 03-20-04
08-04-05 02:42 PM - Post#753660
    In response to brad6841
Quote:
The stiffer suspension parts will make the truck ride rougher over bums...
Make sure Johnny Law doesn't catch you doing this!
WV Ridge Runner
- 05 Impala LS
- 79 Monte Carlo
- New! 07 Cobalt
nodakbassmaster
nodakbassmaster
Loc: Poorhouse, SD
Reg: 03-14-04
08-04-05 08:12 PM - Post#753661
they tend to frown on it......
CaptainK
CaptainK
Loc: Maryland
Reg: 02-25-02
08-05-05 12:58 AM - Post#753662
'99 Silverado (NBS)
brad6841
brad6841
Reg: 03-10-05
08-05-05 01:42 AM - Post#753663
OOOOOOOOPPPPPPSSSSS!!!
Please don't test your suspension by running over any bums. Please test it on bumps.
Brad
2001 2500HD 4X4 LS
CaptainK
CaptainK
Loc: Maryland
Reg: 02-25-02
08-05-05 05:40 AM - Post#753664
Oh man,,,, now you tell us
'99 Silverado (NBS)
glsable
Loc: Virginia
Reg: 07-02-03
08-05-05 06:14 AM - Post#753665
Hey, Guys. After re-reading this, I think we're mis-reading SPL's request here. He appear to be asking for a serious technical argument (wink,wink) to convince his S.O. ("Significant Other") that plunking down the dough for a fully-lowered suspension will solve the problem. So, with that in mind, here's my response:
"Yes definitely, you get my vote! Oh, and you better check into a Westers. I hear that might be necessary to get rid of the "shimmy" in the back after you lower it. Glad I could help!"
glsable
2003 K1500 Suburban LT
1993 Caprice wagon
1998 Volvo S70 Turbo
Anonymous
08-05-05 06:51 AM - Post#753666
    In response to glsable
Its the tire(s), they are out of balance or out of round.
WVRidgeRunner
WVRidgeRunner
Reg: 03-20-04
08-05-05 09:18 AM - Post#753667
Quote:
Hey, Guys. After re-reading this, I think we're mis-reading SPL's request here. He appear to be asking for a serious technical argument to convince his S.O. that plunking down the dough for a fully-lowered suspension will solve the problem...
I agree. Print this to show the SO...
Your problem is serious! Stop driving that truck at once!
Your wheels and tires are screwed up, and you need aftermarket replacements. That alone will not fix the problem though... The ONLY WAY you are going to be able to fix that problem is the wheels and tires AND a complete lowering kit, with a C Notch Kit and Air Bags. Yes, you will need the Westers Tune to re-calibrate for the decrease in height, but it will all be worth it to get rid out that bouncing wheel...
WV Ridge Runner
- 05 Impala LS
- 79 Monte Carlo
- New! 07 Cobalt
CaptainK
CaptainK
Loc: Maryland
Reg: 02-25-02
08-06-05 03:11 AM - Post#753668
I would also print this out as well to show the SO that the staff here concurs with what the solution is to address your issue.
'99 Silverado (NBS)
steve v
steve v
Loc: n. cal
Reg: 05-08-04
08-06-05 09:42 AM - Post#753669
    In response to CaptainK
You guys crack me up!
Execution time: 0.277 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 12:22 AM
