Username Post: AntiFreeze leaking from Head Bolt        (Topic#108040)
HotRodg57
HotRodg57
Loc: San Marcos CA USA
Reg: 06-04-01
07-28-05 05:00 AM - Post#749190
I've just noticed I have a slight leak comming from what looks to be a head bolt (not freeze plug!) I tried to tighten it up, but it's tight Any ideas??
On the up side I just had my 700R4 installed. WOW, what a difference! I love it! Used to be turning 3600 RPM's at 70 MPH, now it's right at 2100. Now if someone just tells me what's up with this leak, I'll be a happy camper.
Thanks for your input.
Rodger
Check out my Car Pics
rj_ly
Loc: Southwestern OH
Reg: 11-15-02
Re: AntiFreeze leaking from Head Bolt
07-28-05 06:36 AM - Post#749191
    In response to HotRodg57
Any ideas??
The bolt is tight and you have this leak.
My $0.05 on it = bad head gasket.
57 Hrdtp(mine for 40 YEARS JULY 12)
57 210 4-dr Sdn(37 yrs Aug 12)
57 Hrdtp(32 yrs Jan 12)
57(windowed)S. Delivery(31 yrs Oct 12)
57 150 Wgn(24 yrs Mar 12)
57 210 2-dr Sdn(8 yrs Oct 12)
Bluemeany
Bluemeany
Loc: Santa Clara, CA
Reg: 05-31-02
07-28-05 06:37 AM - Post#749192
The infamous leaky head bolt into the water jacket trick.
Drain radiator until water level is well below the Head bolt that is leaking. Remove the bolt and put on some aviation type gasket sealer on the threads and torque it down. Refill the Radiator and see if leaks. Hopefully it's not a head gasket problem. Congrats on your gas saving from your tranny swap!
57 Hardtop 302 & 3 Speed stick w/OD;
93 Camaro Indy Pace Car
HotRodg57
HotRodg57
Reg: 06-04-01
07-28-05 06:44 AM - Post#749193
    In response to rj_ly
RJ, I'll give you your nickle back I don't want to hear that kind of talk It's on the driver side, middle of the block, just below the header flange. I can see the fluid just below the head of the bolt, nothing leaking anywhere else. I re-torqed all the intake manifold bolts, and everything is tight
Rodger
rj_ly
Reg: 11-15-02
07-28-05 06:47 AM - Post#749194
I had a leak out the driver side tailpipe of my Wagon when I first got it and thought, "Oh man the head is warped."
But I checked all the head bolts and most were loose. After I re-torqued them the leak went away.
doobie's taxiola
doobie's taxiola
Loc: New Jersey shore
Reg: 02-27-03
07-28-05 07:10 AM - Post#749195
At the price of premium (or better) you should recoup the money laid out for the tranny in no time. To us financial wizards that's known as your ROI (return on investment).
HotRodg57
HotRodg57
Reg: 06-04-01
07-28-05 07:49 AM - Post#749196
    In response to Bluemeany
Bluemeney, now that's the kind of answer I'm looking for! THANKS!, That sounds like a job I wouldn't mind doing
I had a couple of my intake bolts leak oil a few months back, and pulled the bolts, put some sealer on the threads and that took care of it! I was hoping someone would chime in with an easy fix. Thanks again!
Rodger
57TOMMY
57TOMMY
Loc: Bay Area , Calif
Reg: 08-19-03
07-28-05 08:29 AM - Post#749197
HEY ROGER
where did you get your 700r if you don't mind my asking? Also , what ratio do you have in the rearend
Stand up for what is right ,even if you stand alone.
HotRodg57
HotRodg57
Reg: 06-04-01
07-28-05 08:38 AM - Post#749198
    In response to 57TOMMY
Tommy, nope don't mind you asking. I traded a buddy a vette engine and 350 tranny I had for it. It's an early 700R4. I believe my rear end has 377 ratio.
57_sedan_delivery
Old as Dirt Member
Loc: Hog Valley, Fla.
Reg: 02-19-01
07-29-05 04:47 AM - Post#749199
I use spray Copper-Coat gasket sealer on the bolt threads when I build an engine for this reason, worked pretty good so far.
Mike W.
Founding father Desert Classic Chevys in Phoenix, Az.
1957 sedan delivery 454 TH400
1956 windowed sedan delivery US Dept of Ag car
1956 Chevy 3100 US Navy pickup
1959 rare GMC 100 fleet option 100 pickup
Old Ken 55
Junior Contributor
Old Ken 55
Loc: Elk Rapids, Michigan
Reg: 02-16-05
07-29-05 05:38 AM - Post#749200
Had the same problem but under the valve cover into the oil. I used Permatex high temp thread sealant #59235 sealed it and on more problems.
Ken
http://www.picturetrail.com/gallery/view?uid=4453 9...
Execution time: 0.238 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 03:48 PM
