Username Post: Keyless entry not working        (Topic#107434)
florida
Reg: 02-20-05
07-21-05 12:40 PM - Post#744840
Hi,
Tried to open truck with keyless entry and no go. Tried 2nd fob, and same result.
Can anyone offer suggestions/advice for a keyless entry that stopped in my '03 Chev Silverado, before I make the trip to the dealer?
Thanks!
LMC Trucks
Squasher
Squasher
Loc: Northern California
Reg: 07-05-02
Re: Keyless entry not working
07-21-05 03:10 PM - Post#744841
    In response to florida
are you sure it's your truck??
I one time had a problem with both the fob and the key. No matter what, it wouldn't open the door. then I relized it wasn't my truck
2001 GMC Sierra K1500 Z71 x/cab SLT 5.3L
Lucky13MN
Special Senior Member
Lucky13MN
Reg: 06-20-01
07-21-05 03:13 PM - Post#744842
I have a how-to for reprogramming the remote on www.gmdiy.info
2001 Silverado:
  • S&B Intake
  • Corsa Exhaust
  • Z06 Cam
  • Air Bags
  • HP Tuners
  • A 'few' other things
WVRidgeRunner
WVRidgeRunner
Loc: This week: Hill AFB, UT
Reg: 03-20-04
07-22-05 05:09 AM - Post#744843
    In response to Squasher
That IS funny...
One time about 15 years ago, I walked up to the wrong Silver 79 Monte Carlo with Maroon Rear 1/4 Landau Top in the grocery store parking lot... The door key worked...
I got in, but couldn't get the ignition key to work... I was frustrated, then noticed that the things laying around in the car were not mine! I was getting out when this very angry woman accosted me...
It was hard to convince here that it was a mistake, until I spotted my Monte 4 spaces over peaking out from behind a Suburban... We had a good laugh after that...
WV Ridge Runner
- 05 Impala LS
- 03 Black Silverado 2500HD 4X4 LB CC LT
- 93 S-10 4X4 Blazer (Tahoe LT)
- 79 Monte Carlo
- Harleys, 4-Wheelers, etc...
- New! 07 Cobalt
Anonymous
07-22-05 06:27 AM - Post#744844
    In response to WVRidgeRunner
yeah older remotes were alot easier to use to open other cars....
I was once walking thru the parking lot at school, clicking my remote... and walked by a car... thump- thump!!!!!
sure enough my remote was opening this cars doors...... I locked it.... and kept walking.
07-22-05 08:44 AM - Post#744845
    In response to
The remore quit on my 99 Silverado. Key wouldn't unlock it and the lever inside wouldn't either. Had to take it to the dealer. Bad actuator. It was locked in the up postion and wouldn't let anything else unlock the door. $321.85 fixed it.
florida
Reg: 02-20-05
07-23-05 10:12 AM - Post#744846
Well, I also noticed that the passenger window & door lock no longer work. Very strange. Any other ideas?
Thanks!
GM-Tech
GM-Tech
Loc: South Florida
Reg: 06-27-03
07-23-05 02:21 PM - Post#744847
This is your problem...
Remote Keyless Entry (RKE) System Inoperative (Reprogram Passenger Door Module) #03-08-52-001C - (Mar 17, 2003)
2003 Cadillac Escalade, Escalade ESV, Escalade EXT
2003 Chevrolet Avalanche, Silverado, Suburban, Tahoe
2003 GMC Sierra, Yukon, Yukon XL
2003 HUMMER H2
From Start of Production (SOP) through December, 2002 for the 2003 Model Year
This bulletin is being revised to provide the latest service information. Please discard Corporate Bulletin Number 03-08-52-001B (Section 08 -- Body and Accessories).
Condition
Some customers may comment on any of the following conditions:
The RKE key fob does not function.
The RKE has a very limited range.
The passenger door will not unlock from the passengers or drivers door switches.
The passenger door window is inoperative.
Correction
Important: For clarification purposes, the following information is provided. The components involved in this bulletin are known by various names. The Service Information Document ID #849813 refers to the component as the Door Lock and Side Window Switch. General Motors Service Parts refers to the components as SWITCH DR LK & SI WDO. Within this component is a micro processor that is referred to as the Passenger Door Module (PDM). Techline equipment refers to the component as the PDM Passenger Door Module. This bulletin addresses issues with the software of the microprocessor in the Passenger Door Module (PDM).
