CowboyTrukr
Loc: Salt Lake City
Reg: 06-20-09
04-25-12 07:28 PM - Post#2219163
In response to Charlie57
One of the things to consider is look at what brands have been around for a long time. High end spending notwithstanding, if you're looking for decent sound, compare different head units on the same set of speakers. Make sure the speakers are at ear level to minimize room reflection issues. The brands that come to mind are Pioneer, Kenwood, Sony, and Sanyo. Now power ratings are the issue and hype that often get misrepresented. You need to look at the Continuous power output rating and the speaker resistance at that power, for example 50W/ch 8 ohms. That means they connected some 8 ohm speakers and then cranked up the volume, measuring the power dissipated across them.
Match the speaker impedance to the amplifier rating, and make sure the speakers are rated to handle at least twice the amplifier power.
Greg
'94 Silverado K2500 4X4 5.7 5spd Xcab LB
RV cam, Pace Setter Headers, TBI spacer, Flow Tech air cleaner adapter, Hypertech street chip
"The only thing necessary for evil to triumph is for good men to do nothing" Sir Edmund Burke |