Perform the following procedure step by step (do not skip a step) to determine the proper course of action.
Important: Verify the software version in your Tech 2. If the software is not 23.001 or newer, your Tech 2 software needs to be updated.
Determine the production date of the vehicle by viewing the certification label on the driver's door.
- If the vehicle's month of production is PRIOR to 01/03, go to Step 2.
- If the vehicle's month of production is 01/03, THIS BULLETIN DOES NOT APPLY. Refer to Customer Satisfaction Program bulletin 03011, published March 2003.
- If the vehicles month of production is 02/03 or newer, this bulletin does not apply. Refer to published Service Information for the symptom experienced by the customer.
Use the Tech 2 to determine the PDM operational software release number.
- With the Tech 2 installed and powered up, verify the software version. If the software is not 23.001 or newer, your Tech 2 software needs to be updated.
- Press Enter.
- Select: Diagnostics.
- Select model year: 2003.
- Select: Light truck.
- Select : Body.
- Select the proper Product line.
- Select the proper HVAC Type.
- Select the proper Radio System type.
- Select: Passenger Door Module.
- Select: Data display.
- Select: Module 1 information.
If a number is displayed following "Operational S/W Part Number" , continue with the next bullet.
If an (*) is displayed following "Operational S/W Part Number" , go to Step #3 below.
- If the "Operational S/W Part Number" is 15181562, 15186199 or 15186460, exit out of this bulletin procedure. Refer to Service Information to diagnose the condition reported by the customer (the vehicle has the most current software as of the date of this bulletin).
- Exit to the Main Menu.
- Perform normal SPS reprogramming of the Passenger Door Module.
- Go to Step 4.
If an (*) is displayed following "Operational S/W Part Number" , return to the screen which will allow you to select the Passenger Door Module by pressing Exit (3) times.
- Select: Special Functions.
- Select: Refresh.
- Follow all on-screen instructions.
- When the Tech 2 displays "Refresh Procedure Successful", Exit to the Main Menu.
- Go to Step 4.
Return the vehicle to the customer.
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
N4808
Module, Body Control (BCM) - Reprogram
0.4 hr
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
Copyright General Motors Corporation. All Rights Reserved.
florida
Reg: 02-20-05
07-25-05 03:17 AM - Post#744848
    In response to GM-Tech
GM Tech,
Thanks for the info! I spoke to my service advisor, mentioned the bulletin and he said that was the fix.
I'm curious to know and for the sake of no more incoveniences each time there is a bulletin or recall that needs to be done, is there a way they can fix all of these known issues, instead of fixing each time they occur?
Thanks!
GM-Tech
GM-Tech
Loc: South Florida
Reg: 06-27-03
07-25-05 06:03 AM - Post#744849
It's not an issue if it's not occuring! This doesn't happen to all vehicles, so we only fix 'em if it has the problem.
BowtieBonanza
BowtieBonanza
Loc: Las Vegas, NV
Reg: 07-14-04
07-25-05 07:40 PM - Post#744850
Hmm... I was going to suggest the military or something. At least that's what my problem was...
Click Here to see what I mean
--Jonathan
'07 Silverado 1500 5.3 2WD Ext Cab Reg Bed
-RIP 3/17/2007-
'00 Silverado 1500 5.3 2WD
Flowmaster 3" Single Exhaust
K&N Intake
Wester's 89/93 Dual Tune
florida
Reg: 02-20-05
07-28-05 12:22 PM - Post#744851
Guys just wanted to thank everyone for their input, I really appreciate the time all of you took to comment.
On a side note, when I took my truck in, the cause of the right side not working was the "passenger door module". The module was replaced, and all is now well.
GM Tech: If it's not an issue yeah, I can see how GM won't replace it....thankfully, the guys at the dealership where I go in for service is a great bunch. Thanks Bob Taylor Chevrolet!
Once again THANK YOU ALL here on the forum!!!!
nodakbassmaster
nodakbassmaster
Loc: Poorhouse, SD
Reg: 03-14-04
07-28-05 05:53 PM - Post#744852
Hopefully you'll hang around... we'll help you spend some more money and through any other issues that come up
'09 Silverado 3500HD CC LB D/A LTZ Z71, Mods Annonymous Member #3
LMC Trucks
Execution time: 0.15 seconds.   Total Queries: 13   Zlib Compression is on.
All times are (GMT -0800) Pacific. Current time is 11:27 AM
